NASkeet Samba Member
Joined: April 29, 2006 Posts: 2947 Location: South Benfleet, Essex, UK
Posted: Tue Mar 27, 2018 8:11 am Post subject: Re: The Tire Sticky FAQ |
vwwestyman wrote: |
xyzzy wrote: |
So what's the latest in terms of best tires for Bays?
BFG ATs: Gone.
General Grabber ATs: Only downside is they're a little wider, and the spare wont fit in the usual spot because of the increased width?
Hankook RA18: New version of the RA08. Good price, good tire.
Goodyear Tires Wrangler AT LT195/75R14: Is anyone running these? They look very comparable to the old BFGs.. Money aside, these seem like they'd be a better fit for the Bus than the Grabbers, while till having that offroad footprint, right? |
Grabbers are also taller, so that too would likely prevent them from going in most stock spare tire locations. |
So far as spare-tyre storage is concerned, it might be preferable to continue discussions in the following topic thread, to avoid them being submerged in the hundreds or thousands of general tyre related discussions.
Forum Index > Bay Window Bus > Largest tyre sizes, to fit rear spare-wheel well?
https://www.thesamba.com/vw/forum/viewtopic.php?t=251940
Based upon the tyres section-widths & aspect-ratios, the factory-stock 185/80 R14 tyres and proposed replacement 195/75 R14 tyres, have virtually the same external radius to within 2 mm; the replacement wider, lower-profile tyre, being slightly smaller by 055%.
195/75 R14 tyres 3240 mm predicted external radius
185/80 R14 tyres 3258 mm predicted external radius
Having similar concerns about alternative tyres (i.e. 65-Series light-truck tyres, for 7 x 16 inch Mercedes wheels), I recently measured the engine-deck spare-wheel well of my 1973 VW 1600 Type 2 Westfalia Continental campervan.
I tried for size, one of my recently acquired Mercedes C-Class 7J x 16 inch wheels with 205/55 R16 tyres. It would NOT fit! According to my measurement with a metric tape measure, the spare-wheel well is 214 mm (i.e. 165 mm + 49 mm) wide, so I was a little surprised that a Mercedes C-Class 7J x 16 inch wheel with 205/55 R16 tyre didnt fit!?!
I have used a mathematical circle-theorem pertaining to intersecting chords of a circle, to determine the radius of curvature of the spare-wheel well, which to a close approximation, is probably part of a circular cross-section.
According to the theorem, if two chords AB and CD intersect at a point E inside or outside the circle, then the product of lengths AE x EB = CE x ED.
If I measure lengthwise horizontally across the spare-wheel well (i.e. 630 mm), this will give chord-length AB via mid-point E, such that AE = EB = ½ x 630 mm = 315 mm.
Measuring vertically downward from mid-point E, to the bottom of the wheel well at point C, gives the length CE (i.e. 194 mm) forming part of chord CD = CE + ED, which is a diameter of the circle; recalling that a radius or diameter bisects a chord at a right angle.
Manipulation of the theorem relationship gives ED = AE x EB / CE. Substitution gives the wheel-well diameter CD = CE + ED = CE + AE x EB / CE.
Hence, spare-wheel-well diameter (i.e. twice the radius of curvature) CD = 194 + 315 x 315 / 194 = 705 mm
185/80 R14C tyre predicted external diameter = 652 mm
195/75 R14C tyre predicted external diameter = 648 mm
195/65 R16C tyre predicted external diameter = 660 mm
205/65 R16C tyre predicted external diameter = 673 mm
215/65 R16C tyre predicted external diameter = 686 mm
225/65 R16C tyre predicted external diameter = 699 mm
235/65 R16C tyre predicted external diameter = 712 mm
Comparison of the calculated spare-wheel-well diameter with the calculated external tyre diameters, suggests that a 215/65 R16C tyre should fit comfortably in the spare-wheel-well, provided the spare-wheel-well can be made wide enough; and might possibly even accommodate a 225/65 R16C tyre.
Just to be on the safe side, I shall measure the external circumference (from which I can infer external diameter & radius) of the two 215/65 R16C tyres on Vauxhall Movano wheels that I possess (salvaged from a waste-skip dumpster in USA parlance!?!), and create a corrugated-cardboard template to try for size in the spare-wheel well.
https://en.wikipedia.org/wiki/Renault_Master#Second_generation_(1997%E2%80%932010)
The second generation Renault Master, which arrived in November 1997 was more conventional in appearance and, though primarily developed by Renault, was available from 1998 as the almost identical Opel Movano (badged in the United Kingdom as the Vauxhall Movano), and from Renault's closely related partner Nissan, from whom it was available as the Nissan Interstar.
For interest, I have also recently been investigating the space-saver spare wheels & tyres, that are supplied for Mercedes C-Class & E-Class cars; several second-hand examples of which, are currently listed on British E-bay.
There is a 16 inch steel wheel with 125/90 R16 98M tyre and a 17 inch steel wheel with 155/70 R17 110M tyre; either of which would be of adequate load rating for a 1971~79 VW Type 2. Their external circumferences are comparable with a 205/55 R16 tyre, which is about 3% smaller than a 185/80 R14C tyre
Mercedes C Class Clk Spare Space Saver Wheel W203 W209
https://www.ebay.co.uk/itm/Mercedes-C-Class-Clk-Sp...Sw4vJathOb
Mercedes E Class Space Saver Wheel
https://www.ebay.co.uk/itm/Mercedes-E-Class-Space-...Swf~JalCqU _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
richparker Samba Member
Joined: November 24, 2011 Posts: 6936 Location: Durango, CO
Francoc Samba Member
Posted: Wed Apr 11, 2018 7:15 pm Post subject: Re: The Tire Sticky FAQ |
The Hankook Vantra LT RA18 is a summer tire, right? |
Posted: Wed Apr 11, 2018 7:47 pm Post subject: Re: The Tire Sticky FAQ |
The RA18 is a 3 season tire And are Hankooks replacement of the RA08 which was a 4 season tire. The tread looks good though, I bet they could handle some snow when they are new.
I have a few hundred miles on my new RA18s already. I will review them after our trip to Canyon Lands next weekend. So far Im am pretty happy. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20233 Location: Sandpoint, ID
Posted: Thu Apr 12, 2018 1:33 pm Post subject: Re: The Tire Sticky FAQ |
richparker wrote: |
I have a few hundred miles on my new RA18s already. I will review them after our trip to Canyon Lands next weekend. So far Im am pretty happy. |
Having them siped may help. _________________ nothing |
gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Wed Apr 18, 2018 9:00 am Post subject: Re: The Tire Sticky FAQ |
I found this website today accidentally, and they have a ton of off-brand 185 R14 size tires all correctly load rated. I was surprised to see so much selection. Not sure I'd trust my bus to a "TBC brand" tire, but hey, if you're on a budget, they have D-rated tires down to $60/tire.
https://simpletire.com/catalog?width=185&ratio=-&rim=14 _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
busboyjake Samba Member
Joined: September 22, 2002 Posts: 393 Location: Colorado
Posted: Thu May 17, 2018 10:32 pm Post subject: Re: The Tire Sticky FAQ |
Sorry if it's been answered before, because it likely has, but:
Does anyone have any details as to whether a 30x9.50x15 will fit a stock bus on split window 15" wheels?
I've ran 215/75r15 bfgoodrich all terrains before without much trouble. _________________ 1965 Pearl White Caravelle Camper
1978 Dakota Beige Westy
1969 Montana Red Westy (for sale soon) |
Posted: Fri May 18, 2018 7:05 am Post subject: Re: The Tire Sticky FAQ |
busboyjake wrote: |
I've ran 215/75r15 bfgoodrich all terrains before without much trouble. |
I would think the with of the tire might be an issue. 15 split wheels are only like 4.5 or 5.5 wide, dont recall off hand. My buddy was told by a tire shop that they wouldnt even mount the 215/75r15 because the tire was too wide for the rim. Which is funny b/c its been done and many split guys are running them. Id also imagine that the 30x9.5 would rub the sway bar at full tilt. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build |
Tcash Samba Member
Posted: Fri May 18, 2018 7:20 am Post subject: Re: The Tire Sticky FAQ |
You can try using the [Search this topic...] function.
It is better to limit your search term. Example 30x9.50x15 try 30x9.50.
Good luck
Tcash |
Posted: Fri May 18, 2018 9:10 am Post subject: Re: The Tire Sticky FAQ |
Tcash wrote: |
Good luck
Tcash |
Thanks. Did that. I got this 180 page thread. You're more than welcome to comb through it, but I have better things to do like go to work and work on my bus, eat food, sleep, etc. _________________ 1965 Pearl White Caravelle Camper
Posted: Fri May 18, 2018 9:20 am Post subject: Re: The Tire Sticky FAQ |
busboyjake wrote: |
Tcash wrote: |
Good luck
Tcash |
Thanks. Did that. I got this 180 page thread. You're more than welcome to comb through it, but I have better things to do like go to work and work on my bus, eat food, sleep, etc. |
I tried it, too, and found this...
https://www.thesamba.com/vw/forum/viewtopic.php?p=8218660&highlight=30x9.5#8218660
Looks like you're gonna need some lift to fit these meats. _________________ nothing |
Posted: Fri May 18, 2018 9:25 am Post subject: Re: The Tire Sticky FAQ |
cdennisg wrote: |
busboyjake wrote: |
Tcash wrote: |
Good luck
Tcash |
Looks like you're gonna need some lift to fit these meats. |
Nope. Same thing I found. Still doesn't answer my question. Yes, I assume they will fit on the rear.
This gets me closer:
Posted: Fri May 18, 2018 9:33 am Post subject: Re: The Tire Sticky FAQ |
Buy some, and see if they fit. They have been fit to a lifted bus. You may be the first to stuff them under a stock height bus.
They may be made to fit out back, but I am guessing there will be a need to modify the offset of the rear wheels to get them centered in the space.
Diameter will likely be too big up front to clear the rear dogleg during suspension travel. _________________ nothing |
Posted: Fri May 18, 2018 9:35 am Post subject: Re: The Tire Sticky FAQ |
We're talking about 2 inches taller (one inch closer to the b-pillar), and 1 inch wider (0.5 inches closer to the sway bar)
This may call for a test fit. _________________ 1965 Pearl White Caravelle Camper
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5680 Location: Manhattan, Kansas, USA
Posted: Fri May 18, 2018 9:38 am Post subject: Re: The Tire Sticky FAQ |
The "Use the Search" suggestion was referring to searching within the thread, not searching all of the Bay forums...
Anyway, one suggestion I have is you could go to your friendly local tire mounting shop and see if they have any used take off tires in your desired size. You could buy a pair of them and have them mounted and do your test-fit with a relatively cheap pair of tires vs buying all new ones only to find out they don't fit. If they're really nice at your store, maybe they'd let you "borrow" them for the cost of a couple mounting fees.
Worth a shot, that is what I did when shopping for tires for my Bus. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri May 18, 2018 9:41 am Post subject: Re: The Tire Sticky FAQ |
These look pretty rad, and they're cheaper than bfg's. _________________ 1965 Pearl White Caravelle Camper
Tcash Samba Member
Posted: Fri May 18, 2018 9:50 am Post subject: Re: The Tire Sticky FAQ |
Tcash wrote: |
Good luck
Tcash |
Let me try this again.
You can try using the [Search this topic...] at the top of the page of the Thread you are in.
Search results in 8 links.
https://www.thesamba.com/vw/forum/search.php?searc...ults=posts
Just trying to help
Tcash |
Tcash Samba Member
zwartePiets Samba Member
Joined: January 05, 2009 Posts: 58 Location: Austin Texas
Posted: Thu May 24, 2018 9:10 pm Post subject: Re: The Tire Sticky FAQ |
Does anyone run a 27x8.5-14 Kumho Road Venture on their bay. I was looking to see how they look and fit. |
Posted: Thu May 24, 2018 9:17 pm Post subject: Re: The Tire Sticky FAQ |
zwartePiets wrote: |
I run that size, but a different make and model, with no ill effects. They fit perfectly.
Cooper Starfire 27x8.5r14LT
https://www.summitracing.com/parts/coo-51089/overview/ _________________ nothing |
