What did you do yesterday on your buggy?
Page: Previous  1, 2, 3, ... 197, 198, 199  Next
wythac
wythac is offline
PostPosted: Sat Feb 18, 2006 1:06 pm    Post subject: Reply with quote
Still working on my pan. Just got it back from having bed liner on both sides of it....awesome. Routing hyd. clutch, brake and fuel lines, painting parts. Completion too far out to get real excited about having it ready by the time it gets warm.
SeeBee, would like to know what mfg and size of the tires you are running..they look ideal for what I have in mind.
Yellermanx
Yellermanx is offline
PostPosted: Sat Feb 18, 2006 4:53 pm    Post subject: Reply with quote
As some of you know I have been working on a body lift. There was some discussion on steering shaft alignment. I am using a super beetle u-joint shaft and part of the column. In these two pictures you can see that I welded the bottom couple inches of the super column to the bottom of standard column which is much longer. The shaft also had to be lengthened and the lower part of super shaft used because of bearing. I made a mistake and welded too close to the end of the super column and made the bearing holder come loose. Now I have to find a bushing that will work instead. The pieces are just tacked in pictures to check fitment. The second picture shows how the shaft fits underneath. For other pics of lift project click link below. This is what I am doing now. Just finished mounting seats and started wiring.
http://photobucket.com/albums/v635/Yellermanx/?start=all
MURZI
MURZI is offline
PostPosted: Sat Feb 18, 2006 5:26 pm    Post subject: Reply with quote
Chuck, Lookin goooood!!! Keep me posted on any hints on the wiring job. I will be tackling that next. Weekends have been filled lately so no buggy attention. If I just had some time, I could be awesome....
HEHEHE Very Happy Very Happy Very Happy
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
flaboyjim
flaboyjim is offline
PostPosted: Sat Feb 18, 2006 5:58 pm    Post subject: Reply with quote
Chuck;
I hope mine turns out that good - taking the week off to get er done...
Flaboyjim
Mid 60s Manx Clone - almost finished
1968 Manx M2178G826S - in process
View user's profile Send private message Send e-mail AIM Address Twitter Gallery Classifieds Feedback
MURZI
MURZI is offline
PostPosted: Sat Feb 18, 2006 6:30 pm    Post subject: Reply with quote
Yea, I am aiming for March 18th as the final date. I want to bring it to a VW show on March 18th. Looks like I may have to take off a day or two to get it done too. All that is left to do is the wiring and some misc painting. I used to wake up at 4:00 am and go out to the garage and work before work, but with all the cold weather it is just too hard to get out of a warm bed. Hopefully it will warm up and I can be ready for some spring cruising........
MURZ
http://photobucket.com/albums/b374/MURZI/
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
Yellermanx
PostPosted: Sat Feb 18, 2006 6:41 pm    Post subject: Reply with quote
Hey Jim, Time's a runnin out. 34 days and counting. I hope you don't have as many problems as I have had. It fights me at every turn such as the bearing support coming out. I guess that was my fault. I put the engine in today and now it is sitting lop sided. I'm hoping that the spring plate bushings haven't seated yet and they are holding it of kilter. The plates were installed correctly, chassis level and the same angle with a protractor. I hope after I get it running and take it for a bonsai ride it will be level.
Hey Murzi, just start hooking things up. Start with the ignition and engine that way you can move it, however you will have to fight the urge to take off down the street. OK go ahead once. One thing at a time and eventually they will all be hooked up.
Yellermanx
PostPosted: Sat Feb 18, 2006 6:45 pm    Post subject: Reply with quote
Murzi and Jim, At least when you two get your 's done you will be through. Mine will still need the body done. (later) Oh yea I want a go fast engine too. I have spent a fortune on nuts and bolts the last couple of weeks. Rolling Eyes
MURZI
MURZI is offline
PostPosted: Sat Feb 18, 2006 9:58 pm    Post subject: Reply with quote
Yea, I bet I have at least $200.00 in nuts and bolts and that is in just regular grade---not stainless. At some point, I am beyond it, you get sick at the money that goes into one of these things. I am ready to be done.
MURZ
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
seabeebuggy
seabeebuggy is offline
PostPosted: Sat Feb 18, 2006 10:19 pm    Post subject: Reply with quote
I am past sick at how much money I put into it. now I just don't think and keep dumping into it. May as well make it like you want it. you will not get the money out of it. have fun fun fun.. LOL Wink
Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad
flaboyjim
PostPosted: Sun Feb 19, 2006 8:36 am    Post subject: Reply with quote
Things just seem to get in the way of finishing. I had hoped to get the body done this week, but there has been a holdup. If things dont start going better, FACT - O - BAKE may be the theme of the day. I have found that painters are a lot like artists, they will only give you so much leway to get the thing to them, after that, they ignore you......
keep your fingers crossed for me -
o, Chuck, i found the button head bolts for the body - there is a wholesale supply wearhouse just down the street from me - I wandered in and asked, they had them!!!
Flaboyjim
73resto
73resto is offline
PostPosted: Sun Feb 19, 2006 1:05 pm    Post subject: Reply with quote
Yellermanx
where can i find some pictures of your project that your lifting?
Yellermanx
PostPosted: Sun Feb 19, 2006 1:39 pm    Post subject: Reply with quote
73resto wrote:
Yellermanx
Right here. http://photobucket.com/albums/v635/Yellermanx/?start=all
There are other pictures there, but the lift pics are pretty self explanatory.
It is made of plastic decking from Home Depot. Two boards Liquid Nailed together. If you have any questions feel free to ask.
BTW it is on a Berrien chassis.
mr_bill
mr_bill is offline
PostPosted: Mon Feb 20, 2006 12:12 pm    Post subject: Reply with quote
I took mine out for a ride.................. Laughing
see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
UncleBob
Grease Midget
UncleBob is offline
PostPosted: Mon Feb 20, 2006 12:38 pm    Post subject: Reply with quote
Jeez, that looks like crap, Chuck. Laughing
Come March, I know where I'm eating my lunch.
OG JHC
don't worry, the ciggaret is fake.
flaboyjim
PostPosted: Mon Feb 20, 2006 4:43 pm    Post subject: Reply with quote
Today:
Took engine tin to get powder coated. Had a stroke of luck, he was running a lot of the color that I wanted on Wednesday, so I got it done for $50.00 including the sandblasting...
Polished the Alternator, cylinders and intake manifolds of Kadrons (still looks like shi. though - gotta start over).
I tried to play body man and fill in the pin holes in the body - BLEW IT! I put way too much resin on, now it is a major sand and re-seal job.
Installed Aluminum bolt on rocker covers. (looks good)
Drilled floorboard for install of e-brake and pedal cluster.
Ran out of time to do anything else - will be in the garage till midnight re-polishing the alternator and intakes.
Flaboyjim
Yellermanx
PostPosted: Mon Feb 20, 2006 5:22 pm    Post subject: Reply with quote
I don't even have it running yet and it is already a lot dirtier than that picture. Confused The shoe still look the same, maybe you can eat off of it. Razz
Yellermanx
PostPosted: Mon Feb 20, 2006 5:24 pm    Post subject: Reply with quote
flaboyjim wrote:
Today:
Polishing the alternator and manifolds? I just stuck my old dirty engine back in. You trying to make me look bad? Embarassed
Billet_Bus
Billet_Bus is offline
PostPosted: Mon Feb 20, 2006 6:17 pm    Post subject: Reply with quote
Finished the undercoating and got my tires mounted.
Heres a pic of the mock up
i also picked up my new tranny Twisted Evil
www.Full-Race.com
Anything else is just half fast.
CTD Fabrication
seabeebuggy
PostPosted: Mon Feb 20, 2006 6:47 pm    Post subject: Reply with quote
I did nothing on the buggy again. I went skeet shooting with the boy scouts. sunburned!!
WuZaBuG
WuZaBuG is offline
PostPosted: Wed Feb 22, 2006 6:31 am    Post subject: Reply with quote
Filled the pits in my pacer wheels after sandblasting. Getting ready to try powdercoating myself. [/img]
I have been through some terrible things in my life.
Some of which, actually happened.
Page 2 of 199
