chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Tue Nov 23, 2010 2:54 pm Post subject: |
westyventures wrote: |
Frank Condelli installed his that way:
That's exactly what I was thinking. Thanks. _________________ -James
86 Syncro Westy, etc |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Tue Nov 23, 2010 3:36 pm Post subject: |
chimivee wrote: |
That's exactly what I was thinking. Thanks. |
I would recommend separating the cool air return however - this could be accomplished by adding holes to the electronics cover plate (the original return would be blocked by the door) and then venting the cubby by cutting a hole through to the under-fridge area. The previous version heaters actually had the air return vented through a perforated cover. |
Posted: Tue Nov 23, 2010 10:18 pm Post subject: |
Mine is one with the perforated cover (EX1800). I'll be sure to vent the space properly if I go this route. I actually have some questions about the fittings... but I'll hit you up with that if/when I finally get around to the install. Thanks! _________________ -James
Posted: Tue Nov 23, 2010 10:29 pm Post subject: |
chimivee wrote: |
Mine is one with the perforated cover (EX1800). I'll be sure to vent the space properly if I go this route. I actually have some questions about the fittings... but I'll hit you up with that if/when I finally get around to the install. Thanks! |
I have the replacement 90-degree fittings to make it fit better, if that was going to be the question. |
Energy Concepts Samba Member
Joined: March 12, 2007 Posts: 352 Location: Yacolt, WA
Posted: Tue Dec 14, 2010 2:49 pm Post subject: |
Last edited by Energy Concepts on Tue Dec 14, 2010 3:50 pm; edited 1 time in total |
Posted: Tue Dec 14, 2010 3:35 pm Post subject: Re: Propex Heater Wiring Circuit Board Help Needed :o) |
Energy Concepts wrote: |
Hi All,
Before I get too busy plugging things into the wrong place.
I thought I'd seek wisdom from the Samba
Anyone out there know for sure
where to plug the Power and Thermostat wires into?
I couldn't see anything showing where in the installation literature.
It's probably self evident, but what do I know
See Pic's:
Thanks,
John
PS: THIS IS THE 2800 PROPEX
It looks like #2 plug receiver is for the Thermostat
It is a 6 prong plug ( see further below)
but I dont know where the Power plug goes
Really? Please walk away from that heater, slowly....sit down into a chair, and read the manual supplied. Page 5:
"The connectors on the PCB are marked CN24 (power) and CN27 (switches)". As most technical installations, the first thing one should do is read the manual. Oh - and don't shorten the pipes. |
Posted: Tue Dec 14, 2010 3:44 pm Post subject: |
Thanks Karl !!!
I never was very good at reading the instructions !!! heh heh...
JC... |
Homercules Samba Member
Posted: Fri Feb 11, 2011 11:29 am Post subject: Here's some extra photos. |
I just finished my install so I'll add my input to this thread which was so helpful for me.
My photos are kinda crappy.
Sitting in the closet. The shelf just drops in now for easy servicing.
Exhaust exits fender well. Didn't get a picture of the intake. Doh! It just enters the engine bay and is routed out of the way.
TEE propane line under sink.
Cover for the intake side.
The cover was to keep any noise down but the intake screen isn't needed. Fresh air can be drawn in from inside the closet under the window. I'll be adding a shelf to cover the Propex in the closet at some point. _________________ 89 Syncro |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Feb 17, 2012 6:57 pm Post subject: Re: Here's some extra photos. |
Homercules wrote: |
Umm, I think Karl said that adding a T inside the van is sort of a no-no. Other that that possible transgression, nice work!
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Sat Feb 18, 2012 9:56 am Post subject: |
Thanks
Yah, I tried to connect the line on the outside but I couldn't get a decent flare in the little bit of room I had. I only had about an inch of line to tee into due to the regulator length and the "Extend a Stay" that I added. _________________ 89 Syncro |
Posted: Sat Feb 18, 2012 10:05 am Post subject: |
Properly done and sealed flares are ok inside. What I don't like to see is crap work with incorrect fittings, like I have photos of work done by one certain large west-coast vendor.
Probably should tie that one line to the cabinet so that it doesn't move around though. Using a quad fitting to replace the tee at the regulator would give the extra port needed. |
Posted: Tue Feb 21, 2012 4:15 pm Post subject: |
You guys notice everything!
Everything was secured before I reassembled
I also installed a quad fitting but I left the extra port for the second propane tank that I'm eventually adding. I was concerned about running a high pressure line from one tank to the other and decided it would probably be safer to run a low pressure line after the regulator. Or is this wrong? _________________ 89 Syncro |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Wed Feb 22, 2012 8:04 am Post subject: |
I considered mounting my Espar in the rear cabinet, but was concerned about having a hole in the fenderwell above the tire for the exhaust. There is a lot of water and dirt being slung in there. How did you seal the exhaust? Did you fabricate a splash shield? In the end, mine went under the back seat.
Also with the Propex, I assume the propane is being ignited to produce the heat. Is there a seperate intake for the propex for combustion or does it use the air from inside the Van? _________________ ☮️ |
Posted: Wed Feb 22, 2012 9:48 am Post subject: |
rsxsr wrote: |
...How did you seal the exhaust? Did you fabricate a splash shield? |
I sealed the exhaust on the inside of the van but have not put a splash gaurd on yet.
rsxsr wrote: |
...Also with the Propex, I assume the propane is being ignited to produce the heat. Is there a seperate intake for the propex for combustion or does it use the air from inside the Van? |
There is a separate intake. The combustion intake port comes out inside the air inlet pillar (see photo 5 first page) so you're free to route the intake hose wherever you need. I ran mine up high in the engine compartment just under the lid, sorry no picture.
There are definately some pros and cons with the rear cabinet install. But after using it a few times in cold temps I'm happy with my descision.
Pros
Fairly clean install with little impact on space
Cold air is pulled from the back (where my head is) and cycled when sleeping
You can drape a blanket from the upper bunk to close off the lower bed area and therfore use far less propane in cold temps.
Cons
More difficult to install
No heat at floor level so dosen't effectively heat the whole van
have to put a hole in the cabinet
If I think of any others I'll update this post. _________________ 89 Syncro |
SirIvor70 Samba Member
Posted: Thu Feb 23, 2012 12:00 am Post subject: |
Have located mine there too and very happy with the result. Saves on the under seat storage space. _________________ '87 Vanagon Westy
'74 1300 Beetle |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Thu Feb 23, 2012 9:11 am Post subject: |
After thoroughly pressurewashing, scrubbing and steam cleaning the underbody chassis... without engine/trans in the way....
I noticed how much space there is under the rear seat/transmission hump, so much I'm almost willing to cut/fabricate a small box for the propex to sit in.. a totally waterproof addition underbody.
I'm also curious if anyone has Backfed the existing air distribution system?
This would take advantage of circulation throughout the interior.
mm.. |
