Clara Samba Member
Posted: Thu Mar 29, 2018 1:07 pm Post subject: Re: Official good deal on Buses or parts topic |
D-train wrote: |
zuggbug wrote: |
I was stoked to say the least! Here’s the rest.
And this panel. I don’t need it obviously! Haha
Score!
What happened to the RHD PG/SG bus and the RHD outie vent turkis bus they got the interiors from?
Are you in Australia? |
EmpiGT Samba Member
Posted: Thu Mar 29, 2018 2:09 pm Post subject: Re: Official good deal on Buses or parts topic |
So Clara how do you know the long panel came from an outie vent, different skrew pattern??? Lol |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Thu Mar 29, 2018 9:01 pm Post subject: Re: Official good deal on Buses or parts topic |
EmpiGT wrote: |
Trim length? _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Clara Samba Member
Posted: Fri Mar 30, 2018 7:13 am Post subject: Re: Official good deal on Buses or parts topic |
The back edge.
outie:
innie:
You can fit a early panel into a late bus and vice versa, the back edge won't line up with where it should screw in.
It means that late 63s with innie vents have unique lower and upper corner panels.
This also means there are three versions of "a 63 interior panels set" for a microbus. |
EmpiGT Samba Member
Posted: Fri Mar 30, 2018 9:52 am Post subject: Re: Official good deal on Buses or parts topic |
Wow learned something new. Never noticed the angle cut like that on early interior panels. |
srfndoc Samba Member
Posted: Sat Mar 31, 2018 8:55 am Post subject: Re: Official good deal on Buses or parts topic |
This seems like a good deal for a solid Westy with an interesting history. Typical setup for a German delivered Westy: two tone paint, steering lock, no jalousie windows, no port code/Westy Code (or Westy VIN code) but does have special paint code.
https://www.thesamba.com/vw/classifieds/detail.php?id=1936297
Has the early cooler (whale pump), spare tire setup removed for Eberspacher (which its mcoded for), also ordered with belly pans. Has a few issues but still a solid deal. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Apr 02, 2018 7:23 am Post subject: Re: Official good deal on Buses or parts topic |
There's no need to remove the spare tire well for an eberspacher VW never did that.
srfndoc wrote: |
Has the early cooler (whale pump), spare tire setup removed for Eberspacher (which its mcoded for), also ordered with belly pans. Has a few issues but still a solid deal. |
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Clara Samba Member
Posted: Mon Apr 02, 2018 8:16 am Post subject: Re: Official good deal on Buses or parts topic |
crofty wrote: |
srfndoc wrote: |
True. Maybe someone wanted a wider bed.
Dual carbs don't fit with an Eberspacher I've heard. |
Posted: Mon Apr 02, 2018 9:24 am Post subject: Re: Official good deal on Buses or parts topic |
Clara wrote: |
crofty wrote: |
srfndoc wrote: |
My bad, I was thinking of the Stewart Warner heater setup which requires the spare tire removal.
Bed appears to be the same width although the rear pad has been extended.
Skim Rants Master
Posted: Mon Apr 02, 2018 9:59 am Post subject: Re: Official good deal on Buses or parts topic |
Is there any pics of the outside of the bus _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Mon Apr 02, 2018 10:37 am Post subject: Re: Official good deal on Buses or parts topic |
Skim wrote: |
Is there any pics of the outside of the bus |
No good side shots for sure. Based on the description in the last photo it sounds like he had some recent metal work done and the outside resprayed with new pics coming. He should post some underneath photos as well or provide a link to more shots. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Mon Apr 02, 2018 10:40 am Post subject: Re: Official good deal on Buses or parts topic |
Skim wrote: |
Just of the nose and rear.
A little stuffy to camp in with all stationary windows. _________________ Your Vanagon sucks, Stop waving at me.
Braukuche Samba Member
Posted: Tue Apr 03, 2018 1:32 pm Post subject: Re: Official good deal on Buses or parts topic |
Clara wrote: |
crofty wrote: |
srfndoc wrote: |
Trust me they don't. You have to run a single carb. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
velvetgreen Samba Member
Posted: Wed Apr 04, 2018 7:29 am Post subject: Re: Official good deal on Buses or parts topic |
Yep, his bed hinges must be broke so they don't click to hold upright.
That 62' Flipseat is definitely cheaper but I see zero left of the actual Westy kit including the flipseat itself and the arms. It would take a grip of money and a ton of luck to find all that stuff. Probably a prime candidate for a repro kit with some kind of swivel seat mod. Still a cool starting point. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Wed Apr 04, 2018 7:54 am Post subject: Re: Official good deal on Buses or parts topic |
Id think, and this is conservative, that you're looking at close to $9k just to get the kit, tent, and front seat for that bus. If you wanted it complete then there's another $5k for the little stuff.
srfndoc wrote: |
That 62' Flipseat is definitely cheaper but I see zero left of the actual Westy kit including the flipseat itself and the arms. It would take a grip of money and a ton of luck to find all that stuff. Probably a prime candidate for a repro kit with some kind of swivel seat mod. Still a cool starting point. |
otahuhu Samba Member
Posted: Sat Apr 07, 2018 7:57 pm Post subject: Re: Official good deal on Buses or parts topic |
crofty wrote: |
Id think, and this is conservative, that you're looking at close to $9k just to get the kit, tent, and front seat for that bus. If you wanted it complete then there's another $5k for the little stuff. |
5k for an original chair, Mauser bowl, toilet, shot glasses, chandelier, 3x hunnersdorf water jugs, subhatch rack and clamps, sisal mat, 3x sprung rear mattresses, wood panels, green cot, bottle rack, fridge- ice-tray and shelves, hardware etc... its 1k just for the repro fabric to redo the curtains. And an original chair if one ever came up for sale could potentially be 5k alone... |
nineteensixtyfiveVG Samba Member
Joined: August 03, 2009 Posts: 456 Location: San Diego
AS350driver Samba Member
Posted: Thu Apr 12, 2018 7:18 am Post subject: Re: Official good deal on Buses or parts topic |
Linda, are you watching? Here's your 56. |
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Thu Apr 12, 2018 8:10 am Post subject: Re: Official good deal on Buses or parts topic |
Shouldn't last long IMO... _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
