dok33 Samba Member
Joined: December 07, 2005 Posts: 70 Location: Austin, TX
Posted: Wed Mar 01, 2006 10:16 pm Post subject: Dok's '66 Hoodride |
Here are some pics of my '66, currently in hoodride status:
Before:
After:
updated interior pic to come
Specs:
engine: 1600dp, 12v conversion, quad tip exhaust
Tranny: Sachs clutch (now with correct pp), scat dragfast shifter
Susp: adjustable beam, 1 notch rear, 14" bus front wheel, 15" smoothies rear
Int: $5 ebay seatcovers, sunpro tach, custom cardboard radio blockoff
Ext: lots of dents and rust, og patina paint and some rustoleum, harbor freight horn:D
Plans: install t-bar bumpers, smoothie hubcaps,and stereo that are all sitting in my garage and then CRUISE
I will probably replace the rusty heater channels and 1/4s and paint it at some point, but for now I'm having a blast cruising around town scraping everything... |
sharky745 Samba Member
Joined: September 30, 2004 Posts: 182 Location: Port Orange, FL
Posted: Wed Mar 01, 2006 10:39 pm Post subject: |
Thank God you fixed that engine paint...... I was beginning to think you were a hurricanes fan gone terribly wrong. Nice lookin car _________________ "I could be wrong though." |
dok33 Samba Member
Posted: Wed Mar 01, 2006 11:23 pm Post subject: |
LOL, believe it or not that wasn't the worst thing the PO did...
Definitely not a canes fan, GO HOKIES!!!! |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Thu Mar 02, 2006 12:03 am Post subject: |
drop spindles, yo _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Mar 02, 2006 1:37 am Post subject: |
before you go speding you cash on dropped spindles or anything else get all the holes in the tin plugged up. your fan is sucking hot exhaust air and blowing it on the heads/cylinders! |
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Thu Mar 02, 2006 7:40 am Post subject: |
what is that light over the rear window for? |
dok33 Samba Member
Posted: Thu Mar 02, 2006 6:19 pm Post subject: |
Rides fine for me, no need to spend $200 on spindles. Got some plugs for the tin last night so you guys can shut up about it No idea what the light over the window is, doesn't work though.
Had some drama on the way home from work tonight, brake pedal went to the floor and I had to ebrake it and steer into the curb to avoid hitting someone Pedal was fine after that but it scared the crap outta me. Guess it needs more bleeding, I've already bled out almost 1/2 a bottle of fluid... |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Thu Mar 02, 2006 7:49 pm Post subject: |
what the heck is that on the decklid? Those 2 flat things? Too bad it wasnt completely OG green, I would roll it just like that OG paint.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
dok33 Samba Member
Posted: Thu Mar 02, 2006 8:11 pm Post subject: |
Haha, I was wondering when someone was going to notice those. They are "custom" 6x9 speaker grilles, the PO had some interesting taste
I'm going to do some hand sanding to try and blend the rustoleum into the og paint a little, we'll see how it turns out |
Skim Rants Master
Posted: Thu Mar 02, 2006 8:17 pm Post subject: |
dok33 wrote: |
WTF he had 6x9's bumping out the engine. J/K. _________________ GFK
1953 Kabriolet
1954 Sunroof
dok33 Samba Member
Posted: Thu Mar 02, 2006 9:02 pm Post subject: |
Yea, it's pretty ghetto, I need to find a better way to cover up the holes he cut into the decklid... |
Skim Rants Master
Posted: Thu Mar 02, 2006 9:15 pm Post subject: |
dok33 wrote: |
You need to get a new decklid homie. _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Thu Mar 02, 2006 9:33 pm Post subject: |
A lid should be easy to find in TX anyways. Then you can work on that rustoleum "blending" _________________ "I could be wrong though." |
