Hella fog light bumper guard combo
Page: 1, 2, 3  Next
vwovalguy
vwovalguy is offline
PostPosted: Wed Feb 22, 2006 12:52 am    Post subject: Hella fog light bumper guard combo Reply with quote
Can anyone post some pics of these fog lights and tell me the part #'s of the guards and lights?? I will be looking at a set this weekend and need these #'s confirmed as there are different styles of each. Seems like the lights in the 2 photo's are different?
http://www.thesamba.com/vw/forum/album_page.php?pic_id=223669
http://www.thesamba.com/vw/forum/album_page.php?pic_id=75474
Any help would be great
Thanks
markm
markm is offline
PostPosted: Wed Feb 22, 2006 5:52 am    Post subject: Reply with quote
I think Chris over at L5VW had a set of those recently.
Kubel Nick
Kubel Nick is offline
PostPosted: Wed Feb 22, 2006 8:06 am    Post subject: Reply with quote
picts I have I saved from earlier:
Peter_Plade
Peter_Plade is offline
PostPosted: Wed Feb 22, 2006 11:27 pm    Post subject: Reply with quote
The red oval is mine and both the guards and lights are from Hella.
But be aware that the guards are left and right sided, they are not the same.
http://vw-bluehats.blogspot.com/
vwovalguy
PostPosted: Wed Feb 22, 2006 11:45 pm    Post subject: Reply with quote
Thanks Peter,
I was aware of that already, but can you tell me about the amber lights on the rometsch? Are they original or just a common set added to the gaurds? I need to know if they used different foglights on these and which ones are correct. Can you give me a part# of your lights?
Mike
Peter_Plade
PostPosted: Fri Feb 24, 2006 7:49 am    Post subject: Reply with quote
Hi Mike
I dont know if there diffrent sets available but assume that all HELLA
lights that fits would be correct?!
On the outside just over the glass it says: n=23cm/5m.
And on the reflector it says: Nr. 110 zh-9
That is all I can find, but there is also some numbers inside the gurds.
Evert Tersiqo
Evert Tersiqo is offline
PostPosted: Fri Jan 16, 2009 1:11 am    Post subject: Reply with quote
Hallo Guys,
Needs your help I need the fog light for my bumper guard...please help...
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Facebook Gallery Classifieds Feedback
alexwoa
alexwoa is offline
PostPosted: Fri Jan 16, 2009 2:15 pm    Post subject: hella bumper guards + lamps Reply with quote
hello,
the red rometsch's lamps are not correct.
it is selfexplaining because this are BOSCH ! lamps on hella bumper guards.
those bosch nipple lamps are very nice but not mixed with hella guards Smile)
i have a set of original hellas for the bumpers left - so if anyone needs them - please email me.
best regards
alex
tomas persson
tomas persson is offline
PostPosted: Fri Jan 16, 2009 2:48 pm    Post subject: Reply with quote
Hi Mike and Peter,
There where 2 diffrent styles available... for round or oval shaped lights. One set o guards for each type. These where made for the earlier kind of bumper too, used on split bugs also. I have a Hella catalouge from the summer of 1958, where the diffrent kinds are on pictures...
Peter, you know me... the guy with the green/white split bus at the swap meet of Bug Run. =)
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jan 16, 2009 3:47 pm    Post subject: Reply with quote
tomas persson wrote:
Hi Mike and Peter,
Good information, thanks. Cool
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Fri Jan 16, 2009 7:02 pm    Post subject: Reply with quote
What is the difference of the mounts for the round lights or the oval lights???
I own a set of these and can't imagine what would change for round lights or oval lights to mount on the top.
I can tell you that just about any small Hella light will mount on the bumper horns, Marchal fog lights will not.
Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible
Evert Tersiqo
PostPosted: Fri Jan 16, 2009 8:10 pm    Post subject: Re: hella bumper guards + lamps Reply with quote
alexwoa wrote:
hello,
best regards
alex
Sent you an email already Alex, please check...danke...
Peter_Plade
PostPosted: Sat Jan 17, 2009 12:57 am    Post subject: Reply with quote
Hi Mike and Peter,
Hello Tomas
Yes ofcourse I know you Smile
I never seen that oval shaped lights that refer to, any pictures?
The round lights are in 2 versions, most of them with a big bracket on the back for mounting. But it´s possible to change that so that they will work as they were intended on the bumber guards.
I can post pictures later if anyone interested?
tomas persson
PostPosted: Sat Jan 17, 2009 5:55 am    Post subject: Reply with quote
Here comes the pictures for you... I can translate if wanted.
[/img]
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Sat Jan 17, 2009 9:02 am    Post subject: Reply with quote
OK, now I see. Those oval shaped lights won't mount on the bumper horn brackets. The stem on those sticks straight down.
The round lights you see pictured on the bumper horn brackets have a stem that leaves the light diagonally to the rear of the light, matching up with the bumper horn bracket.
I have a small set of round Hella lights with grille guards that I will be running on my set, they fit great.
195? Project "X"
tomas persson
PostPosted: Sat Jan 17, 2009 1:19 pm    Post subject: Reply with quote
Well, I think they would. The oval lights called "128ZN-4" are made to fit the guards called "16/117", and that the "110ZN-9" (dia 110mm) and the "130ZN-9" (dia 130mm) are made to fit the guards called "16/68".
IN2VWS
IN2VWS is offline
PostPosted: Sat Jan 17, 2009 3:18 pm    Post subject: Reply with quote
To add to the information Tomas has posted, here are some pics of the 2 styles of mounts from Hella catalogs.
Here are some pics from a 1950's Happich catalog which has one style of mount, but it is for both style lamps.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
tomas persson
PostPosted: Sat Jan 17, 2009 3:28 pm    Post subject: Reply with quote
And I see that there are another size of the lamps also = 120 mm in dia.
IN2VWS
IN2VWS is offline
PostPosted: Sat Jan 17, 2009 3:38 pm    Post subject: Reply with quote
This is from a 1953 Happich catalog.
Beware, not all these mounts are for a VW. Sometimes people have sold DKW versions as VW.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
tomas persson
PostPosted: Sat Jan 17, 2009 3:46 pm    Post subject: Reply with quote
Yes. In my catalog there are for Opel Olympia 51-52, Kapitän 51, Ford Taunus 12M and 15M, Mercedes 170S and 220, Borgward and DKW.
So beware...
Page: 1, 2, 3  Next
