67_13Deluxe Samba Resident Alien
Joined: February 18, 2005 Posts: 912 Location: Salt Lake City, Utah
Posted: Mon Jan 30, 2006 12:39 pm Post subject: Got a problem.... |
I was driving today in my 65 Beetle. We were at a stoplight and we started to go. I was getting ready to shift into 2nd when all of a sudden the engine revved up and i thought i heard a clunk. After thtat the car would not move no matter what gear i put it in. There was a kind of small grinding sound when i tried to go right after it happened and the car moved very slowly. But now it wont go anywhere and with the engine on I can shift freely through the gears without even using the clutch. Is this a clutch problem or a transmission. Yes i did a search but found nothing like this. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
56 Beetle - Wilbur. I found a lot of lipstick on this pig so far.
63 Beetle - Luna
66 13 window Bus - Tetanus
71 Bay Window - Lola. Totaled. |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2862 Location: Northeast Florida
Posted: Mon Jan 30, 2006 12:41 pm Post subject: |
Check for stripped drum... _________________ OG JHC
don't worry, the ciggaret is fake. |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Mon Jan 30, 2006 12:45 pm Post subject: |
UncleBob wrote: |
Check for stripped drum... |
Yep. If the axle nut is not torqued to the proper 230ft/lbs then the iron axles will strip out the splines of that cast iron drum in a heartbeat. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Mon Jan 30, 2006 1:20 pm Post subject: |
ill check that. hopefully that is the only thing that is wrong. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Wed Feb 01, 2006 1:54 pm Post subject: |
OK that is what it turned out to be. But only on the right side. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Posted: Wed Feb 01, 2006 2:31 pm Post subject: |
67_13Deluxe wrote: |
OK that is what it turned out to be. But only on the right side. |
It's usually just one side that goes. Make sure the opposite one is torqued properly. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
renderit Samba Member
Joined: October 09, 2005 Posts: 1155 Location: Austin, TX
Posted: Wed Feb 01, 2006 3:44 pm Post subject: |
Check the splines on the axle as well. My wife had a 68? T3 fastback when we got married that threw them on the drivers side all the time. They told us at the time they wanted 450 to replace the axle (1979). We sold the car...... I want it back. |
Posted: Wed Feb 01, 2006 5:02 pm Post subject: |
I will check all that tomorrow. Thanks for the help. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Wed Feb 01, 2006 11:34 pm Post subject: |
If you can shift gears without using the clutch it sounds to me like your shift coupler broke.Lift the back seat,remove the access cover and check the coupler.Sometimes you have to watch the coupler while someone shifts gears to be able to tell if its bad _________________ die schwarzen Schafe #666 |
Posted: Thu Feb 02, 2006 5:20 am Post subject: |
Alan Willis wrote: |
If you can shift gears without using the clutch it sounds to me like your shift coupler broke.Lift the back seat,remove the access cover and check the coupler.Sometimes you have to watch the coupler while someone shifts gears to be able to tell if its bad |
I will check that too. Everything seems fine when i shift. It feels right but ill definately take a look at it. _________________ If you can't dazzle them with your brilliance, baffle them with your bullsh*t.
63 Beetle - Luna
