82 Vanagon with wbx engine.
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 9:49 pm    Post subject: Reply with quote
Yep, built July of 82 according to the sticker.
If it was a Diesel replacement they went through a lot of trouble to do it. It looked 100% factory all the way down to the Unleaded Fuel only stickers. It even had A/C.
Myself and another VW guy who is knows much more about Vanagons then I crawled all over it for two hours. He is convinced it was either a prototype or test vehicle. I'm just convinced it was kind of neat and was stock.
Also one more thing (to me) say this was a stock WBX Vanagon. The same sticker inside the engine compartment that said it was emissions exampt also said that the motor was a 1.9L but didn't say gas or diesel. Now correct me if I'm wrong but wasn't the Diesel motors 1.6 and the WBX motors 1.9L? It also had sparkplugs.
HerrBGone
HerrBGone is offline
PostPosted: Sat Feb 04, 2006 9:29 pm    Post subject: Reply with quote
Two questions: Are you sure itís an í82? Was the diesel replaced with a gas boxer with the exempt stickers left over from itís former life?
HerrBGone
(AKA: Dave)
A fellow wanderer on the road less traveled
Fritz, '71 Superbeetle
Galileo, '98 New Beetle
Thunder, '85 Vanagon Westfalia (full camper)
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 8:57 pm    Post subject: Reply with quote
no, it's not a diesel. It was a WBX engine. I even thought that as well but right on the dash it said unleaded fuel only and above the gas cap it said the same.
[email protected]
skinnyboy76@hotmail.com is offline
PostPosted: Sat Feb 04, 2006 6:51 pm    Post subject: Reply with quote
its a diesel. my 82 has the emission exempt sticker on it also
Fleg
Fleg is offline
PostPosted: Sat Feb 04, 2006 4:04 pm    Post subject: 82 Vanagon with wbx engine. Reply with quote
Found a 1982 with WBX engine in it while searching for a wiring harness for my 82 vanagon at the junkyard. It's all factory and had some wierd labels on it saying it was exempt from emisions. I took the wiring harness out of it but even it is a little different and will need some work to get it to adapt to my 82 aircooled.
