5 speed in a Vanagon
Page: 1, 2, 3  Next
Christopher Schimke
PostPosted: Mon Mar 20, 2006 10:34 pm    Post subject: 5 speed in a Vanagon Reply with quote
I might have the opportunity to purchase a 5 spd for my Vanagon.
Is this a direct bolt in? Anyone driven or driving a Vanagon with a 5spd?
Is it worth it? Any other useful information?
Thanks!
wbx
wbx is offline
PostPosted: Tue Mar 21, 2006 4:45 am    Post subject: Re: 5 speed in a Vanagon Reply with quote
Thanks!
First question - is this a diesel 5 speed, or the uber-rare european/south african gas 5 speed?
The former, i don't think will fit (unless you have a diesel), and only gives you a crazy low first gear. Although you should be able to swap out bell-housings. The latter is really cool and i want one.
-Damon
Christopher Schimke
PostPosted: Tue Mar 21, 2006 8:47 am    Post subject: Reply with quote
It's a European Gas model.
wbx
wbx is offline
PostPosted: Tue Mar 21, 2006 9:43 am    Post subject: Reply with quote
You bastard. Then, yes, as far as i know, it is a direct bolt-in. You are going to want to do something with the linkage at the front (the shifter box above the spare tire) as first is below reverse - and there is no lockout between the two (and you have to press down to get into first, now.
Also, get the 5sp shifter knob, if you can Wink
I have driven one, and it was very nice. The big gap between 2nd and 3rd gear is wrong, and 4th gear is a lot more useful for the hills. I *really* want one!
-Damon
vwjedi
vwjedi is offline
PostPosted: Tue Mar 21, 2006 10:30 am    Post subject: Reply with quote
I long to shift into a fifth gear, my wife is so used to driving our TDI that she accidently downshifts to 3rd looking for 5th. Shocked
How much would one of these little puppies run? $$$$$
1987 Wolfsburg T25 still riding out. A bunch of other VW's passed on...
wbx
wbx is offline
PostPosted: Tue Mar 21, 2006 10:36 am    Post subject: Reply with quote
The only place i know selling them is weddle engineering. But i think they are not cheap.
I'm tryinng to work some angle to get one over from europe...
-Damon
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 21, 2006 11:23 am    Post subject: Reply with quote
Cheap is realitive. I got some Caddy parts from SA in the past, but they were small items. I have been in contact with a breaker in SA. Parts no problem. Payment via credit card, no problem. Shipping is a problem. I would have to buy a container load before the shipping costs would be reasonable. Or just have them send the parts to convert a 4 speed. My brother has the tools.
Ratios. Different boxes have different ratios. You can mix and match with Weddle, if you want. I think it was like $1700 for a custom 5 speed. If I had a stick shift van, I would do the 5 speed. I may yet, but we kinda like the auto as it is so brainless. Then again as I am changing final drive ratios when I change the engine, I may rethink that. But, I have enough to worry about driving that big box. The kids do not help me drive, either.
So there you go....
Christopher Schimke
PostPosted: Tue Mar 21, 2006 4:54 pm    Post subject: Reply with quote
Cool thanks guy's.
So, what is the shift pattern? If reverse becomes 1st, is second straight down or right and down? Where is reverse?
wbx
wbx is offline
PostPosted: Tue Mar 21, 2006 5:48 pm    Post subject: Reply with quote
loogy wrote:
Cool thanks guy's.
You got it wrong... Reverse is below first. The shift pattern is like this:
R-2-4
1-3-5
And yes, it is weird to drive.
weinerwagen
weinerwagen is offline
PostPosted: Tue Mar 21, 2006 6:06 pm    Post subject: Reply with quote
How bout posting the gear ratios of 1-5. Let us compare what VW did in regards to the 5 vs the 5.
In my A-2 diesels I can tell you that having that 5th gear, even if it is still
only slightly higher than the 4th (in regards to the GLI trans),
I put a GTI 84 in my Caddy truck diesel, pulled it out after a few weeks. Geared way too low. Guess the magic wand 5 speed is not always the answer....
wbx
wbx is offline
PostPosted: Tue Mar 21, 2006 6:15 pm    Post subject: Reply with quote
Ask and you shall receive. God... why do i have all this information Rolling Eyes
http://volksweb.relitech.com/helmut/GEARBOX.HTM#5Watertranny
and here is a crap copy and paste...
Forth the 5-speed boxes for gasoline engines:
Type 094 094 094 094 094 094
ID character DV, 7D 8H, 8F ABL DW, 8D 8E, 3P ABN, ABM
For engine 1.9L 1.9L 1.9L 1.9L 1.9L 1.9L
Power 44 kW 44 kW 44 kW 57 kW 57-66 kW 57-66 kW
Year < 83.11 > 83.12 > 84.8 < 83.11 > 83.12 > 84.8
1. gear 4.11 4.11 4.11 4.11 4.11 4.11
2. gear 2.33 2.33 2.33 2.33 2.33 2.33
3. gear 1.48 1.48 1.48 1.48 1.48 1.48
4. gear 1.02 1.02 1.02 1.02 1.02 1.02
5. gear 0.77 0.82 0.82 0.77 0.82 0.82
Revers 3.67 3.67 3.67 3.67 3.67 3.67
Transaxle 4.86 4.86 4.83 4.86 4.86 4.83
weinerwagen
PostPosted: Tue Mar 21, 2006 6:25 pm    Post subject: Reply with quote
Sooooo, I guess it's safe to assume that the 1st gears are 4.11's!
Rolling Eyes Rolling Eyes Wink Wink
Now if I could just find me a 3.56 final drive....
D Clymer
D Clymer is offline
PostPosted: Tue Mar 21, 2006 6:59 pm    Post subject: Reply with quote
The 094 5 speed has always been kind of a puzzle to me. Obviously the Vanagon needs a taller cruising gear than 4th. But if you look at the ratios on the 5 speed, first gear is about 9% shorter than with the four speed, and 5th is about 9% taller. If you get one with the .82 fifth, you're only 4% taller. They should have kept first and second the same, shortened third and fourth, used the .82 fifth and then run a 4.57:1 final drive. I would gladly pay the money for a tranny with ratios like those.
David
weinerwagen
PostPosted: Tue Mar 21, 2006 8:19 pm    Post subject: Reply with quote
Having been the lucky sap who has driven big rigs off and on since 1974...I sware by multi geared trans.
I sometimes dream that my Vanagon diesel had a 7-8 speed in it. It would be a blast to drive with a multi geared close ratio trans
I'm doing an 84 automatic with a turbo diesel in it. But we are changing the final drive.
One of these days when I am rich with plenty of money to just throw in the wind, my 3 litre Cat power plant engine is going into an automatic Vanagon, BUT the final drive has to be in the high 2's to low 3's.
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 21, 2006 8:49 pm    Post subject: Reply with quote
Where are you getting that from? Ratio?
weinerwagen
PostPosted: Tue Mar 21, 2006 8:54 pm    Post subject: Reply with quote
Where are you getting that from? Ratio?[/quote]
Having it built. Custom built. One of my race car engine builders said he could either find one, or have one made.
SOOOOO......he got a sample and I wait... Rolling Eyes
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 21, 2006 10:01 pm    Post subject: Reply with quote
You can get one other final drive set at fastforward.ca
weinerwagen
PostPosted: Tue Mar 21, 2006 10:32 pm    Post subject: Reply with quote
hmmmmmm a 2.88 to 3.40ish one???
My little Cat runs between 1800-2300. Therein, the final drive gotta be a lower numba or we only goes 40-50 mph max....
gunna check with fastforward manana. Momma cat has already walked twice across the laptop. Bedtime... Confused
Wellington
Wellington is offline
PostPosted: Wed Mar 22, 2006 10:38 am    Post subject: Reply with quote
I have been led to believe that the 5 speed is a direct bolt in, however you need ALL the 5 speed parts, linkage gear shifter, bushings etc.
I have the Weedle catalogue and they offer all the parts. They list 3 or 4 different 5 speeds, the R&P is different. They also offer a taller 5 as an option. I think the price range was 1700 to 2300 for the tranny, about 300$ more for the optional taller gear.
Tomorrow I will post the ratios they have as off the shelf.
[email protected]
vwman17@yahoo.com is offline
PostPosted: Wed Mar 22, 2006 11:23 am    Post subject: Weddle currently does have all the parts necessary Reply with quote
I just talked to Steve Jones from Weddle engineering today. They have in the past had all of the conversion parts. They currently do not.
He also stated that the first 3 gears could not be changed.
His estimate for cost was $1500 or more
Page: 1, 2, 3  Next
