60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Tue Jan 31, 2006 11:28 am Post subject: light question |
ok question.....
so when i turn on the parking lights in my converted to 12 volt bus the dash light and the gas light turn on, but the parking lights in the headlights don't turn on, but if i touch the knob and twist is all the way to the right the parking lights turn on.
next thing....when i pull the knob all the way out the dash lights go out and all the lights work on the out side and everything and the only thing that doesn't light up is the dash lights. the only way i can get them to work is if i hold the knob all the way to the right like before the dash lights light up and the parking lights turn on.
so what's the deal?? any help? anyone know what i'm talking about? _________________ 77 Westy - Cape Cod Sage
LLAP |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Tue Jan 31, 2006 11:35 am Post subject: |
Sounds like someone wired your switch wrong... Get a wiring diagram and double check where your wires need to be. _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Tue Jan 31, 2006 11:55 am Post subject: |
Sounds like you are wired exactly backwards. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Tue Jan 31, 2006 10:49 pm Post subject: |
I think your dash lights and your parking light wires are reversed. Do your parking lights dim as you twist the knob? The grey parking light wires should be on terminal 57, from the seat, looking at the knob, it'll be the wire on the back at the 1 o'clock position that sticks out at an angle. The grey/red wire for the dash lights goes on 58b, the terminal that's riveted at the 12 o'clock position, comes straight out of the switch then is bent 90 degrees toward the speedo. Or you could just take the switch out and look at the terminal numbers. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
