hlwimmer Samba Member
Joined: May 29, 2002 Posts: 533 Location: concord, calif.
Posted: Sun Mar 12, 2006 8:41 am Post subject: sumps and crankcase pressure... |
2 questions really, but intertwined (so, 3).
1: sumps and pressure... does a small sump effect crancase pressure one way or another?
2: other ways to reduce cranckase pressure... vented valve covers? more breathing? i have a OG 356C breather vented to the carbs -- no downdraft tube, which might be a good add... (engine = mild-1776)
3: thoughts on sumps... i'm looking for a small, low-profile sump (1.5 - 2 quarts). thoughts on good ones? the wide-glide sump with filter was looking good: http://cbperformance.com/catalog.asp?ProductID=198 ... anyone else other than empi, CB and GBE? especially if they could use the stock drain plate. oldschool styling would be cool (but they're fairly unchanged through the years, no?) |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sun Mar 12, 2006 9:05 am Post subject: |
Hmmm...your engine looks familiar. Was your car at Volks Authority when Ray's shop was open before he closed shop? _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Posted: Sun Mar 12, 2006 9:20 am Post subject: |
yep. ray built the motor. since then, i've had to swap to a larger genny (38amp GR17) after burning up five 25amp 356 ones (ouch). the switch to a 12V stand necessitated a new porsche breather (different angle and offset). the new breather does not have a downdraft tube, which might be adding to the oil leak woes -- but does have a larger carb breather line (might have to add the downdraft tube, but would rather not if i could avoid it). additional oil, especially with more filtration might be nice, too. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sun Mar 12, 2006 9:59 am Post subject: Re: sumps and crankcase pressure... |
hlwimmer wrote: |
thoughts on sumps... i'm looking for a small, low-profile sump (1.5 - 2 quarts). thoughts on good ones? oldschool styling would be cool (but they're fairly unchanged through the years, no?) |
There are several old-school sumps 4-sale. They all used the same mold, but changed the logo. DDS & Race Trim etc... all used the same mold. These sell for about $40-$50 without a logo. I believe Dave Mayes (Oregon) has a pair available for $75/pr And they use the oem sump plate. Otherwise, Berg would be the only sump I'd consider.
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
