dragonfire709 Samba Member
Joined: July 13, 2005 Posts: 154 Location: Hampshire, UK
Posted: Sat Mar 18, 2006 10:49 am Post subject: Urgent Help!! |
Help!!
We have just got halfway through a Westy canvas transplant but the canvas does not seem to be large enough and wont stretch to the back drivers corner! What have we done wrong?!?!?! |
Randy in Maine Samba Member
Posted: Sat Mar 18, 2006 11:06 am Post subject: |
What year of van and where did you buy it? |
Posted: Sat Mar 18, 2006 12:32 pm Post subject: |
Its an 86 Westy Weekender and the roof came from Just Kamoers in the UK. Its the right roof according to the invoice and the label on the box, but it seems to be anout 10-20cms too small!
Paintedbus Samba Member
Joined: September 14, 2003 Posts: 679 Location: salem, ma
Posted: Sat Mar 18, 2006 12:41 pm Post subject: |
i had a similar problem to this. mine was at least 3 inches short! luckily i have a lot of experiance in stretching canvas as i am in art school
what i did was get help from my dad. he screwed the bracket thing on while i pulled the canvas tight. another pointer (i know you dont want to hear this) is to start over. start from the front center and work your way all the way around one screw at a time. each time pull the canvas as tight as you possibly can before screwing it in place. this will wear you out after a couple of hours, but it is certianly worth it when you have a nice taught canvas. after you get done, spray it with water and let it dry in the sun to get the wrinkles out. _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
WWW.PAINTEDBUSART.COM |
r39o Samba Polizei
Posted: Sat Mar 18, 2006 12:46 pm Post subject: |
Heat from steam helps too, just like the pros do. I am dreading doing mine, but someday I must. Your directions should help. Everybody needs to know such tricks. For some reason, the Vanagon stuff is not so well documented like others.
Well back to my brake upgrading.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Mar 18, 2006 3:02 pm Post subject: |
Are you trying to put it on with the top all the way up?
That's the biggest mistake.......
Put something like a chair on the upper bunk. |
Posted: Sat Mar 18, 2006 5:44 pm Post subject: |
Thanks for all your input. Levi, we started by getting the front top all lined up and screwed in. then we started on the sides. as we got to the back we found we had lost about 10cms!
Our plan is to undo the sides and try to locate the middle of the rear and then try again![/url] |
Posted: Mon Mar 20, 2006 8:52 am Post subject: |
OK-hopefully problem solved. We tried again to reinstall the top on Sunday, and couldnt make the corners of the canvas stretch to where they needed to go.
Popped back over to the supplier, and behold! The canvas was too small! Have now been supplied with one that seems to be the right size, and we're now going to try and install during the evenings this week.
And we thought we were going mad!! |
