DASLWST Samba Member
Joined: October 21, 2007 Posts: 194 Location: JACKSONVILLE
Posted: Wed Apr 15, 2020 4:03 pm Post subject: Re: Lowering a Bay FAQ |
Anyone in the states making endplates for an early bay? Or have the file so I can get them cut? _________________ #daslwst |
vee dub dan Samba Member
Joined: June 23, 2004 Posts: 445 Location: Pennsylvannia
Posted: Wed Jul 01, 2020 11:18 am Post subject: Re: Lowering a Bay FAQ |
Hello,
I bought a lowered bus recently and looking for some input. Has the slam the bay kit on it running 195/60-14 all around.
The engine blew on the way home from camping. It looks like a mix of a bad intake gasket and part failure. But we cruise between 55-58 mph most of the time and that's almost 4000 RPM.
I see a lot of people running similar sized tires. Has anyone changed their transmission gearing, or just built a higher revving engine? I think i'm going to try some bigger rear tires, at the very least for the summer, but just curious what others have done.
I'm going to test fit some 185r14 LT tires in the rear soon to see what it looks like, but I don't know if low profile in the front and light truck tires in the back are a good idea or not. Assuming they remotely fit.
_________________ 1974 Standard Beetle - Slammed
1956 Deluxe Oval - Running project
1969 Deluxe Transporter
Fresh Air VW Car Club - Pittsburgh, PA |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Wed Jul 01, 2020 11:23 am Post subject: Re: Lowering a Bay FAQ |
Yes, running small diameter tires with a stock geared trans can cause issues. Fit the tallest tire you can in there, or build a trans with taller gearing. Try to get the final drive ratio (with tire diameter calculated into that formula) as close to stock as possible, if you continue to use a stock-ish engine.
Sorry to hear about your engine failure. It may or may not have been due to excess RPM, but it sucks either way. _________________ nothing |
Posted: Wed Jul 01, 2020 11:28 am Post subject: Re: Lowering a Bay FAQ |
cdennisg wrote: |
Sorry to hear about your engine failure. It may or may not have been due to excess RPM, but it sucks either way. |
My friends and I agree that it may have exposed and accelerated 1-2 small issues, but that it probably would have done it regardless of RPM at some point. _________________ 1974 Standard Beetle - Slammed
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Wed Jul 01, 2020 11:59 am Post subject: Re: Lowering a Bay FAQ |
vee dub dan wrote: |
Hello,
The tire you're running now is 2.5" shorter than stock, and produces a ~ 10% difference in circumference, height, and speedometer error. Using a close to stock height tire should be very beneficial. A 185r14 like you stated should fit fine and help out a lot. I run a stock height tire on the rear and am lowered more than your bus with no issues. I do recommend it. Maybe this is the time to build a larger engine, then you can calculate the package all together for efficiency. Good luck! |
garymaertens Samba Member
Posted: Wed Jul 29, 2020 11:27 am Post subject: Re: Lowering a Bay FAQ |
Hey guys quick question, I was about to install the rear horseshoe plates in the next week or so and I heard that there has to be modifications or replacement to the rear brake lines?? I hear a lot about you brake cable stuff and that all looks pretty straightforward to do, but nothing about brake line modifications any first hand experience on that.. |
busmania Samba Member
Posted: Wed Jul 29, 2020 6:01 pm Post subject: Re: Lowering a Bay FAQ |
I think I had to re bend my rear brake hardlines but it was no big deal as I recall. |
Posted: Wed Jul 29, 2020 6:29 pm Post subject: Re: Lowering a Bay FAQ |
Okay right on. I appreciate the reply 👍 |
xcoldgrimjimx Samba Member
Posted: Wed Oct 07, 2020 2:39 pm Post subject: Re: Lowering a Bay FAQ |
Hey dudes
Was wondering if anyone has information on this westfalia, like specifically what was used on the lowering aspect... any info much appreciated . Thanks
_________________ ya it's rusty...but it's MINE!!!!! |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Fri Oct 23, 2020 8:47 am Post subject: Re: Lowering a Bay FAQ |
Hi guys. I have a front end knock on a lowered type 2 bus.
I've just measured the front shock travel
With the bus on its wheels the top shock bolt to bottom shock bolt is 300mm.
With the shock fitted and the bus on its wheels I only have 1 and a 1/4 inch shock travel till it bottoms out. This is with no front seat passenger, so with more weight that number will drop.
What number should I be at travel wise.
Thanks. |
Posted: Fri Oct 23, 2020 9:06 am Post subject: Re: Lowering a Bay FAQ |
GARRICK.CLARK wrote: |
Thanks. |
I don't have a definite answer regarding how much compression your shock absorber needs, but I have a few suggestions:
From what I understand, rule of thumb is you want 2x the compression potential than extension from ride height. AKA, if the shock has 6" of travel, you want to have 4" of compression and 2" of extension.
Your current shock, sitting 11.8" tall at ride height, compressed 1.25" will bottom out. That gives around a 10.5" compressed length. I would guess the extended length is somewhere around 15"? You can check this to confirm. But 1.25" of compression sounds insufficient.
The other major thing to consider is how much clearance your tire has before it contacts the dogleg/ wheel well of the bus? How low is your bus/ what specs? Pics?
Sometimes shopping for shocks is difficult due to the lack of specs provided by the sellers, but I would assume you might want something closer to a 9" compressed length? Again, all very dependent on your set up. |
Posted: Fri Oct 23, 2020 10:08 am Post subject: Re: Lowering a Bay FAQ |
I'll get some more specs tomorrow, but is not slammed, top of tyre isn't tucked under the arch. No tyre scrub marks on underside of arch. 2 people sat in the front will be getting the inch and a quarter down to half inch I think. I'll get 2 people to sit in the van and remeasure. I scribed a bottoming out mark on the shock body so I'll be able to tell from there. The shocks on it now might even be standard length ones. |
Posted: Fri Oct 23, 2020 10:24 am Post subject: Re: Lowering a Bay FAQ |
As long as you measured the shock at ride height, now you can remove it and cycle it to see it's compressed and extended lengths. As long as you know the length at ride height, you will be able to source a new, correct length shock. I would agree that if you're not very low, they may be stock size. |
CarlSpackler Samba Member
Joined: December 12, 2005 Posts: 665 Location: Mason, Ohio
Posted: Mon Nov 02, 2020 7:18 pm Post subject: Re: Lowering a Bay FAQ |
Okay, so after days of reading this and a couple other threads I believe I have an answer to my question, but could use validation: 1970 bus, stock wheels, getting new Hankook tires. Just trying to drop a couple inches so I can get my hightop inside by 8' garage door (both are 94-1/2"). 2-1/2" drop spindles, and notch in the back should even it up. Sound right? When I switch to disc brakes I'll need the babystangs from Nate or 15" wheels, which will be a different challenge due to the width.
Other options? _________________ '67 Micro Bus
'73 Thing
'91 Westy |
CalLookVdub Samba Member
Posted: Sun Jan 03, 2021 10:39 am Post subject: Re: Lowering a Bay FAQ |
after using 4.5 in drop plates on my 70 deluxe, the cable sheathing no longer reaches. Hoping someone has come across this before. I have already cut up the old cable piece and can use it as a sleeve between the backing plate and the sheathing, but now the cable may/will not reach all the way to the lever up front.
_________________ My Rides
'58 beetle - L335 Capri Blue
'63 15 window Deluxe
'67 Squareback
'68 Sunroof beetle - 1st bug, bought back
'70 Bay window deluxe
'71 Bay window
'14 Jetta SE 1.8T |
Posted: Sun Jan 10, 2021 3:32 am Post subject: Re: Lowering a Bay FAQ |
I could probably machine you up a pair Like a sleeve type thing it would fit over the e break aluminum part and slide into the baking plate . I have a mazak lathe and a Bridgeport Manuel mill should be able to make them in about 3 days out of t6 aluminum.... and to everyone else WHY IS THIS THREAD SO DEAD!? geez wiz! Let’s see some slammed rides!!! I thought with all this stimulus money going around and everyone having some extra time on their hands I thought I would see a lot more bad ass bay’s coming out the lowering kitchen !!!! ps I now it’s really expensive to lower a bay the right way so I know that probably has a lot to do with it ... family , food , water & a roof over head comes first ! But can we see some inspirational pics!? ....please??? _________________ ya it's rusty...but it's MINE!!!!! |
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Sun Jan 10, 2021 1:42 pm Post subject: Re: Lowering a Bay FAQ |
The swing axle guys use a collar/sleeve for that gap. _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sun Jan 10, 2021 2:23 pm Post subject: Re: Lowering a Bay FAQ |
panel wrote: |
The swing axle guys use a collar/sleeve for that gap. |
Yep. You can make them out of section of old tie rod using a grinder. Or you can buy one for a split bus application and shorten it a little. Or you can get some machined by a pro.
https://www.thesamba.com/vw/classifieds/detail.php?id=1973717 _________________ nothing |
cooper363 Samba Member
Joined: July 23, 2018 Posts: 10 Location: Atlanta, GA
Posted: Tue Jan 12, 2021 2:42 pm Post subject: Re: Lowering a Bay FAQ |
xcoldgrimjimx wrote: |
I could probably machine you up a pair Like a sleeve type thing it would fit over the e break aluminum part and slide into the baking plate . I have a mazak lathe and a Bridgeport Manuel mill should be able to make them in about 3 days out of t6 aluminum.... and to everyone else WHY IS THIS THREAD SO DEAD!? geez wiz! Let’s see some slammed rides!!! I thought with all this stimulus money going around and everyone having some extra time on their hands I thought I would see a lot more bad ass bay’s coming out the lowering kitchen !!!! ps I now it’s really expensive to lower a bay the right way so I know that probably has a lot to do with it ... family , food , water & a roof over head comes first ! But can we see some inspirational pics!? ....please??? |
I use this thread for info, I have spent so much time reading but never posted anything so here is my 68 Deluxe, no tubs, no air ride
Posted: Wed Jan 13, 2021 7:16 pm Post subject: Re: Lowering a Bay FAQ |
[/list] _________________ ya it's rusty...but it's MINE!!!!! |
