Iowa Mark Samba Member
Posted: Sun Mar 19, 2006 12:25 pm Post subject: Blink-blink-blink |
Hi there, I'm somewhat new around here, but thought I'd ask a question anyway. I'm working on a Berry Mini t and need to install a blinker switch set-up in it. The steering column mount is out because of lack of room. And one of those under the dash units will skin my knuckles all up when I shift. There is very limited dash space on this critter. Has anyone got any suggestions for a slick way of being legal? Thanks |
fifty-five Samba Crash Test Dummy
Joined: August 27, 2004 Posts: 1188 Location: over by the Farm
Posted: Sun Mar 19, 2006 1:00 pm Post subject: |
Get a three position toggle switch. You can put it anywhere.
Mount so that it is switched left to right and the middle position is the cancelled position. That way you don't have to remember if up is left or right. You just have to be sure to cancel the signals yourself. My old rail was setup this way and worked fine. |
buggyblues Samba Member
Joined: August 21, 2005 Posts: 392 Location: charleston, SC
Posted: Sun Mar 19, 2006 1:25 pm Post subject: inspection states |
some states require that your turn signals shut off automatically and will not allow you to use a 3 position switch so check that out before you go thru all the grief. _________________ www.sticklestowingpittsburgh.webs.com
towing east coast |
tcrdn Samba Member
Posted: Sun Mar 19, 2006 2:29 pm Post subject: |
I used the 3 position toggle switch and it works great. Use a 2 prong flasher or 3 if you want a warning light. Yes, I have driven several miles with a light flashing. I just claim to be practicing for retirement in Florida.
Good luck,
TC |
Posted: Sun Mar 19, 2006 3:08 pm Post subject: |
Thanks folks, and to you, TC, I'm getting old enough to pull that "practicing" thing off! Next thing is to get all this to work with single 1157 bulbs, tail, brake, signals. |
tcrdn Samba Member
Posted: Sun Mar 19, 2006 3:28 pm Post subject: |
All I have is single 1157's. My lights were so abused and pitted I wound up soldering pigtails to each bulb because I couldn't find replacement bulb holders that would fit. Makes it a pain to change a burned out bulb but it works.
TC |
Posted: Sun Mar 19, 2006 4:53 pm Post subject: |
tcrdn wrote: |
Good luck,
TC |
Me too , But I have a quite a few years before I go to Florida unless I win the lottery. |
Santa Clarita Len Samba Member
Joined: December 22, 2004 Posts: 11 Location: Santa Clarita CA
Posted: Mon Mar 20, 2006 10:28 am Post subject: Self cancelling signal switch |
If you want self cancelling dash mounted switches with hazzard lights, try this site: http://www.tperformance.com/street_rod_store/electrical/turn-signal_kits/ It is the site of Total Performance, Inc. and I recently purchased this switch assembly and am in the process of installing it, they appear to be high quality which you would expect for the price. _________________ Santa Clarita Len |
A E Numan Samba Member
Joined: March 12, 2006 Posts: 238 Location: Portland Oregon
Posted: Mon Mar 20, 2006 4:34 pm Post subject: |
Mark: You could use a turn signal switch from a 61 bug. They were made to work with a single 1157 bulb and would also fit the stock stearing colum. It would also be self cansiling. |
Posted: Mon Mar 20, 2006 5:44 pm Post subject: |
Thanks again guys. A.E. I can't use a column mounted switch because I've butchered the thing to get it close to the dash and welded on a quick disconnect hub. I'm 6'-3" and I'm sitting lay-down style in the Mini T, so sliding in under the dash without relocating my knee-caps is way up there on my to do list. If I ever figure out how to transfer pictures to the computer and post them, I'll have to show off my little "cartoon car". |
seabeebuggy Samba Member
Joined: October 03, 2005 Posts: 2395 Location: NM, CA, UT and now NV
Posted: Mon Mar 20, 2006 7:52 pm Post subject: |
tcrdn wrote: |
TC |
they sell replacements at auto part store. some you just need to drill a hole and put it in . it has tabs to keep it there or remove you old bulb holder . replace with new. about 3$. I added 2 in my brake lights . added lights are bright at night also lets me have parking , brake and turn sig. _________________ Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad |
