82 Vanagon with wbx engine.
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 4:04 pm    Post subject: 82 Vanagon with wbx engine. Reply with quote
Found a 1982 with WBX engine in it while searching for a wiring harness for my 82 vanagon at the junkyard. It's all factory and had some wierd labels on it saying it was exempt from emisions. I took the wiring harness out of it but even it is a little different and will need some work to get it to adapt to my 82 aircooled.
[email protected]
skinnyboy76@hotmail.com is offline
PostPosted: Sat Feb 04, 2006 6:51 pm    Post subject: Reply with quote
its a diesel. my 82 has the emission exempt sticker on it also
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 8:57 pm    Post subject: Reply with quote
no, it's not a diesel. It was a WBX engine. I even thought that as well but right on the dash it said unleaded fuel only and above the gas cap it said the same.
HerrBGone
HerrBGone is offline
PostPosted: Sat Feb 04, 2006 9:29 pm    Post subject: Reply with quote
Two questions: Are you sure itís an í82? Was the diesel replaced with a gas boxer with the exempt stickers left over from itís former life?
HerrBGone
(AKA: Dave)
A fellow wanderer on the road less traveled
Fritz, '71 Superbeetle
Galileo, '98 New Beetle
Thunder, '85 Vanagon Westfalia (full camper)
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 9:49 pm    Post subject: Reply with quote
Yep, built July of 82 according to the sticker.
If it was a Diesel replacement they went through a lot of trouble to do it. It looked 100% factory all the way down to the Unleaded Fuel only stickers. It even had A/C.
Myself and another VW guy who is knows much more about Vanagons then I crawled all over it for two hours. He is convinced it was either a prototype or test vehicle. I'm just convinced it was kind of neat and was stock.
Also one more thing (to me) say this was a stock WBX Vanagon. The same sticker inside the engine compartment that said it was emissions exampt also said that the motor was a 1.9L but didn't say gas or diesel. Now correct me if I'm wrong but wasn't the Diesel motors 1.6 and the WBX motors 1.9L? It also had sparkplugs.
