?Waldo? Samba Member
Posted: Wed Jun 01, 2011 1:51 pm Post subject: |
BoneStock67 wrote: |
So I will try the Libby mod, although it pains me a little to drill into even a peripheral part of the van. |
That's kinda funny. I cut big holes without pain. I wouldn't ever even give a second thought to drilling into an already ruined part (that was a very poor design to start with) in order to make it usable again. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Jun 01, 2011 2:09 pm Post subject: |
fortunately for me, I didn't have to do a drill and pin. I kept the mirror in the house (really missed having it on that passenger side tho) and I just kept soaking and scraping over and over again and tried various other fixes but finally got it out and back together correctly and it seems okay but haven't really tested it at high speeds yet. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
BoneStock67 Samba Member
Joined: January 27, 2006 Posts: 439 Location: New Jersey
Posted: Thu Jun 02, 2011 4:17 am Post subject: |
I admit that part of my problem here is that I don't have confidence that I won't drill slightly off-center and miss the hexagonal shaft. I'm sure it will look easier once I put the part on the drill press, but if you (Andrew or anybody else) have any further tips, please post. _________________ 1986 Wolfsburg Westfalia Weekender 2.1L stock
1967 Beetle, now becoming my daily driver again, after a long rest in the garage
"There are two possible outcomes: if the result confirms the hypothesis, then you've made a measurement. If the result is contrary to the hypothesis, then you've made a discovery.” -Enrico Fermi |
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Fri Jun 03, 2011 10:26 am Post subject: |
i found that it was pretty easy to eyeball where to drill the hole to hit the center shaft. i aimed it so that it would contact one of the flat faces of the hexagon.
and, not having access to a drill press, i did mine with a hand drill...didn't work so well. but, i now have 2 broken drill bits holding my mirror together. didn't even have to use a pin! _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
Posted: Fri Jun 03, 2011 10:53 am Post subject: |
OK, I'm going to have to admit here that yesterday I ordered two new Hagus mirrors from Bus Depot. I figured that my current mirrors were most likely aftermarket anyway, so at $30 per mirror, it just seemed ... well ... easier.
I'm so ashamed. _________________ 1986 Wolfsburg Westfalia Weekender 2.1L stock
Posted: Fri Jun 03, 2011 11:01 am Post subject: |
Feel no shame. Now that you have replacements and nothing to lose, why not give drilling and pinning a try? Now that the risk is gone it might be a fun learning experience with the potential bonus of a usable spare. |
DAIZEE Samba Member
Posted: Fri Jun 03, 2011 11:37 am Post subject: |
Don't be ashamed. You tried and like Libby says practise on the old, good opportunity cause they all get floppy at some stage _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Tue Sep 06, 2011 12:47 pm Post subject: |
Here's an update on my new BusDepot Hagus mirrors.
1. Both were floppy out of the box.
2. So, I decided to add the rubber washers to both.
3. When I got the driver's side mirror disassembled, I noticed that the mating surfaces on the ball joint looked pretty rubber washery already (as opposed to the surfaces on the older mirrors that I replaced).
4. After rubber washerizing the driver's side mirror and tightening down the nut, I decided to do a little experiment and tighten the nut on the passenger's side mirror without adding the rubber washer.
5. On the highway yesterday, the passenger's side mirror held firm, while the driver's side flopped.
Tentative conclusion: Newer mirrors don't benefit from rubber washers.
Caution: I'm not sure I torqued the nuts on the two mirrors the same amount, so it's not a very fair experiment.
Additional comment: The more I think about it, the more I believe that the added material should be rough, which a rubber washer surely is not. On a thread on the vanagon mailing list today, someone said something similar, claiming good results by adding emory paper, rather than a rubber washer.
Comments? _________________ 1986 Wolfsburg Westfalia Weekender 2.1L stock
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 492 Location: PORTLAND ORE
Posted: Thu Sep 08, 2011 9:09 am Post subject: |
thank you for this thread going to ace hardware to get the washers.thought i would have to replace mirrors. _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Thu Sep 08, 2011 10:11 am Post subject: |
yeah, I would have never searched for this, haha |
Posted: Thu Sep 08, 2011 12:54 pm Post subject: |
ace hardware washers $.43 each and 10 minutes.thanks again _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Sep 08, 2011 7:36 pm Post subject: |
I finally gave up on the washer fix & just sprung for the new GW
"No Flop" Side-view Mirrors - currently just $32 each ($5 off this month).
LINK: GoWesty "No Flop" Side-view Mirrors
I was an early convert to the washer fix (cheap & effective), but it's gotten to
where I've had to replace them every month all summer & I've decided I'm
done with it. Not a long-term solution for me - sorry, I tried.
I'll report on the GW version - should be here early next week. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Thu Sep 08, 2011 7:41 pm Post subject: |
Awe, bummer.
Ill use this fix till I get my truck mirrors. |
jimeg Samba Member
Posted: Thu Sep 08, 2011 9:47 pm Post subject: |
dhaavers wrote: |
I'll report on the GW version - should be here early next week. |
I'd like to know what their "modification" is.
This manually adjustable mirror is made in Germany [Hagus], and is modified here at GoWesty to eliminate the "flop" that can occur at highway speeds. It also includes metric mounting screws and base gasket. _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490 |
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Fri Sep 09, 2011 5:52 am Post subject: |
I "modified" my original mirrors on my 85 with emery cloth. I cut butterfly washers so as to fit on the rounded surface out of 320 grit emery cloth. I have to replace about every 3 years. Works great. |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Fri Sep 09, 2011 6:12 am Post subject: |
indytriple wrote: |
On the off chance some of you cyclists out there have some carbon fiber assembly paste/gel:
http://www.finishlineusa.com/products/fiber_grip.htm
It fixed my floppy mirror syndrom pronto. I took the mirror apart and put a healthy dose of it where the ball and socket surfaces meet Been going strong for over six months now. |
Update:
It's been over a year and a half now, and the carbon fiber assembly gel is still going strong even after lots of rain and car washes. Available at your friendly local bike shop. Good for any surface where you want/need lots of grip with reduced torque. There are lots of good brands. Tacx is another good one. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
Posted: Fri Sep 09, 2011 7:51 am Post subject: |
Indytriple's carbon fiber gel solution sounds very promising. I will definitely give that a try. Thanks!
Heidi85Ho's emery cloth idea is also interesting, but I have two questions:
1. Don't you need double-sided emery cloth to make it work as intended?
2. What the heck is a butterfly washer? _________________ 1986 Wolfsburg Westfalia Weekender 2.1L stock
Posted: Sat Sep 10, 2011 6:49 am Post subject: |
I should mench:
Another reason I'm ditching my original mirrors is that one has a cracked
housing & the other a cracked mirror - probably due to all the FREAK-ing
flopping over the years...
I'd love to, but I just can't put the money into LT or power upgrades...so
GoWesty came along with the <next> cheapest option.
We'll see... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
DAIZEE Samba Member
Posted: Sun Sep 11, 2011 6:18 am Post subject: |
Well all my work on the passenger mirror seemed to be for naught! It still flopped. Then at my first meet Ed from Conneticut took it off and ratched it tighter (lots tighter) so the fix was in and now holds really well. I've got to get used to ratchetting as I don't have much strength for regular wrenching it would seem. But I was darn proud of my work in preparing for a tight ratchett. Thanks Ed. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Mon Sep 12, 2011 8:45 am Post subject: |
753 miles last week with the washers no floppy mirror.so far so good.would like to hear if those gowesty mirrors work _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
