Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Feb 19, 2006 2:16 pm Post subject: |
OK, I will be first.
I bought a used Clarke 100E welder at a swap meet for very cheap.
http://classicvw.org/gallery/main.php?g2_view=core.ShowItem&g2_itemId=1966
I have the welder working, but need to know how to set the current with the rocker switches.
Does anyone have a manual for this welder, that could scan the instructions, or explain to me how they work??
Thank you in advance. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
renderit Samba Member
Joined: October 09, 2005 Posts: 1155 Location: Austin, TX
Posted: Sun Feb 19, 2006 4:32 pm Post subject: |
Here's one for you. I need to take classes and all, but a friend mentioned that if I'm spending most of my time on sheet metal I'd be happier with TIG than MIG. What do you think? |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Mon Feb 20, 2006 10:14 am Post subject: |
TIG is more versatile and produces beautiful welds, but it is much more expensive - you can still do very good welding with a MIG and the equipment cost is about half ($600 for MIG compared to $1.2k for TIG)
I think TIG is for the everyday/pro welder/fabricator - MIG is for the hobbyist/DIYer _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Matt K. Paint and Body Nutcase
Joined: January 14, 2005 Posts: 2598 Location: Hemet, So Cal.
Posted: Mon Feb 20, 2006 12:00 pm Post subject: |
I agree with Mark, unless you are a fabricator that requires the specific strength and precision of a tig weld than you are better off learning on a mig. When i started welding classes, i started on a "buzz box" or arc welder and the use of torch "gas welding" then to mig and tig mig is the most widely used in both fabrication and body shop repair. _________________ This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.) |
Posted: Fri Mar 10, 2006 9:00 pm Post subject: |
A TIG is just like welding with a torch, except the heat is supplied by an arc, instead of a flame.
I love welding with a torch. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
tfitz9 Samba Member
Posted: Sun Mar 19, 2006 4:59 pm Post subject: Spot weld gun |
Bug me Video demonstrates use of a Eastwood spot welder GUN that attaches to a 110volt stick welder and is used in replacing body panels
The procedure appears simple and just right for a guy WITHOUT welding experience
Anyone have any expierence with this method? Are there other suppliers of this gun?
Comments invited |
Posted: Thu Apr 06, 2006 1:31 pm Post subject: |
Looking for a 110 mig. What is the best one out there. _________________ Tomorrow I tested the theory that cooking instant grits in the microwave makes you go back in time. |
wileysc71 Samba Member
Joined: March 13, 2005 Posts: 660 Location: Madison, AL
Posted: Tue Apr 25, 2006 7:00 am Post subject: |
renderit wrote: |
Looking for a 110 mig. What is the best one out there. |
I don't know what the heck I'm doing with it yet, but based on advice I got here.........I bought a Lincoln 135Plus (infinite controls for voltage/feed).......and I love it. Used it a couple of times for practice and gave it a go on some real body panels. Penetrats nicely w/no burn through. _________________ ~ Sean
'71 Super |
bunnytrucker Samba Member
Joined: March 29, 2006 Posts: 70 Location: Ferndale WA
Posted: Fri Apr 28, 2006 3:00 pm Post subject: |
I just got a bus and I need to do alot of rust repair. So that means alot of cutting and welding. I can weld alright but I dont know much about welders. I want something that I wont have a problem welding sheet metal with. Should I go with a 110 or 220? From what I have heard 110 seems to be better for this application. Is this true? I was thinking of getting a 110 gas option mig. But for not much more I can get a nice 220 mig. But i have had problems welding sheet medal in the past with 220 welders. I don't want to buy one and then find out that it will just burn holes. What do you think  |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Fri Apr 28, 2006 3:28 pm Post subject: |
bunnytrucker wrote: |
I'd go 220v. Make sure its infinately va. I have never had issues with doing sheet with 220. Make sure you turn down the heat. The advantage with 220 will be it is capable of welding thicker materials. If you are burning thru, try less heat. Also try moving the torch faster, as pausing is a good way to burn thru. _________________ The honey-do list put my project on hold....... |
Posted: Sat Apr 29, 2006 5:18 am Post subject: |
What Jowlz said is true. The only advantage of the 110 unit is you don't have to worry about plugins. I.e. if you want to roll it over to the neighbor's at night and weld his doors shut using his power you can do it. If you had the 220 unit you have to break in, pull the Dryer plug and do it from there. See the versatility difference? _________________ Tomorrow I tested the theory that cooking instant grits in the microwave makes you go back in time. |
rossmda Samba Member
Joined: January 27, 2003 Posts: 345 Location: Baltimore
Posted: Mon May 01, 2006 11:42 am Post subject: |
Home Depot and lowes sell lincoln mig welders. I have been using one for 4 years, flux core. Yes flux core. Just requires a little more cleanup when you complete a weld and you have to take a little more time. I also have used the gas when welding and the results are damn near the same each time, with the exception of the cleanup with a wire wheel on the flux core. Flux tends to burn ya a little more from sparks, but hey I was on a tight budget when I bought it and don't use it enough to get the bottle hookup |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Tue May 16, 2006 7:01 pm Post subject: |
If you are looking to buy a Lincoln Mig welder you are better off buying it from a welding supply store. The units sold by the welding supply stores have a higher duty cycle then the same size machine from Home Depot. The welding supply store can also help you with any problems you have.
Jerry... |
Posted: Wed May 17, 2006 11:27 am Post subject: |
lostinbaja wrote: |
Jerry... |
AND...a good store will have a demo area setup where you can try it out before you buy it. _________________ ~ Sean
'71 Super |
Posted: Mon May 22, 2006 2:35 am Post subject: |
Well I got a welder. I went with the 110 for a few reasons. The biggest reason was because the 220 welder in my price range could only handle an extra 16th over the 110 at $150 price difference. So I ended getting a Clarke 180en. Awesome welder! 10 year warranty too. Gas or no gas. It is IMO perfect for the application. I recommend it highly! Price is good too. $300 on Ebay and it came with the regulater for gas as well. |
mcatak Samba Member
Joined: January 13, 2006 Posts: 109 Location: somewhere fixin' somethin'
Posted: Sun Jun 18, 2006 2:03 pm Post subject: |
any input from here about the "low priced" Chicargo Electric 90 amp MIG welders on ebay? _________________ I couldn't afford to fix my brakes, so I made my horn louder...
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road...
Never buy a car you can't push... Authors Unknown |
Volkswagenaholic Samba Member
Joined: June 08, 2005 Posts: 846 Location: Grand Rapids, MI
Posted: Sun Jun 18, 2006 6:47 pm Post subject: |
so what welder is best for a restoration shop? a MIG? or a TIG? _________________ 1974 Superbeetle 1641cc 17.9@72mph, 1957 Ragtop, 1969 "Splash" Bug, 1966 Beetle, 1993 Corrado SLC 3.6L, 2013 BMW X3
F I S H E R W E R K E |
stancey53 Samba Member
Joined: October 05, 2005 Posts: 185 Location: Pittsburgh, Pa
Posted: Fri Jun 30, 2006 9:09 am Post subject: |
The Chicago Welders, all of them, SUCK! Harbor Freight sells a lot of Chicago Electric stuff. Its funny, I don't recall there being a Chicago in China but apparently there is as this is where these welders are made.
I bought a 220v one from Harbor Freight last fall and it didn't work. Flat out didn't work straight from the box. I called HF and they sent me a new one. Took it out of the box and, you guessed it, it didn't work. I talked to a tech support person from HF who said that it was likley a bad circuit board in each welder. They offered to send me a new board to install myself. Needless to say, I got my money back and bought a Hobart. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Jul 13, 2006 10:59 pm Post subject: |
An auto-dimming helmet (mine is a Speedglas) is an excellent investment, too. Nothing beats being able to point and weld without having to pull down your helmet or look away as you do the weld. You only get one pair of eyes...  |
