dkoesyncro Samba Member
Posted: Tue Jul 10, 2018 8:49 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
dkoesyncro wrote: |
baltik wrote: |
Thanks for all of your help on this project btw, I ended up spending $180 for the remanufactured pair.
The custom brake line that you are using - do you happen to know the length? are you using banjo fittings or standard metric? any photos you may have of how they are attached at the caliper as well as how they are retained from rubbing on the wheel would be super helpful |
I believe 20" and its a standard metric line, no banjos!
It looks similar to the burley line that bajelo posted. |
This pic is the best I've got!
baltik Samba Member
Posted: Tue Jul 10, 2018 9:33 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Hmm it almost looks like Burley is using a standard Female/Female line with some sort of adapter as opposed to a custom line? |
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Tue Jul 10, 2018 9:42 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
baltik wrote: |
Not sure what you mean by adapter. It's just a brake line with a male thread on both ends. _________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
baltik Samba Member
Posted: Tue Jul 17, 2018 6:13 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
Finally connected my brakes with the custom hose, eliminating the hard-line, much better brake feel around town. I got an extra set as well in case anyone needs one
https://www.thesamba.com/vw/classifieds/detail.php?id=2194614 |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed Jul 18, 2018 8:10 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Do you have a syncro or 2wd? I don't know the length I need yet but I'll take them if you know they work on a syncro at full droop. _________________ Steve
Steve's 87 Syncro project |
baltik Samba Member
Posted: Wed Jul 18, 2018 8:19 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Steve Arndt wrote: |
Do you have a syncro or 2wd? I don't know the length I need yet but I'll take them if you know they work on a syncro at full droop. |
They work at full drop but it's close - I've been cautioned that there is variation in where the hardline to the master cylinder is mounted on diifferent syncros so I would measure to make sure |
burleymotorsports Samba Member
Posted: Sat Jul 21, 2018 7:51 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
bajaleo wrote: |
baltik wrote: |
I got these brake lines from Burley. I put some plastic split loom over them to protect them.
From looking at your pic , I would suggest a drilling a 6 mm hole to allow use of a cushion clamp to hold the hose to a sweet spot on the side of the upper control arm.
The new BMS billet aluminum upper arms feature a threaded hole on the bottom for this clamp for use with the BMS front brake kit. _________________ Protect your investment !
Buy only genuine Burley Motorsports products
I will not see your PM.
Please email us directly through our website at http://www.burleymotorsports.net . Thank you.
Web: http://www.burleymotorsports.net
Facebook: http://www.facebook.com/burleymotorsports
Instagram: http://www.instagram.com/burleymotorsports |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Sat Jul 28, 2018 6:58 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
Hey All,
A little background. I bought the Small Car G60 kit and paid $120 extra for their stainless lines. These require reuse of the short piece of hardline. They don't provide a bracket and I didn't care for the loop. My advice for potential Small Car brake consumers is to save your money on the brake lines and source them yourself.
Here is what I came up with for brake line. I bought a pair of Wilwood stainless flex line (part number 220-6861). These are 20" long and seem to be a perfect fit for my Syncro. These lines require an adapter for the G60 caliper. I found a set at Pegasus Auto Racing (part number 3265-16). The adapters and flex lines cost me $80.96 plus shipping. The flex lines have a clear plastic cover over the stainless braid for extra protection.
I have not fit the wheels yet. I don't think there will be a problem. I'm also using cushion clamps on the back side of the spindle.
Here are a couple of photos.
I hope this helps. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
pechaaa Samba Member
Joined: July 05, 2017 Posts: 38 Location: Europe, Latvia
Posted: Fri Aug 23, 2019 1:57 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
What size wheels/rims can you put on with this setup? |
UngaWunga Samba Member
Posted: Sun Feb 02, 2020 8:18 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Bump an old but helpful thread with more info from another site:
The girling g60 can be found from:
1989-1991 Audi 200 turbo quattro,
1992-1994 Audi turbo quattro,
1990-1994 Audi V8,
1992-1994 Audi 100 V6,
1987-1988 Audi 5000 quattro turbo,
1984-1988 Audi 5000 turbo,
1993-1995 Audi 90 V6 |
vwpascal Samba Member
Joined: July 28, 2011 Posts: 66 Location: Northern New Jersey
Posted: Wed Apr 22, 2020 10:53 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
reviving an old thread. if anyone out there noticed there are two rubber brake lines on the rear disc brakes from smallcar? I changed the main rubber line from the frame to the rear traling arm, checked the bleeder screw and notice another rubber brake line. Anyone out there know what stainless metal brake hose is compatible? The end away from the caliper attaching to the metal brake line in between has a larger end on it then the side that attaches to the caliper. If that makes any sense? _________________ 1984 Westfalia Vanagon 2.3 liter gowesty waterboxer |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Wed Apr 22, 2020 11:52 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
If I recall correctly it's a VW Beetle brakeline (female/male) that I sourced from CiP1. |
Posted: Wed Apr 22, 2020 12:23 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
wesitarz wrote: |
You are correct on that.
Really the correct way is to make one lone braided stanless hose that goes from the hard line on the van to the caliper. Its silly to have all those hoses and pipes daisy chained together. I guess it wouldn't matter if it was under your kitchen sink but on a vehicle you want the least amount of connections. _________________ Protect your investment !
Posted: Wed Apr 22, 2020 10:42 pm Post subject: Re: Disc Brake Conversion.... Audi parts? |
thanks fellas, I like the idea of one long line instead of all those connections. i'll have to do some measuring to get the right length hose. _________________ 1984 Westfalia Vanagon 2.3 liter gowesty waterboxer |
Posted: Thu Apr 23, 2020 6:38 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
Got up under there and measured. it's about 32 inches from the trailing arm connection to the caliper connection to go to the frame would ad another 6 to 8 inches. It's looking like I'd have to order up a custom length stainless hose if I wanna get rid of the caliper hard line connection. I found a 31inch hose with an m12 inlet from wilwood of course I need an m10. May order bulk hose and crimp myself. Has anyone ordered the bulk ptfe stainless brake line from pegasus? I'm sure it's quality just curious. Leaving the connection and just going with the available hose would be way easier but whats the fun in that right? _________________ 1984 Westfalia Vanagon 2.3 liter gowesty waterboxer |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Thu Apr 23, 2020 9:31 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
What could go wrong? Used a high speed end mill to plunge cut on my drillpress. Ain't perfect, but it'll work
Old and new match right up
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Fri Apr 24, 2020 7:42 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
UngaWunga wrote: |
Nice! What is the correct name for the bit, if a guy was shopping? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
4Gears4Tires Samba Member
Posted: Fri Apr 24, 2020 9:49 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
https://en.wikipedia.org/wiki/End_mill _________________ '87 Syncro
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Fri Apr 24, 2020 11:51 am Post subject: Re: Disc Brake Conversion.... Audi parts? |
I got my stainless lines made at Paragon performance. They deal with many high end race cars so it was a natural choice. I've successfully worked with them multiple times with custom lines and fittings.
I have been known to mingle in 80's Audi's and had a spare line from a 4000 around. They have the correct end fittings for G60 conversions on Vanagons but are too short. No worries, just call them up and have them make some Audi 4000 front lines 19 inches long.
My 2wd is sitting at 17.5" from center of wheel to fender lip, and a19" length works great. Adjust accordingly.
They work great, are high quality (DOT compliant and pressure tested-report included), and Paragon is effortless to work with.
