What did you do yesterday on your buggy?
Page: Previous  1, 2, 3 ... 190, 191, 192, 193, 194  Next
hillmotorsports
hillmotorsports is online now
PostPosted: Sat May 27, 2017 5:36 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Jim
Is that a carbon shift tube?
Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!)
SoCal67Volks Premium Member
SoCal67Volks is offline
PostPosted: Sat May 27, 2017 8:55 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
hillmotorsports wrote:
Jim
Paul,
Yes things were just too crowded and there was no way the stock shift tube would squeeze in. Even with the 1/2" diameter carbon fiber shift rod I had some trimming to do.
Meyers Manx Kickout #33
1967 Type 1 Sunroof
"Making a car look complicated is easy, making it look simple is hard." John Buttera
Singerdude
Singerdude is offline
PostPosted: Sat May 27, 2017 9:15 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Damn I wish we would be allowed to register custom made frames here. SoCal67Volks yours looks AWESOME. From a safety and regulations standpoint it doesn't make sense. i would have way more confidence in beating the snot out of that than a cut/welded stock one that endured 45 years of abuse.
hillmotorsports
PostPosted: Sun May 28, 2017 3:40 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Singerdude
You need to adjust your perspective.....
If you think along the lines of of the Meyers Tow'd you can make a new frame similar to the frame here but utilize the rear suspension/torsion tube/transmission mount section of the VW frame. Now you still have an original, oem VW chassis number on a new and improved frame.
Not sure how much different the regs are in Quebec....
Morrisburg, Ontario
YDBD
YDBD is offline
PostPosted: Sun May 28, 2017 6:06 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Out cruising the buggy with the bike trailer on a gorgeous day in Bavaria..
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
Singerdude
PostPosted: Mon May 29, 2017 2:02 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Singerdude
Quebec has probably the strictest laws in CAN in respect to custom built cars but the lousiest, least enforced laws for regular cars... You see people on the roads with crapped out mid-90's Sunfire rustmobiles rolling undisturbed. But custom builders have to jump through endless hoops or sometimes bend the laws a bit to get their cars registered. Bureaucratic idiocy...
For sure there are workarounds like what you suggested, I not a fabricator by any stretch of the imagination so my results would be worlds away from a bought trick chassis from Airkewld or others...
hillmotorsports
PostPosted: Mon May 29, 2017 6:35 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Singerdude
Dave Barrett of Manxchassis (Arizona, not far from Las Vegas NV) would be my 1st choice but Berrien Buggy in PA could also build a tube chassis with an oem VW torsion/suspension/transmission mount with the serial number unmolested.
It might be worth your while to call either or both and discuss this directly with them.
Morrisburg, Ontario
Singerdude
PostPosted: Mon May 29, 2017 6:58 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Oh I'm not in need for a chassis, my buggy is complete. But seeing as it now has a rather lively 2276 in the back and I'm pushing it pretty hard on very twisty roads. I'm pretty sure I'm outside of the driving parameters that these things were originally engineered for. I'm also considering Turbo-ing it. Add to that the fact that a 45 years old chassis surely must have some sort of metal fatigue. A nice tube chassis with coilovers on all corners would be confidence inspiring and would add a lot of "trickness" factor. But if I ever start a buggy from scratch I will surely keep your ideas in mind Smile
MrGoodtunes
MrGoodtunes is offline
PostPosted: Sun Jun 11, 2017 9:43 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Replaced my buggy's rear window with a clean new piece of clear plexiglass:
Built its frame using window moulding from a VW Vanagon about 3 decades ago. Original plexi had yellow'd and micro stress crack'd; it was getting hard to see thru.
911pickup
911pickup is offline
PostPosted: Thu Jun 29, 2017 7:55 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
I finally got my Thing off the lift and running properly. I've decided to drive my Thing this summer and save my dune buggy project for the winter.
Storing my buggy this way gives me more room in my shop. More room means I now have room for another project. Very Happy
motoRAT
motoRAT is offline
PostPosted: Sun Jul 02, 2017 11:15 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
still working on the shell
Be curious, dismantle it all, reassemble it, go for a ride!
motoRAT
motoRAT is offline
PostPosted: Sun Jul 02, 2017 12:51 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
new dash and "tailgate"
cj92345
cj92345 is offline
PostPosted: Sun Jul 02, 2017 1:50 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
[img]https://www.thesamba.com/vw/gallery/pix/1662891.jpg[/
Picked up wheels
SBD
SBD is offline
PostPosted: Sun Jul 02, 2017 7:53 pm    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
cj92345 wrote:
Picked up wheels
Fixed it for you! Cool
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
oprn
oprn is offline
PostPosted: Mon Jul 03, 2017 6:30 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
I ran into a snag on my new engine build, out of time to sort it out with all that is on our plate this summer so back in went the old tired 1600 DP with it's Kadrons and all their issues. Sorting out some details so we can drive it for the summer. Wiring yesterday and break adjustment today...
cj92345
cj92345 is offline
PostPosted: Mon Jul 03, 2017 11:18 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
thanks SBD!
motoRAT
motoRAT is offline
PostPosted: Thu Aug 03, 2017 11:11 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
finally, the fiber is ready for paint Shocked
oprn
oprn is offline
PostPosted: Sat Aug 05, 2017 6:55 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
I finally solved all the electrical issues I (and the previous 2 owners since 1976 no doubt) have been having. The original builder used the stock Bug wiring harness and fuse panel. No end of chasing electrical problems with lights etc. Then it dawned on me in the middle of the night that the fuse box including all the original ground connections were mounted on fiberglass!
I ran a ground wire from the fuse panel mounting bracket down to one of the master cylinder mounting bolts and... Bingo! All the problems evaporated!
motoRAT
motoRAT is offline
PostPosted: Sun Aug 06, 2017 3:54 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
And I've done the controversial raptor Twisted Evil
not bad, not bad at all
oprn
oprn is offline
PostPosted: Sun Aug 06, 2017 6:31 am    Post subject: Re: What did you do yesterday on your buggy? Reply with quote
Aw man! After all that work I was hoping it would be shiny.
Anyway, good job and enjoy!
Page 191 of 194
