Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Mon Feb 20, 2006 11:41 pm Post subject: Since we're talking front suspension... |
71' Bus---I have some kind of odd clak* sound when I hit bumps at low to moderate speed.
I know the front end of a bus pretty well and my ball joints are tight- just had the spindles off a few weeks ago.
Anyway, hit a pothole or speedbump and I get a *clak clak* kind of dull noise. Hubs / bearings are great, lubed and solid. I jacked it up today and pried on the drag link and the center pivot- nothing. All mounting bolts tight.
It *did* get worse when I put some pretty stout KYB Gas-Adjust's on the front a week or so ago. I didn't like the mushy feel, so I went stiffer. Old shocks were fine, but softer spring. Shocks are tight obviously, bushings are new. The noise was just barely noticable before switching shocks, I mean I wouldn't even have thought twice about it. BUt now its bad enough to scare the wife.
I have a reciept for an entire front end rebuild less than 20k ago for this bus...which makes me suspicious.
What else can I look for?
'P.s. Whats the official toe-in on a bus for doing a driveway alignment? I think I set 3/16"-1/4" at 48" out from the center of the hub. But I have 7" wheels on the thing too. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
caldwell54 Samba Member
Posted: Tue Feb 21, 2006 5:55 am Post subject: |
My noise turned out to be broken torsion leaves inside the tube.
They were broken in the center where the grub screw tightens
against them. Hopefully that is not your problem.
Good Luck
Dean _________________ 1978 Dakota Beige Westy Deluxe |
GroversBus Samba Member
Joined: August 28, 2005 Posts: 59 Location: Coal Township, Pa
Posted: Tue Feb 21, 2006 6:17 am Post subject: |
Aye, same thing here, broken torsion leaves was the culpret. after i replace the front end, it went away completely as well as other obvious problems _________________ 71 Westy 1600cc "The Turtle Bus" A.K.A "Mama Pajama"
570-290-4419 |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Feb 22, 2006 12:36 am Post subject: |
caldwell54 wrote: |
Dean! Look at how they enriched your life. Maybe he needs the lessons learned! How's your bus doing?
Reverend Colin _________________ www.itinerant-air-cooled.com |
