Hazet Assistent
Page: Previous  1, 2, 3 ... , 50, 51, 52  Next
mrmenin
mrmenin is offline
PostPosted: Wed Jul 25, 2018 11:58 am    Post subject: Re: Hazet style assistant tool cart Reply with quote
I found one just like this. Do you know who the manufacturer was?
mrmenin
DannyZ wrote:
Here's a Hazet style assistant tool caddy made by another company. I have seen and owned a few of these Hazet copies Here's one I found today at a local swap meet. It looks like new. It has the rubber bumpers and the tray dividers and the book rack. 2 wheels swivel and lock. This Assistant collapses and can be put it the trunk for easy transportation. No rust or damage anywhere.
fig
fig is offline
PostPosted: Wed Jul 25, 2018 1:58 pm    Post subject: Re: Hazet Assistent Reply with quote
I recently picked up this all blue Hazet Assistent, with blue top tray and blue pre-65 Hazet logoes:
Does anyone know anything about these? Why all blue? What year/s were they built?
I've only found 1 other on this thread, the 2nd one in Wout's line-up:
Wout wrote:
Made a new line up Wink :
gr
Wout
fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..."
Wout
Wout is offline
PostPosted: Wed Jul 25, 2018 2:26 pm    Post subject: Re: Hazet Assistent Reply with quote
Hi
Repainted that's why Confused , mine is also repainted. Btw your logo is post 65.
Don't like them repainted but was the first 'small a' I got my hands on Very Happy .
gr
Wout
Aircooled vw's for life!
notchboy
notchboy is offline
PostPosted: Wed Jul 25, 2018 4:19 pm    Post subject: Re: Hazet Assistent Reply with quote
gr
Wout
Yes yours is a Post 65 with the bif "A".
Why are all the houses on Planeet Rd gated? Bad neighbourhood in SA?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
fig
fig is offline
PostPosted: Thu Jul 26, 2018 1:32 am    Post subject: Re: Hazet Assistent Reply with quote
Wout wrote:
Hi
gr
Wout
Haha. Of course it's a post-65. Sorry, had a brain fart.
This one may have been repainted, but it doesn't look like it, and the colour match is spot on. I'll have a closer look for signs of respray.
Pretty much ALL formal houses in South Africa are walled and gated unless they're in gated estates. The whole country's a bad neighbourhood. Crying or Very sad
fig
Kaapse Kombi Kult
fig
fig is offline
PostPosted: Wed Aug 01, 2018 7:35 am    Post subject: Re: Hazet Assistent Reply with quote
To the Hazet experts: is there any way to accurately date a Hazet Assistent?
I know the logo changed in 1965 and at some stage after German reunification, "Made in W Germany" changed to "Made in Germany".
When were Continetal tyres discontinued?
When did the top tray change to black from grey/silver?
When was the stool discontinued?
When did the pressed Hazet logo change to the stuck-on plastic version?
Any other changes that might assist in dating these?
My latest Assistent, above, has post-1965 logo, Continental tyres and has the hole for storing the stool. Any ideas how old it is?
My other Assistent has a black top tray and Made in Germany, so probably from the 1990s, yes?
fig
Kaapse Kombi Kult
Wout
Wout is offline
PostPosted: Sun Aug 05, 2018 4:01 am    Post subject: Re: Hazet Assistent Reply with quote
Have one stool at home, will give it a try in a few days to reproduce one. It's a lot smaller than I imagined...
gr
Wout
notchboy
notchboy is offline
PostPosted: Mon Sep 24, 2018 5:24 pm    Post subject: Re: Hazet Assistent Reply with quote
Can I get the plastic knob replacement part from a Hazet vendor? Broke off during move. Crying or Very sad
1964 1500 S
Wout
Wout is offline
PostPosted: Tue Sep 25, 2018 7:55 am    Post subject: Re: Hazet Assistent Reply with quote
Maybe some have old stock but as far as I know they’re sold out at Hazet.
Gr
Wout
blackdog1999 Premium Member
blackdog1999 is offline
PostPosted: Sun Sep 30, 2018 5:27 pm    Post subject: Re: Hazet Assistent Reply with quote
To answer this set of question for 1964 & older from my experience;
All early tops are Painted Gray with a crinkle coat type paint. There is the typical curved/arched top & the very early flat top. There is also the first generation of the flat top with a lock in the side where the rubber goes. Those I would guess are 1954-55 only. The flat top without the lock is most likely 1956-59.
The rubber for the flat top tray carts has this style rubber;
This is the rubber for arched type top tray carts;
Next there is a progression of the vertical tube supports on the middle trays.
Oldest style, 1954-1956?;
second style, 1957-59;
Third style, this may have only been for the accessory tray to change a 161 into a 162 after the fact. 1957-59?;
Fourth style, 1960-64? This is usually with the arched top tray.;
Flat top tray carts also usually have this style vertical pole support in the bottom tub;
There is also 2 types of labeling tags. The very early carts (1954-1956) have small tags on the middle trays;
Still during the flat top cart era the tag became larger & moved to the front of the bottom tub. 1957 & newer?;
Even the caster wheels show some differences during the years. The first generation had no lock on the caster wheels. (1954-55);
Next one caster wheel received a plain lock band. (1956-57)?;
Then the one caster wheel received an arm on the side to make it easier to reach. (1958-1968)?;
Last thing I will note in this posting is the logo on the bottom tub. It started out as a stamped piece of metal that is spot welded to the bottom tub before it was ever painted. (1954-1963)?
Then Hazet went to stamping their logo directly into the bottom tub. This also continued into the earliest big "A" carts until Hazet went back to a separate metal logo that was attached with double sided tape & then on to the plastic Hazet logo.
I have noticed more differences in the carts I have owned but am not sure of the chronology. The above list of changes I am pretty confident of the timeline I have listed as being 80-90% accurate. Please correct me if anyone feels I am wrong.
Home of the one true split Bus Motorhome
easy e
easy e is offline
PostPosted: Tue Oct 02, 2018 8:48 pm    Post subject: Re: Hazet Assistent Reply with quote
Whew!.... awesome detail breakdown Corey!
aka: Evan
"They are about as worthless as the tits on the boars that live in the woods behind their junk yard." -Weatherly
Wout
Wout is offline
PostPosted: Tue Oct 23, 2018 11:48 am    Post subject: Re: Hazet Assistent Reply with quote
Made a start on the repro Hazet stools
gr
Wout
catron1
catron1 is offline
PostPosted: Wed Oct 24, 2018 6:42 am    Post subject: Re: Hazet Assistent Reply with quote
Hey Wout,
I am definitely interested, keep me posted!
-Bill Very Happy
mannys66 Premium Member
mannys66 is offline
PostPosted: Wed Oct 24, 2018 10:08 am    Post subject: Re: Hazet Assistent Reply with quote
catron1 wrote:
Hey Wout,
-Bill Very Happy
me too
Wout
Wout is offline
PostPosted: Wed Oct 24, 2018 9:47 pm    Post subject: Re: Hazet Assistent Reply with quote
Ok Cool
gr
Wout
ottovu
ottovu is offline
PostPosted: Sat Nov 03, 2018 6:47 am    Post subject: Re: Hazet Assistent Reply with quote
Wout,
Id buy a stool if you ever sell them. Keith
Wout
Wout is offline
PostPosted: Sat Nov 03, 2018 1:47 pm    Post subject: Re: Hazet Assistent Reply with quote
Made some progress on the stools, they’re allost all in paint.
Gr
Wout
SplitBusVanatic
SplitBusVanatic is offline
PostPosted: Sat Nov 03, 2018 4:01 pm    Post subject: Re: Hazet Assistent Reply with quote
I would buy a stool too.
Let me know if you will be selling them.
Thanks.
I'm In Ireland
My Diesel Splitty Project
PostPosted: Sat Nov 03, 2018 6:49 pm    Post subject: Re: Hazet Assistent Reply with quote
What did you use for the rubber feet?
Gr
Wout
Wout
Wout is offline
PostPosted: Sun Nov 04, 2018 1:49 am    Post subject: Re: Hazet Assistent Reply with quote
I bought this in our local hardware store. 17mm would have been better but is not available.
Gr
Wout
Page 51 of 52
