Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Sun Jan 21, 2018 12:15 pm Post subject: Re: Lowering a Bay FAQ |
Check my gallery for pics (some posted a few replies above too). I’m not super slammed by any means, and I’m also running 17’s with (near) stock diameter tires. I’m as far down as I can go without needing tubs and notches. I only get the slightest of a rub up front when completely loaded and hit a larger bump/dip.
Those trailing arms are interesting... I’d have to go poke my head back underneath to see, but I thought the cv shaft would be the first interference. Also, maybe there is difference in frame rails between early and late bays? Not sure on that either. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
bonzai272 Samba Member
Joined: January 20, 2006 Posts: 237 Location: NorCal (East Bay)
Posted: Sun Jan 21, 2018 12:25 pm Post subject: Re: Lowering a Bay FAQ |
Saw the pics. Looks good.
Anyone have photos and/or a how-to of how they notched their frame?
I noticed that same company I just linked sells a bolt-in c-notch kit. Basically line it up, cut the notch, then drill the holes and bolt the kit to the frame. Anyone have any experience with it?
http://www.vintagev-dubs.com/shop/1968-79-bus-bolt-on-c-notch-clips/ _________________ 1955 Beetle |
Trashman Samba Member
Joined: May 18, 2016 Posts: 280 Location: Santa Cruz, CA
Posted: Sun Jan 21, 2018 4:56 pm Post subject: Re: Lowering a Bay FAQ |
I wouldn't mess with those bolt on frame notches. If you're going to be cutting into your frame, do it right and weld everything in. Theres three general types of rear notches.
First there's the regular c-notch for the cv's
Then there is a big notch for both trailing arm and cv. This way you retain some of the original frame, box it in, and add more material on top.
Lastly, there are the big daddy notches where you cut out the entire section of frame and replace it with rectangular tube tucked as high as you can get it.
_________________ Bagged 1968 Neptune Blue "Deluxe" |
AirKooledGarage Samba Member
Joined: September 28, 2012 Posts: 314 Location: Wisco
Posted: Sun Jan 21, 2018 6:57 pm Post subject: Re: Lowering a Bay FAQ |
bonzai272 wrote: |
http://www.vintagev-dubs.com/shop/1968-79-bus-bolt-on-c-notch-clips/ |
Not sure bolt on is the ticket. I used a 5" tube, cut it in half and hole sawed the notch and welded it in. Bottoms out right before engine hits the ground.
Posted: Sun Jan 21, 2018 7:42 pm Post subject: Re: Lowering a Bay FAQ |
Excellent explanation on the different notches and their progression Trashman!
bonzai272, just depends on how low you want to go... on stock diameter tires, I’m at the practical limit (at least IMO). Shorter tires would be the next easy thing, past that it’s tubs and notches. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
Posted: Sat Jan 27, 2018 10:40 am Post subject: Re: Lowering a Bay FAQ |
Vee Dub Nut, your bus is so clean. Yours is set basically exactly how I would do it, as low as possible without notching and without axle hitting. However, Id probably go with 15" wheels instead.
Anyone have any photos with 15" wheels as low as itll go without hitting, notching or tubbing? _________________ 1955 Beetle |
Posted: Sat Jan 27, 2018 7:25 pm Post subject: Re: Lowering a Bay FAQ |
bonzai272 wrote: |
Anyone have any photos with 15" wheels as low as itll go without hitting, notching or tubbing? |
Thanks bonzai!
I could certainly go lower on some 15's and shorter tires without requiring any body mods, but I love the look of the 17" Fuchs.
I have some pics of it on the stock 14's and 185s at this height. Since my current 17" fronts are 0.5" shorter than stock, I do get a tendency to rub a bit when the stock height tires are back on up front. That and the rears won't go on without airing them down first to squeeze past the fender lip. That's another plus of the 17", since its ID is bigger, the rears go on with no games. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
pgtips Samba Member
Posted: Mon Jan 29, 2018 2:13 am Post subject: Re: Lowering a Bay FAQ |
Hi,
I hope someone can help with a pic.
I had my bay mild lowered inch or so all round but I'd like to get rid of the negative camber .
I read on the first page from long-roofs post
Quote: |
when lowering the rear, you can maintain good camber if you shim on the top bolts between where the spring plate and trailing arm meet. |
which ones exactly are the top bolts, my wheels are off while I install engine and I may as well tackle this but if theres a 50/50 I don't want to mess it up.
is shim still seen as acceptable route to reduce camber ?
PG _________________ 1975 1.8l FI Auto Westy - Subaru converted
1971 356 kit 1600 TP - semi/stickshift
1971 1302 LS - semi/stickshift
Trim ring info here -> http://www.thesamba.com/vw/forum/viewtopic.php?t=559668
http://www.thesamba.com/vw/forum/viewtopic.php?t=451210
http://www.thesamba.com/vw/forum/viewtopic.php?t=479721 |
72camper Samba Member
Posted: Mon Jan 29, 2018 11:07 am Post subject: Re: Lowering a Bay FAQ |
bonzai272 wrote: |
Here is mine with 5" narrowed, adjustable front beam and 3 1/2" plates out back. I'm running on 15x5.5 wheels with 195/55-15 tires. It was 2" lower up front, but with the family going with me all over and camping, we kept scrubbing front tires and din't want that.
0616161532c by Camper Mike '72, on Flickr
buscamping3 by Camper Mike '72, on Flickr |
Posted: Tue Jan 30, 2018 7:28 am Post subject: Re: Lowering a Bay FAQ |
That is perfect, thanks for sharing! _________________ 1955 Beetle |
Posted: Fri Feb 02, 2018 10:07 pm Post subject: Re: Lowering a Bay FAQ |
I found a pair of horseshoe plates in a box from the previous owner but no markings on them.
They are however, zinc coated. Anyone know who might have made them? Most the ones Ive seen are raw or black. _________________ 1955 Beetle |
metz Samba Member
Posted: Sat Feb 03, 2018 2:23 am Post subject: Re: Lowering a Bay FAQ |
bonzai272 wrote: |
They are however, zinc coated. Anyone know who might have made them? Most the ones Ive seen are raw or black. |
Could be these? https://type2detectives.com/collections/suspension...-early-bay _________________ 68 panel
64 ghia coupe |
Posted: Wed Feb 07, 2018 3:03 pm Post subject: Re: Lowering a Bay FAQ |
Couple quick questions I'm sure easy answers but hard to find in this long thread.
Installing 3.25" horseshoe plates on rear of my 70 bus, I need to remove drums in order to disconnect e-brake....correct?
I'll obviously remove the bump stop but will I also need to cut off the bump stop arm near the spring plate?
Is disconnecting the hard brake line from the wheel cylinder required?
Lastly, what shocks are people running? _________________ 1955 Beetle |
Posted: Mon Feb 12, 2018 8:33 am Post subject: Re: Lowering a Bay FAQ |
I think I found some of my answers. Yes drums need to be removed but doesnt appear I need to cut off the bump stop arm.
Still not sure if disconnecting the hard brake line is required and what type of shocks people are running.
Ive read stock shocks and "bug shocks" but no specifics. Anyone? _________________ 1955 Beetle |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Mon Feb 12, 2018 3:13 pm Post subject: Re: Lowering a Bay FAQ |
I used KYB's from the back of a bug with horseshoe plates. Rode really good, and bolted up cheap and easy.
I don't think you will need to remove the hard line. There should be just enough flex in the soft line to get stuff moved around and in position.
Brian |
Posted: Tue Feb 13, 2018 7:50 am Post subject: Re: Lowering a Bay FAQ |
Thanks for the reply!
I assume you used stock length rear bug shocks instead of lowered bug shocks, right?
What did you use for the front shocks? (assuming you had an adjustable beam with dropped spindles) _________________ 1955 Beetle |
Posted: Thu Feb 15, 2018 6:42 pm Post subject: Re: Lowering a Bay FAQ |
Got the rear end finished today. Ran out of good daylight so Ill post pictures later.
Installed 3.25" horseshoe plates and went with 15x5.5 chrome 5-spokes on 185/60R15 tires.
I was luckily able to get the rear wheels on without having to flatten the tire or do anything else. I dont have shocks on the rear yet though so that may have helped.
Driving around the block wasnt even that bouncy without shocks so I may leave it shock-less. We'll see.
No notching needed either as no impact between axle and frame, even with me jumping on the bumper. No tire rubbing either.
Still waiting on the front beam to arrive so I can get the nose down level. _________________ 1955 Beetle |
Posted: Fri Feb 16, 2018 4:32 pm Post subject: Re: Lowering a Bay FAQ |
3.25" horseshoe plates installed with 15x5.5 chrome 5 spokes on 185/60R15 tires. no rubbing, no frame notching, no axle hitting frame, no having to flatten tire to get wheels mounted.
Posted: Sun Mar 04, 2018 8:34 pm Post subject: Re: Lowering a Bay FAQ |
Got my Wagenswest 4" narrowed beam finally installed. Bus already had dropped spindles.
atech Samba Member
Posted: Mon Mar 05, 2018 9:15 am Post subject: Re: Lowering a Bay FAQ |
bonzai272 wrote: |
looks sweet! _________________ welloffandwellconnected.tumblr.com |
