Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Dec 03, 2020 3:40 pm Post subject: Re: The Tire Sticky FAQ |
Nice high load rating. How many percent taller is a 195 than 185? got a diameter? Just wondered about gearing. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Thu Dec 03, 2020 3:53 pm Post subject: Re: The Tire Sticky FAQ |
45-70bpcr wrote: |
richparker wrote: |
I love mine, they offer a good ride on and off road. I even use then on my Frontier. I got mine for $471 shipped off eBay, no rebate tho. Local shop charged me $75 to mount them, but I only brought them the rims and tires. That $75 was for 5 tires as a bought them a 185r14c Hankook to install as my spare, I wanted it to fit in the spare tire well in the back. |
Ya $75 is about the going rate around here for 4 mount and balances. If you can take the abuse the harbor freight tire mounter pays for itself pretty quickly. There is a satisfaction of mounting them yourself too. |
I just bought 5 Hankook Vantra's for my '69 bus and used the POS Harbor Freight tire mounting tool to mount them. My wheels are the wide five pattern, at first I thought I couldn't use it because of the big hole in the wheel. I eventually used a old wheel adapter to make it work...I lag bolted my machine to a pallet. They work if your willing to put in the effort (literally) and have some experence mounting tires. I polished the working ends of the bar and that seemed to help. I didn't have any way to balance them, so I took them to Discount Tire and they broke it off in my ass $60 for the balance. At first they said they couldn't do it, but one employee suggested using a mandrel for 1 ton trucks and it bearly had enough diameter to catch the wheel. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Thu Dec 03, 2020 4:17 pm Post subject: Re: The Tire Sticky FAQ |
Yeah those mandrels are just big enough to get the job done.
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
fokker100 Samba Member
Joined: February 13, 2006 Posts: 149 Location: North of the border
Posted: Thu Dec 03, 2020 4:52 pm Post subject: Re: The Tire Sticky FAQ |
Alan Brase wrote: |
Nice high load rating. How many percent taller is a 195 than 185? got a diameter? Just wondered about gearing. |
I have 185R14 Westlake tires, used, at 25” diameter, and new Hankook Vantra 195R14, new, at 26”. It is quite a difference for the same rims.
I think the Westlake’s would be 25 1/4” when new, approximately.
I have to say that I measured roughly, and these are 2 different brands, but it gives an idea. |
SGKent Samba Member
Posted: Thu Dec 03, 2020 4:53 pm Post subject: Re: The Tire Sticky FAQ |
airschooled wrote: |
just as an FYI since that is a great photo. When a lug nut is over tightened it expands tha area between the lugnut hole and the center of the wheel. If the lug nuts are done with an air gun where the tightening is uneven then the peninsulas between the lugnut and the center opening are uneven so the tire is no longer centered when it is mounted on a tire balancer You'll never get a tire when that happens balanced because a tire where the steel is deformed then the tire is off center in the machine. The fix is to use your digital calipers to measure between the edge of the lug nut and the edge of the steel at the center on each lugnut, then file the ones that are wider so that the lugnut holes are all equal distance from where the wheel balancing cone will center in the wheel. Then you'll get a good balance. Took me years to figure that out. Also if a car has mags that use lug bolts, the tires won't run a true as using studs, and lug nuts. A new car won't have as many issues balancing as an older steel wheeled car that has been on and off many times with an air gun. Many shops today use a torque wrench to finish the tightening. Not so in the 70's thru 90's. They just hammered on them with the air gun which deformed the wheel.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Dec 03, 2020 5:08 pm Post subject: Re: The Tire Sticky FAQ |
You could use ON CAR balancer.
Good thing is that with 60-70mph normal cruising speed, tire balance is less of a concern. _________________ Al Brase
Vanagons:
Posted: Thu Dec 03, 2020 9:31 pm Post subject: Re: The Tire Sticky FAQ |
We had a spin balancer at a VW stealership I worked at. There is a learning curve to those and I doubt if some of the brain-dead imbiciles at Discount Tire could master it. Spin balancers and bubble balancers are relegated to the dust bin of automotive history. If I had either one, I'd have done it myself. Computer balancers are probably the best. I cringe every time I have to go to Discount Tire.
One of these days I'll write a book about me and Discount Tire. And I still give them money. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
TCU ......GO FROGS!!!!!! |
Posted: Thu Dec 03, 2020 10:31 pm Post subject: Re: The Tire Sticky FAQ |
Mentioned before, I have pretty good luck mounting with a real rubber headed tire hammer.
Now I can afford it I suppose I should buy at least some type of a tire machine.
Not sure where to go with that, short of spending $3000. Which will not happen. _________________ Al Brase
Vanagons:
brando90gl Samba Member
Posted: Fri Dec 04, 2020 3:31 am Post subject: Re: The Tire Sticky FAQ |
Alan Brase wrote: |
Not sure where to go with that, short of spending $3000. Which will not happen. |
I bought one of these rim clamp changers several years back, sure it’s an offshore machine, but it works.
https://www.nhproequip.com/phoenix-pwc-2950-tire-changer
I’ve also been very satisfied with balancing my wide five tire/wheel combos with Counter Act balancing beads, 3oz per tire for our sizes. Just tear a corner off a 3oz bag and toss them in the tire before mounting. The kits do come with a bottle and small length of tubing to funnel the beads in through the valve stem as well. _________________ 67 Type 1
68 Campmobile
70 Single Cab |
nemobuscaptain Samba Member
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Fri Dec 25, 2020 9:30 pm Post subject: Re: The Tire Sticky FAQ |
rugblaster wrote: |
so I took them to Discount Tire and they broke it off in my ass $60 for the balance.. |
that's cheap. i get 20/ea to balance. mount and balance is 40. if you have stick on weights its 60 each for a balance.
if you own wide 5's and don't have the adapter you really should. i was lucky enough to come across one that i will probably never use again _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
snapped Samba Member
Joined: October 21, 2009 Posts: 20 Location: Washington State
Posted: Mon Dec 28, 2020 3:06 pm Post subject: Re: The Tire Sticky FAQ |
I went to my local discount tires to check out some general grabber A/Ts. they actually had an adapter to balance the wheels, but they would not mount the tires to a wheel under 6 inches. Is there a stock style wheel that works? Is this something tire stores are starting to do for liability reasons? I have a 69 sc. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Tue Dec 29, 2020 3:22 am Post subject: Re: The Tire Sticky FAQ |
snapped wrote: |
I’ve read this from several posters. For the reason you stated some shops won’t mount the tires. The 27x8.5 fit without any issues, if you want them go to another shop.
The local shop I deal with was unable to get them for me. So I ordered them off eBay and brought them in with just the rims. They were mounted without any questions or issues.
Good luck! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Sjoerdvleugel Samba Member
Posted: Thu Feb 25, 2021 12:20 pm Post subject: Re: The Tire Sticky FAQ |
Just got some new A/T offroad tires for my T2a 1968 Deluxe!
Malatesta 195/75 R14 Kobra Trac NT for a reasonable 88 Euro per tire.
Most importantly they look awesome, they drive quite good and don't rub riding on standard suspension. They do make more rolling noise versus standard tires obviously.
_________________ 1968 T2a California import |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Thu Feb 25, 2021 1:10 pm Post subject: Re: The Tire Sticky FAQ |
Those are some nasty looking treads, I like. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
melville Samba Member
Joined: August 09, 2006 Posts: 1246 Location: Just Outside the Redwood Curtain
Posted: Thu Feb 25, 2021 3:31 pm Post subject: Re: The Tire Sticky FAQ |
Malatesta?
Bad head?
Sick head? _________________ 2000 M Roadster
79 R100RS
78 R100/7
75 R75/6
65 Standard Micro
57 Sedan |
fatmatt650 Samba Member
Joined: November 18, 2008 Posts: 188 Location: Pacifica, Ca
Posted: Fri Apr 02, 2021 6:04 pm Post subject: Re: The Tire Sticky FAQ |
Pretty sure I'm about to pull the trigger on a set of Grabbers for my '72 camper to replace the tired out Vancos I've been running for about 10ish years now. From what I gather - similar crosswind performance, lower gas mileage (10%ish?), slightly more road noise but not too bothersome, about 3/4" taller so speedo and odo will be off a bit. This sound about right?
_________________ 62 Single Cab
70 bug
72 Highroof
72 Highroof
86 Scirocco
"So much to do...so little time." |
Posted: Fri Apr 02, 2021 6:17 pm Post subject: Re: The Tire Sticky FAQ |
^I run the 27x8.5 Grabber ATX. My Speedo is accurate, I don’t have any extra road noise and I get the same gas mileage. In my bus that 16-17 in town and 20-21 on the highway. I run them the at 35 psi and personally I thing the ride is excellent. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Apr 02, 2021 8:53 pm Post subject: Re: The Tire Sticky FAQ |
richparker wrote: |
^I run the 27x8.5 Grabber ATX. My Speedo is accurate, I don’t have any extra road noise and I get the same gas mileage. In my bus that 16-17 in town and 20-21 on the highway. I run them the at 35 psi and personally I thing the ride is excellent. |
That's excellent to hear. I've been agonizing over this. Thanks for the review. _________________ 62 Single Cab
70 bug
72 Highroof
72 Highroof
86 Scirocco
