bustedtype2 Samba Member
Joined: May 07, 2005 Posts: 417 Location: The arm pit of california
Posted: Fri Mar 03, 2006 1:18 am Post subject: Bammboo tray for type 3 |
Guess what!!!
I just got my bammboo tray for my fast back today from mid america moters. Its cool but, It came with two "L" brackets w/ no screws or directions. How do you put this on? The brakets dont even have holes in them.
I called them and asked how to put it on and they had no idea and they said they dont give out directions . NICE!!!! THE PLACE I GET IT HAS NO IDEA. I DONT THINK I WOULD BY AN ENG FROM THEM! |
rusty57 Samba Member
Joined: October 21, 2003 Posts: 2089 Location: Bakersfield,CA.
Posted: Fri Mar 03, 2006 7:57 am Post subject: |
I installed the brackets with self tapping screws. Drilled a small hole through them. Put the tray over the brackets, and zip tied the tray onto the brckets. That way you don't see any of the hardware. I did it on a type 1, but the application should be fairly similar. hector
_________________ 67 Ghia coupe, Retired military.
www.TagDefender.com |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Fri Mar 03, 2006 8:14 am Post subject: |
Be carefule drilling through the carpet!!!! If the scre snags the carpet it will make an unwravel line big time. The top of the tray should hit the bottom of your steering tube. Level it from there. Put the brackets on the left and right sides for support. It is a figure it out kinda deal with these aftermarket deals. Good luck take it slow. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Mar 03, 2006 6:49 pm Post subject: |
Be careful you dont put a screw into a wire harness on the lefthand side. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
jimmynotch Samba Member
Joined: February 11, 2003 Posts: 2901 Location: sacramento
Posted: Sat Mar 04, 2006 1:06 am Post subject: |
Russ Wolfe wrote: |
Be careful you dont put a screw into a wire harness on the lefthand side. |
Ha! Did that about two years ago and eded up replacing the whole harness after a key-to-coil melt down and fire. A better way to mount your parcel tray is to use T-bolts and tension screws to hold it up. _________________ Jim in Sacto -
my wonderful loving supportive wife wrote: |
You guys are dorks. |
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2 |
Posted: Sun Mar 05, 2006 9:28 am Post subject: |
Thank you,, I will put it in today.
Now I have a better Idea. Stay cool. Hope to see all you at the Bakersfield show.
Paul |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1531 Location: L.A./Dublin, Irl
Posted: Sat May 05, 2007 4:34 pm Post subject: |
Does anyone have or can anyone take a pic of where they drilled their holes into the metal under the dash to mount one of these parcel trays? Just got one of these puppies for my T3 and although it did come with two metal brackets that wrap around the bamboo frame at its narrowest circular point, I'm just curious as to where you guys drilled your holes in the metal? I'm thinking about putting it about 10" forward from the doors near the wiring harness (on the drivers side), and an equivalent place on the passenger side. Good idea? |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat May 05, 2007 5:54 pm Post subject: |
TommyBoyGomes wrote: |
no drilling in mine - tension screws at the four corners is all... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sat May 05, 2007 5:58 pm Post subject: |
Damn, I just realized. I don't have a try in mine! _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat May 05, 2007 6:02 pm Post subject: |
Russ Wolfe wrote: |
Damn, I just realized. I don't have a try in mine! |
you have one left, don't you? _________________ póg mo thóin
Posted: Sat May 05, 2007 6:03 pm Post subject: |
...can you tell me what pre-existing holes you put the tension screws into then blank? (it's usually at this point that I'm either missing something very obvious or that I don't have holes there) |
Posted: Sat May 05, 2007 6:08 pm Post subject: |
you may not have the holes in yours, depending upon the manufacturerer; if they were there, you would have found them... _________________ póg mo thóin
Posted: Sat May 05, 2007 6:17 pm Post subject: |
Right, there aren't any holes on the tray itself. Airhead parts sent the "bamboo" (more like wicker) tray with 2 hose-clamp style brackets and two screws. The frame of the tray goes where the hose would be. On the clamp itself, there is a metal tab with a hole in it. It's through this hole that the screw goes and (I assume) screws into the metal framework behind the carpet.
So my question is, where on the metal framework beneath the dash do these screws screw into? Because I don't see any pre-existing holes in the metal. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat May 05, 2007 6:23 pm Post subject: |
You have to drill new holes. |
Posted: Sat May 05, 2007 6:36 pm Post subject: |
that's what I thought, does anyone have any pics of where they've drilled these? |
Posted: Sat May 05, 2007 6:52 pm Post subject: |
I'd follow Notchboys's directions "see above". |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Sat May 05, 2007 9:54 pm Post subject: |
Here's my standard parcel tray:
http://www.icbm.org/cmgallery/thumbnails.php?album=76
Dunno if it will help or not
Okay, I can't contain myself...here's a public sneek-peek of a li'l something-something I've created, will be sold thru the DDB, and it will be on display tomorrow at the Cruise For The Cure. Just look for my baby and Martin's roadster (roofless air-ride):
http://www.icbm.org/cmgallery/thumbnails.php?album=79
P.S. The black one in Martin's ride is the revised version. Fits '67 thru '73 and requires no drilling or other damaging methods of fastening
_________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Sun May 06, 2007 10:55 pm Post subject: |
Very interesting! Congrats on your innovativeness...
Not to belittle your creation, but are you using the original holes under the dash to mount your modern stereo or did you have to drill new ones? Did you custom make the case that it fits into as well? |
Posted: Mon May 07, 2007 3:06 pm Post subject: |
I don't remember on the stereo install, it was so long ago. My car originally belonged to my parents and Dear Ol' Dad had a CB in there at one time as well as a red emergency light (he was a volunteer fireman and EMT for a long time) to he put in holes where he needed to
As for the "case" around the stereo...I had left over orange felt when I installed the headliner so I simply wrapped the stereo in it (with appropriate holes for ventilation). Same for the orange under the three gauges where the speaker grill used to be _________________ Toby http://www.aircoolednut.com/
onerase Samba Member
Joined: January 17, 2008 Posts: 260 Location: Albuquerque, NM
Posted: Sun Oct 05, 2008 8:59 pm Post subject: |
yeah this thread is old as hell but I still dont know how to put mine in, it came with the two L brackets and a rubber ring (???), I can fit it in there, but is it secure just sitting on the brackets? I dont really want to zip tie it. And wtf is the rubber ring for? Its a total mystery to me. |
