Terry Kay Banned
Posted: Fri May 19, 2006 9:22 am Post subject: |
[quote="redwinegeek"]
thecaptian wrote: |
what are some of the benefits you noticed from the pipes? like lower engine temp? |
<<was hot, in the 80's. The coolant pipes make a large difference in cooling the engine. The temp gage never went past the little red light. I have, in the past, had to shift down into 2nd (Automatic tranny) and turn on the heater to prevent overheating.
I have to say, so far, so good!>>
I found that the pipes radiate a bunch of the coolant heat off of them --fast---and the free air that passes over them, under the Van at speed , does cut down operating temps.
It's like adding anoter radiator under the Van.
They worked out better than anticipated for me and my Vans--no doubt.
Take Care, _________________ T.K. |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Fri May 19, 2006 10:49 am Post subject: |
i was looking on the bus depot site at the cooling pipe area, and found that the plastic pipe was started after 24-F-060001. My van is like 53013 or something and i still have the steel lines.
About Terry Kay, i ordered the shorty SS pipes from him (yet to be installed, ill do it when i flush the system), and terry was nice to me, id do business with him again. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
Busdepot Samba Member
Posted: Fri May 19, 2006 9:51 pm Post subject: |
Quote: |
i was looking on the bus depot site at the cooling pipe area, and found that the plastic pipe was started after 24-F-060001. My van is like 53013 or something and i still have the steel lines. |
I have the rest (late style 1.9L, 2.1L, and Syncro) in Stainless on their way from Germany as I write this, and the should be here in about 3 weeks. Price will be about the same as the early style 1.9L ones I have now ($279 total for both pipes). _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
Terry Kay Banned
Posted: Fri May 19, 2006 10:53 pm Post subject: |
<<I have the rest (late style 1.9L, 2.1L, and Syncro) in Stainless on their way from Germany as I write this, and the should be here in about 3 weeks. Price will be about the same as the early style 1.9L ones I have now>>
And here is the question mark I have with the pipes offered by the BD.
I'm not implicating that they are of lower grade, or of lower quality material or workmanship.
What still eludes me is how can Ron have the pipes built, imported, pay the duty on them and still cost what I am paying just for the materials?
(and at a bulk price.)
I've inquired at least 4 times trying to determine what grade stainless they are, what the wall thickness is, and if in fact they have beaded ends, all to a deaf ear.
So Ron, I ask again---just outa sheer curiosity---whats the pipes made out of, whats the wall thickness, and do they have the correct beaded ends or just flared out ends to retain the hoses?
Hoses---your just using rubber hose for the splice---right???
This info would just about explain everything.
Hasta,
Terry _________________ T.K. |
Terry Kay Banned
Posted: Sun May 28, 2006 11:17 am Post subject: |
For Some reason I didn't really expect a reply.
I'd be buying an item that the seller doesn't know what he's got, or publish what they are made out of.
Another Good Deal Direct from PA. -- _________________ T.K. |
stumpy Samba Member
Joined: April 04, 2007 Posts: 181 Location: york, pa.
Posted: Mon Oct 15, 2007 2:16 pm Post subject: pipes |
TK,What do you mean by-Beaded Ends on the pipes??? Do you use anything in the pipes between the pipes?? Would you post a pic of the ends?? Thanks |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Mon Oct 15, 2007 2:55 pm Post subject: SS pipes |
Now that we can get stainless coolant pipes, how about a stainless double crossover coolant pipe for the syncro. My ALUMINUM crossover pipe corroded through on a roadtrip at one of the weld points. A new one is over $200, I got a used one from Gowesty for $50, just waiting for a stainless option. |
Terry Kay Banned
Posted: Mon Oct 15, 2007 9:39 pm Post subject: Re: pipes |
<<TK,What do you mean by-Beaded Ends on the pipes???>>
A beaded end is a hose retaining bead on the end's to keep the hose & clamp from sliding off of the pipes.
<< Do you use anything in the pipes between the pipes??>>
I don't get this question---
You mean is there anything between the splice's?
Yes--air.
The pipes are only a 1/16th of an inch apart at the spliced area in the middle of them--at the most.
On the pipes I'm building anyway.
I have no clue what the Perkimonville pipes gap is--neither do they--ask them.
<< Would you post a pic of the ends??>>
I haven't had time to figure out how to get this feature to work here---
BUT--if you take an internet ride over to the samba.com Vanagon Parts section, one of the feature ads on the top of the list has just what you asked for---plenty on picture's of the pipes--and the beaded ends.
<< Thanks >>
No Problem _________________ T.K.
Grizzly_black Samba Member
Posted: Tue Oct 16, 2007 9:08 am Post subject: |
I have a set of the Bus Depot pipes on my 2WD Westfalia. They have the beaded ends and the hose used for connecting them together (Front/back) is a high grade marine hose that is wrapped in nylon webbing material. I priced the hose out at NAPA and they said similar hose was $17.95 / Ft. (not cheap) I am not sure what grade the stainless is but I can tell you that the bends in the pipes were not exactly like the originals! It took me a while to figure out witch pipes went together. The labels were in German so they didn't help much. When I called the Bus Depot to ask for help, they didn't have a clue! They told me to match the new pipes with the old. The bends and shape of old and new were completely different so that didn't help much. I installed a set on a friends Syncro and it was almost the same story. Now that they are on I am happy with them but they were a pain in the ass to install!
Grizz |
mysticalclimber Samba Member
Posted: Fri Apr 18, 2008 9:04 pm Post subject: |
I just got a set of stainless steel coolant pipes from Bus Depot. They are TP 304L stainless steel and the wall is 0.0635" thick. They have the beaded ends and come with all the clamps. |
captainpartytime Samba Member
Joined: December 04, 2005 Posts: 715 Location: Mission Viejo, CA
Posted: Sat Apr 19, 2008 8:09 am Post subject: |
For those of us running the older 1.25" diameter pipes ('82 diesel), do I use the 1.5" SS pipes or are there 1.25" SS pipes available. Or can I use the 1.5" pipes wit some sort of pipe reducer at the ends? _________________ -Kerry
1982 turbo diesel Westfalia |
Terry Kay Banned
Posted: Sat Apr 19, 2008 8:16 am Post subject: |
The Vanagon Diesel Coolant Pipes are 1.25" diameter, and they are a much different configuration than the 1.9 1.25" pipes of the 1.9 gas Vanagon.
Same diameter,totally different bends. _________________ T.K. |
Posted: Sat Apr 19, 2008 9:42 am Post subject: |
So... when should I expect those pipes to be available from you? _________________ -Kerry
Terry Kay Banned
Posted: Sat Apr 19, 2008 10:01 am Post subject: |
The diesel pipes have been available for --uhh-- maybe 9 months or so.
I must have made 10--15 sets of them already--not near as many as the gasser's but I've been building them.
Whenever you want them. _________________ T.K. |
Terry Kay Banned
Posted: Sun Apr 20, 2008 8:07 am Post subject: |
<< the hose used for connecting them together (Front/back) is a high grade marine hose that is wrapped in nylon webbing material.>>
Huh.
The pipes I installed for a customer who popped in with the BD pipes in hand. had nothing more than plain old black rubber hose with a cotton reinforcement--no clamps.
I pulled the stuff right outa the box, there was no reinforced hose, and the box wasn't broken,
and no kinda clamps.
Maybe he changed hose supplier's after he ran outa the old stock of plain jane rubber tubing.
Not sure what the deal is, but this is what came outa the box that was shipped from the BD.
<< I can tell you that the bends in the pipes were not exactly like the originals! It took me a while to figure out witch pipes went together.>>
I had a heck of a time getting the ends to match to the point of origin, as well as at the destination.
I had to stick them in my bender to get them to match the original pipe configuration.
I don't think they were tweaked in shipment, as the box they were in wasn't damaged.
I spent a bunch of time bending the pipes so they fit right.
<< The labels were in German so they didn't help much.>>
You have to look at the arrow's and the number's that are on the sticker's to figure out which end goes where--
When you get the number's to match this is the ends that are supposed to go together at the splice.
<<When I called them and asked for help, they didn't have a clue!>>
And this sure can be a big problem if your having dificulties installing the coolant pipes.
The guys that answer the phone over there don't know anything about the pipes, they just process the order's.
I might be busier than all get out, and be real grumpy after I just wacked my thumb with a hammer trying to get to the ringing phone, but you can at least get ahold of the manufacture of the pipes if you have any questions, or need some advise on how to get them into the Van.
I am available, one way or another.
<< They told me to match the new pipes with the old. The bends and shape of old and new were completely different so that didn't help much.>>
Exactly.
They don't match the factory pipes at all.
Your on your own figuring out which side is which, and with a tweak here and there they will fit eventually.
A large Wilton Vice would be a good thing to have if you don't have a hydraulic bender handy.
You can then lock the pipes down in the jaws and tweak them some, up, down, left, or right so they kinda, sorta, will follow the original pipe's path to fit.
Don't crank down of the vice too tight, or you'll flatten the pipes where you've grabbed them to bend them to fit the Van properly.
If the jaws of the vice your using has a pipe holding jaws in it--use that instead of the flat area--you'll be less prone to smashing the pipe as you bend it to fit into the Van.
If you wind up getting the plain ole rubber hose with your replacement pipes,I would suggest doing one of two things.
Seek out some high pressure, high temp slicone hoses to replace the stuff--it's a bullet proof, and the best splice you can use.
( If you want the silicone splice union's, get ahold of me, I always have long length's of it)
Or when you go and buy the clamps that aren't included, buy 4 instead of two--it's help hold down the rubber hose tight to the pipe's.
This is why I use the silicone, reinforced, double ply, high pressure, high temp, splice hoses with my pipes.
They are like the old Chinese finger handcuff's.
Once they are on the pipe's it's almost impossible to get them off--before you have the clamps on them.
I sure can't figure out why anyone would want to shortchange this important pipe union area under the Van where it would be difficult to keep an eye on it.
It sure isn't a good idea. _________________ T.K. |
Ron Mueller Samba Member
Posted: Sun Apr 20, 2008 9:43 am Post subject: |
I just wanted to mention that if your putting together a split set of TK's pipes, be real sure you have the correct pipe matched to the correct pipe.
I made the big mistake of not reading clearly what pipe went where, and attached the blue silicone hose to the pipes.
My God.
I had one difficult time pulling the pipes apart at the splice to correct my error.
I have no fear of them ever coming apart under the Van.
I know that the area between the splices is no more than 1/16th of an inch.
I think the pipes actually touch at splice.
There should be no fear of ever having a splice failure.
And beyond all else, the stainless replacement pipes matched my old dried up and fractured plastic pipes perfectly.
They fit exactly as the factory pipes did.
No bending or adjustments necessary at all.
I'm happy. _________________ Ron |
Terry Kay Banned
Posted: Sun Apr 20, 2008 10:02 am Post subject: |
Oops!
Sorry to hear that you had to play Jack Lalaine to separate them pipes Ron.
You musta played hell yanking them apart.
Soapy water or WD-40 would have helped you a bunch-- ~ 8 )-
Ya gotta be careful and read where I have the pipes marked prior to sticking them together.
For some reason the silicone hose is a bear to separate off of the pipe--or anything for that matter.
But--I'm glad your still happy.
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Tue May 13, 2008 3:37 pm Post subject: |
Does anybody have any experience with the stainles pipes that GW is selling?
http://gowesty.com/ec_view_details.php?id=4210&search_phrase=coolant%20pipes&start=
Should I be more concerned with the age of my plastic pipes or the mileage on them? Mine were replaced in 98 and have about 60,000 miles on them. Am I flirting with disaster?
Thx! _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
need2boat Samba Member
Joined: November 13, 2007 Posts: 123 Location: North Jersey
Posted: Tue May 13, 2008 3:51 pm Post subject: |
GWTWTLW wrote: |
Should I be more concerned with the age of my plastic pipes or the mileage on them? Mine were replaced in 98 and have about 60,000 miles on them. Am I flirting with disaster? |
The pips being sold by go west, Bus Depot and Volks Cafe are all coming from the same manufacture in Germany. Everyone I know of that has installed them (on a syncro) has found they don't fit perfectly but will fit.
The set I got fit find in the back but the front bends tipped down a bit more then factory and I needed to route the front heater core lines on the side rather then directly under. Not a major issue just not like it was before.
If your lines only have 60K on them, I won't worry I replaced mine at around 200K and I wasn't getting drips.
JFF _________________ 1987 Syncro Adventurewagen: Vincent Van-Go
1998 SAAB 900 SE Coupe: Black Swan |
Posted: Tue May 13, 2008 8:41 pm Post subject: |
Terry,
Do you have pipes for Syncro Turbo Diesel, or are they the same as the regular Syncro pipes?
Grizz |
