RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Tue Mar 07, 2006 7:50 am Post subject: |
VDubMattStuart wrote: |
Well, it looks like I don't have the correct horn. It definately is a later horn. Has the raised center (like a nipple) with the pattern of small holes. It does have screw terminals though. |
Sounds like you're describing a 1960 horn. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Suboval Samba Member
Posted: Tue Mar 07, 2006 8:10 am Post subject: |
Here are some pictures of the Split flower/swirl horn:
coad Samba Scapegoat
Posted: Tue Mar 07, 2006 9:18 am Post subject: |
RareAir wrote: |
Does the exterior look like this style of horn? (excluding the Chrome finish of course)
Is that new? I'm looking for that style horn. Had one too until the airline lost the suitcase it was in. |
wolfsburgvw Samba Member
Posted: Tue Mar 07, 2006 10:06 am Post subject: |
the horn is like that black one,steve. |
VDubMattStuart Samba Member
Joined: July 10, 2005 Posts: 273 Location: Lincoln, CA
Posted: Tue Mar 07, 2006 11:13 am Post subject: |
RareAir wrote: |
Sounds like you're describing a 1960 horn. |
Looks exactly like this:
[/url] _________________ 53 oval hardtop |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Mar 07, 2006 12:52 pm Post subject: |
That horn started in the late 50s and was used through the 60s. Those are common as dirt. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Mar 07, 2006 4:59 pm Post subject: |
coad wrote: |
RareAir wrote: |
Nope, it's original. The rearbacking is Baklite and is mint! The horn came with the car I bought. The previous owner told me he had it Chrome plated to preserve it. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Tue Mar 07, 2006 5:48 pm Post subject: |
while we're on horn subject, anyone know if this is VW correct? Supposedly be off a Kubel, but Kubels are known to acquire non-factory parts over the time...
Posted: Tue Mar 07, 2006 8:35 pm Post subject: |
Haven't seen that one before Nick.
Anyone ever seent his one? It was on a really bad Hella bakelite horn. I blasted and sprayed it even though it was in horrible shape. Would love to have a good one, I think it is a real cool design.
'57 Deluxe
'56 Single Cab |
Brezelwerks Samba Member
Joined: March 17, 2003 Posts: 1421 Location: Tyngsboro, MA
Posted: Sun Mar 12, 2006 9:13 am Post subject: |
Ahh, the rare "VW" chrome horn............... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Dec 30, 2010 10:08 pm Post subject: |
Figured I would post in this thread instead of starting a new one.... perhaps there is such thing as a 12 volt split horn......
Restoring a few split horns tonight and found something kind of odd. I have two "swirl" horns, and discovered one has a small hole in the center of the face (like most I think I have ever seen), and one doesn't. And one one is a "B III 6" and one a "B III 12". Could this be a 12 volt split horn!?
I actually had them apart before I discovered the difference in the faces, and am not sure which one went with the 12 vs. the 6. The 6 volt one pulls about 20-21 amps (closed contact) and the "B III 12" about 15 amps, so it quite possibly could be a 12 volt horn. Another Hella "Mercedes sign" horn I have is also marked "B III 6" and pulls about 20 amps.
Anyone seen this before? John, God and owner of all VW literature, do you have something that lists the Hella B III 12???? Has anyone ever seen a swirl horn without the small hole in the middle??
Perhaps B III 12 is a later horn and someone just changed the face? The housing is the threaded bore kind for the 6 screws and all of the later ones had nuts and bolts I think. Also, the contacts, condenser etc. inside is virtually identical between them.
Note that the 6 volt one has brass terminal blocks and the 12volt one has plated blocks.
'57 Deluxe
'56 Single Cab |
Posted: Fri Dec 31, 2010 1:01 pm Post subject: |
Well I finished restoring the horns and the " B III 12" one doesn't seem to be able to run on 6volts, it is very feeble at that voltage no matter how tuned. At 12 volts it wails pretty good. Only thing that is odd is that it pulls about 8-9 amps when tuned, vs 4 amps for the 6 volt ones. For the same power, the amperage should be half for the 12 volt vs. the 6 volt. And it gets warm if you run it for a long time.
So it is using 108 watts of power vs. 24 for the 6 volt one. The tone and volume are about the same....... _________________ John Henry
'57 Deluxe
'56 Single Cab |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Fri Dec 31, 2010 1:23 pm Post subject: |
Interesting Mika. Of course many other vehicles used 12 volt systems in the 40s and 50s and Hella made parts for lots of cars. Same with the star coils, everyone assumes they are all 6 volts (and "KDF!" split VW parts when selling them).
I have the brown body for the Mercedes sign one who's cover is seen in the pic and it is a "B III 6". I think that style preceded the swirl design. _________________ John Henry
'57 Deluxe
'56 Single Cab |
rlegg Samba Member
Posted: Fri Oct 04, 2013 10:56 am Post subject: |
Sorry to dig up an old post.
How often do swirl horns (6v) come up? The K-N has is sold, and B III 12 so by the sounds of it 12v.
I have a swirl horn on my 11G, but the back is real badly damaged and no longer works, it also has the original big horn cover. I've never seen another of those on a car.
Rich _________________ Click to view image |
Posted: Fri Oct 04, 2013 3:51 pm Post subject: |
They are definitely getting pretty rare. I used to see them for sale in the $100-$150 range fairly frequently, but I don't remember the last time I saw one. I don't think I even saw one at Hessisch this last June. If you need one and something comes up, it is one of those parts you better grab no matter how much it is.
Rich, you might be able to use the back from a B 30 6. I have one here and from the back it looks nearly identical, I'm sure the cover would fit. Somewhere here there is a pic of the B 30, I don't think it was ever uses on VWs... _________________ John Henry
'57 Deluxe
'56 Single Cab |
lzamora Samba Member
Joined: October 24, 2009 Posts: 109 Location: Torrance CA
Posted: Fri Oct 04, 2013 4:47 pm Post subject: |
How about this horn? |
Posted: Fri Oct 04, 2013 7:41 pm Post subject: |
lzamora wrote: |
Don't believe that horn was ever used on VWs. Not ovals and splits anyway.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
