Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Thu Feb 02, 2006 5:57 pm Post subject: 010 timing ? Glenn? |
Glenn wrote: |
You should rev the engine to 3000rpm and then set the timing. Usually 28-32 degrees will work depending on your engine. |
I have a '73 Super with 1600DP, dual 34ICT's, 1.25 rockers, and 010 distrib. I have searched for timing specs, including going to Glenn's webpage and searching. I found the above quote in another thread, but I need to know if this is the correct spec for an 010 or not. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Posted: Thu Feb 02, 2006 6:04 pm Post subject: |
That statement holds true for most all Type 1 based engines with mechanical advance distributors. You won't have to rev it to 3K rpm though as the advance comes in sooner with the 010. You'll see it reach max advance with your timing light... _________________ Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine |
Posted: Thu Feb 02, 2006 6:07 pm Post subject: |
Thanks Rich _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu Feb 02, 2006 7:13 pm Post subject: |
The advance on a 010 is all in at 2500rpm, but 3000 is plenty safe.
Start at 30* and advence to 32* if it doesn't ping. If it does ping retard it to 28*. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Feb 02, 2006 7:57 pm Post subject: |
Thanks Glenn _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
