Haus14 Samba Member
Joined: October 10, 2009 Posts: 7 Location: NY/Fla USA
Posted: Mon Jan 27, 2020 7:47 am Post subject: Re: What did you do yesterday on your buggy? |
I like those mirrors! I will check with the local Harley store and inter net and see what's available.
I have a pair of early VW round mirrors (door hinge mount) that I am trying to come up with a mounting system.
NICE BUGGY. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Mon Jan 27, 2020 9:13 pm Post subject: Re: What did you do yesterday on your buggy? |
Haus14 wrote: |
NICE BUGGY. |
The 2 piece mirrors are old style and the new long stems come as a one piece mirror now. They might work but you will have to put the left side on the right and the right on the left due to the way they are bent. That's why the 2 piece mirrors work better.
I think you can still get them at JP cycle or for that matter you could find some steel rod the correct diameter and bend and thread it. If you use stainless rod it won't rust.
I just checked JP and I don't see long stems available. I found mine at a swap meet. I always look for them when I'm there.
You could also get the new one piece style long stem mirror and cut the stem at the upper bend then use that for the old style two piece mirror.
Thanks on the buggy......it's been an obsession.... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
WMAGRU Samba Member
Joined: March 02, 2013 Posts: 28 Location: St. George, Utah
Posted: Wed Jan 29, 2020 4:53 pm Post subject: Re: What did you do yesterday on your buggy? |
I finally got around to installing the competition stripes on my Buggy.
Busted Knuckle Garage Samba Member
Joined: November 22, 2019 Posts: 71 Location: Northlawrence Ohio
Posted: Wed Jan 29, 2020 6:00 pm Post subject: Re: What did you do yesterday on your buggy? |
[quote="WMAGRU"]I finally got around to installing the competition stripes on my Buggy.
Buggy looks great! _________________ Frank |
aluk Samba Member
Joined: October 29, 2016 Posts: 67 Location: Las Vegas NV
Posted: Wed Mar 18, 2020 11:07 am Post subject: Re: What did you do yesterday on your buggy? |
Took a cruise out to Red Rock Canyon.
_________________ "It's all a matter of what you like. That's the great thing about buggies and kit cars. I'm going for a pseudo/updated/old school/semi-clean look". |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Wed Mar 25, 2020 6:11 am Post subject: Re: What did you do yesterday on your buggy? |
I replumbed my fuel filler and vent line. The PO of the buggy had vented the tank from the lower vent return port, and even with a loop of brake line cut in, it still splashed gas when cornering with a full tank. He used heater hose for the filler burp line, and it was degraded from the ethanol fuel. I ordered the stock ‘74 Beetle parts from Wolfsburg and got it back pretty close to stock configuration. Much cleaner, vents as it should, and no gas drip or smell in the garage after spirited runs.
Out with the old
In with the new |
johnnyniceguy Samba Member
Posted: Sun Mar 29, 2020 5:32 pm Post subject: Re: What did you do yesterday on your buggy? |
made and mounted front mud flaps on Sportster
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Wed Apr 08, 2020 10:01 pm Post subject: Re: What did you do yesterday on your buggy? |
Peeled of the Green vinyl-back to YELLOW!
_________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sat Apr 11, 2020 6:55 pm Post subject: Re: What did you do yesterday on your buggy? |
Yes!!!
Now I am curious... why? |
YDBD Samba Member
Posted: Sat Apr 11, 2020 9:44 pm Post subject: Re: What did you do yesterday on your buggy? |
first, I only did it to replicate what it looked like when my dad bought it in 1969 for the 50 years
second, vinyl wrap is good between 2-5 years depending on the quality of the wrap material and it's been a year and a half
third, my family preferred the yellow
fourth, I had the time and the sunshine to do it _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
oprn Samba Member
Posted: Tue Apr 14, 2020 4:28 am Post subject: Re: What did you do yesterday on your buggy? |
I did like the flowers though, have you thought about putting them back on with the yellow? |
Rengroulx Samba Member
Posted: Thu Apr 16, 2020 1:16 pm Post subject: Re: What did you do yesterday on your buggy? |
Shortened my seat frames and ran my fuel lines to both carbs (still have to be clamped)
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Thu Apr 16, 2020 6:02 pm Post subject: Re: What did you do yesterday on your buggy? |
It looks like you have some high loops in brake line(s). Air bubbles will try to collect at high points, and may be difficult to bleed out from up there. Best to try and keep them sort of horizontal as possible. By the way, I love the chrominess of that clean new engine!
Posted: Sat Apr 18, 2020 9:16 am Post subject: Re: What did you do yesterday on your buggy? |
@MrGoodtunes Thanks for the advice! I bled the brakes last week without issues however I might have to modify a few for clearence.. |
EVfun Samba Member
Posted: Mon Apr 20, 2020 7:32 am Post subject: Re: What did you do yesterday on your buggy? |
I put the steering box on, took the steering box off, painted it, put the steering box on, discovered you can't install the steering arm after installing the box (have to do it while installing the box as the lower tube is in the way on K&L cars.) So I took the steering box back off, painted the steering arm and brought it inside to dry overnight, I guess today I will put the steering box and arm on the front beam, again.
I made a few other brackets and filler panels and painted them up too, plus spring yard work and a 20 mile bicycle ride, so the time wasn't wasted, still... _________________
Wildthings wrote: |
gtrplyr Samba Member
Joined: November 10, 2014 Posts: 101 Location: kansas
Posted: Mon Apr 27, 2020 6:26 am Post subject: Re: What did you do yesterday on your buggy? |
It finally drove out of the barn under its own power.
Still have a long way to go. |
joescoolcustoms Samba Member
Posted: Mon Apr 27, 2020 8:02 am Post subject: Re: What did you do yesterday on your buggy? |
That is a good looking Lithia Mark III buggy gtrplyr! I like the wheel choice and the tire stagger. I used the RZR seats in the 4th buggy I built and found them to be really comfortable. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Apr 27, 2020 6:15 pm Post subject: Re: What did you do yesterday on your buggy? |
You, Dale and bowtie were a lot of help, even if you didn't know it! |
YDBD Samba Member
Posted: Mon Apr 27, 2020 9:57 pm Post subject: Re: What did you do yesterday on your buggy? |
Went for a cruise, decided to try the app I use for hiking, mountain biking and skiing...came out pretty cool...
https://www.relive.cc/view/vJOKX7pPk56 _________________ '56 pan Dune Buggy since '69
'67 bug
'64 baja
'60 dune buggy
Posted: Tue Apr 28, 2020 9:05 am Post subject: Re: What did you do yesterday on your buggy? |
Tuned my engine! Twas a learning curve
