bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Fri May 04, 2018 1:49 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
Thanks!
I had them powder coated, and that was one of the options. I don't recall the exact name, but I picked it because it matches the coating that Chris at T3 puts on his front anti sway bar.
shagginwagon83 wrote: |
bajaleo - What kind of coating is that to your spindle? It looks really nice
_________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed May 09, 2018 8:04 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Can anyone recommend a SS brake hose that works with G60 caliper conversions? |
Posted: Wed May 09, 2018 11:03 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Steve Arndt wrote: |
I got mine from Burley. _________________ Leo in San Juan Capistrano
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Wed May 09, 2018 2:10 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
I just purchased a set of Epytec adapters. Hopefully I can squeeze things in and clear my CLK wheels. They are made to work with 312x25 Passat rotors. |
I have Epytec adapter and 312x25 Audi brakes on my syncro. Audi Ate57 calipers and the 7x16 et33 version of the CLK wheels. No clearance issues at all. But my Ronal R9 7x6 et23 did not fit. _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Wed May 09, 2018 2:24 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
OddN wrote: |
I have Epytec adapter and 312x25 Audi brakes on my syncro. Audi Ate57 calipers and the 7x16 et33 version of the CLK wheels. No clearance issues at all. But my Ronal R9 7x6 et23 did not fit. |
The only unknown is the Epytec description specifies G57 calipers. I don't know anybody that has tried G60 with them. From the drawings I've pulled up and snippets of info I've found the G57 and G60 caliper mount spacing is the same. I will report my findings.
What brake lines did you use OddN?
s |
Posted: Wed May 09, 2018 2:26 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
I went with EBC premium British slotted rotors and Hawk ceramic high end pads hopefully it all fits up and works so well it stops on a dime and gives me change back. |
OddN Samba Member
Posted: Wed May 09, 2018 2:35 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
OddN wrote: |
s |
I really don't remember what brake lines i used. But I think it was someting from a BMW. Found the tip somewhere online but don't remember where. Sorry. _________________ 1991 VW Multivan syncro 1,9 TD |
baltik Samba Member
Posted: Sat Jun 09, 2018 8:02 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
So based on my initial measurements the outside edge of the Girling 60 mounting holes is 1/8” wider than the OEM carriers. Not surprisingly this does not make for a perfectly round hole. Want to make sure my experience is consistent with others and these are safe to use
Original measurement
Final outcome
dkoesyncro Samba Member
Posted: Sat Jun 09, 2018 8:20 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
You're on the right track! |
baltik Samba Member
Posted: Mon Jul 09, 2018 12:37 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Finally got this done today,
I used 19-B989/19-B988 remanufactured brakes. Got the holes machined to spec, and sourced all the spacers/hardware at fastenal
I was able to fit 388mm rotors without having to clearance the mounting bracket, very happy about that.
One thing that I'm not that happy about is the whole flex line to hard-line business. Has anyone been able to source a custom 10x1mm braided line with a male fitting on one end and a female fitting on the other end? seems like it would need to be approx. 20" long... |
Posted: Mon Jul 09, 2018 1:09 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
In my collecting, some castings are cleaner than others where the rotor comes through the carrier, the caliper itself fits larger rotors with out mods.
I have lines that fit all the way to the frame connection, a local supplier has them. If you have a hydraulic hose shop near you they should be able to help you out!
What was the cost of the remanufactured Girling set? |
Posted: Mon Jul 09, 2018 1:10 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
baltik Samba Member
Posted: Mon Jul 09, 2018 2:36 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
Thanks for all of your help on this project btw, I ended up spending $180 for the remanufactured pair.
The custom brake line that you are using - do you happen to know the length? are you using banjo fittings or standard metric? any photos you may have of how they are attached at the caliper as well as how they are retained from rubbing on the wheel would be super helpful |
Posted: Tue Jul 10, 2018 4:25 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
baltik wrote: |
I got these brake lines from Burley. I put some plastic split loom over them to protect them.
elizer Samba Member
Joined: May 02, 2016 Posts: 1469 Location: Northern Virginia
Posted: Tue Jul 10, 2018 5:25 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
The braided lines are protection themselves what's the reasoning for the plastic ? Not being a dick but I have the same lines ans want to know if I'm missing something |
Posted: Tue Jul 10, 2018 6:17 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
elizer wrote: |
I wanted to be able to see if there was any rubbing going on without actually rubbing on the brake lines themselves. _________________ Leo in San Juan Capistrano
Posted: Tue Jul 10, 2018 6:54 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
baltik wrote: |
I believe 20" and its a standard metric line, no banjos!
It looks similar to the burley line that bajelo posted. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jul 10, 2018 7:19 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
baltik wrote: |
Two questions:
Where did you source the calipers?
Did you mean 288mm rotors? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Tue Jul 10, 2018 7:32 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
So the Burley line fits it sounds like. I asked him and he said he wasn't sure. _________________ Steve
Steve's 87 Syncro project |
