Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Wed Mar 22, 2006 12:20 pm Post subject: |
Wellington wrote: |
I have been led to believe that the 5 speed is a direct bolt in, however you need ALL the 5 speed parts, linkage gear shifter, bushings etc.
I have the Weedle catalogue and they offer all the parts. They list 3 or 4 different 5 speeds, the R&P is different. They also offer a taller 5 as an option. I think the price range was 1700 to 2300 for the tranny, about 300$ more for the optional taller gear.
Tomorrow I will post the ratios they have as off the shelf. |
The shifter handle and box should be all that is different. The trans case and shifter part is the same as an 091/1 4 speed (83-up).
None of this applies to air cooled and 82 diesels. They are completely different. They had to move the engine rearward 2" to get room for the 5 speed in 83.
If someone needs pics of the shift linkage, I have one I can send pics of. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Wed Mar 22, 2006 3:04 pm Post subject: |
69doublecab wrote: |
If someone needs pics of the shift linkage, I have one I can send pics of. |
can you just load it up here on the samba and post it to this thread?
thanks,
-damon |
Posted: Wed Mar 22, 2006 3:13 pm Post subject: |
Walk me thru the process. One of the pics is 389kb. I suppose the rest are about the same size _________________ Al Brase
Vanagons:
wbx Samba Member
Posted: Wed Mar 22, 2006 3:26 pm Post subject: |
Walk me thru the process. One of the pics is 389kb. I suppose the rest are about the same size |
First of all, to br friendly to dial-up folk like me, it would be nice if you'd reduce the picture size... something no more than 100k would be nice
After that, you look at the top of this page to where it says "Gallery". Then click on "add photo". After that it is pretty obvious. Select the picture you want to upload from your computer, give it a title and description for the samba, tell it to load it to the vanagon/eurovan forum, and boom... it is loaded.
After that, if you click on the gallery picture you just loaded (it'll be a little thumbnail on the left), you can right click it (assuming you have a PC) and copy picture address/url. Use the little (img) button at the top of your "post a reply" dialogue box and paste in in the link between [..img] and [../img] (except without the .. ).
That should do it!
-Damon |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Thu Mar 23, 2006 3:54 am Post subject: |
Weddle listed the following:
standard 1st through 5 are 4.11, 2.33, 1.48, 1.02, .82
R&Ps 5.43, 4.83, 4.57. cost 1695, 1995, 2295$ respectively
optional 5th 0.77, or 0.70 cost 223$
this is from a 2001 catalogue. |
Posted: Thu Mar 23, 2006 7:54 am Post subject: |
wbx wrote: |
loogy wrote: |
Cool thanks guy's.
So, what is the shift pattern? If reverse becomes 1st, is second straight down or right and down? Where is reverse? |
You got it wrong... Reverse is below first. The shift pattern is like this:
R-2-4
1-3-5
And yes, it is weird to drive.
Not wierd at all if you've driven early 911's with 901 and type 911 gearboxes.
Many people liked them best, because, once you'd made the 1-2 shift, all gears were within the pattern. IOW, a road racing transmission, not a 4 speed with overdrive. Perhaps not quite as good in stop and go city traffic.
I now have a later 911 with 915 gearbox and often find myself trying to put it into reverse at 125mph after teaching some snottty nosed asian car driver a lesson. (Still crazy after all these years!) (And that big tailpipe alone is not enough!) I'm not foolish enough to take on WRX's! _________________ Al Brase
Vanagons:
hhholsteiners Samba Member
Posted: Wed Jun 17, 2015 9:46 am Post subject: Need 5 speed for my "new" 1987 Vanagon Westy 2.1L |
Reverse is being a bear in my current R to 4, and I really need that 5th gear. Where can I get a bolt in variety?
Thanks!!!
Anya
313 478 2614 |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
MR GAS Samba Member
Joined: October 29, 2008 Posts: 129 Location: Canon City
Posted: Thu Jun 18, 2015 6:48 am Post subject: New 5 speeds |
Weddle now offers a $1700 kit to install all new 5 speed parts into your 4 speed core. Really nice New trans w optimal gearing. I have built a few with very good response from the owners. Wish I had one now!
$1700 kit
$1200 rebuild
$400 Weddle od 5th gear
$100 MS bearing Thrust plate
Not cheap but cheaper than other options _________________ Transaxles Rebuilt, Repaired and Re Geared 25 years. www.MRGASRebuilds.com |
transanalog Samba Member
Joined: April 06, 2011 Posts: 67 Location: New Orleans, Louisiana
Posted: Thu Jun 18, 2015 7:26 am Post subject: Re: New 5 speeds |
MR GAS wrote: |
$1700 kit
$1200 rebuild
Not cheap but cheaper than other options |
I looked through their website (for at least a minute or two, whew!) and was unable to find this. Can you post a link to the kit and other 5th gear info? _________________ Mike
New Orleans
1991 Vanagon Carat |
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Thu Jun 18, 2015 11:10 am Post subject: |
Thanks!! _________________ Mike
New Orleans
VanMan2009 Samba Member
Joined: October 26, 2009 Posts: 166 Location: Seattle
Posted: Thu Jun 18, 2015 4:10 pm Post subject: |
What would be pros/cons of this vs going with the Suby 5sp? I've been really wanting a 5sp and had thought a Subaru tranny was my only option. Can these transmissions handle decent HP or are they delicate like our stock 4 speeds? |
MR GAS Samba Member
Posted: Thu Jun 18, 2015 4:48 pm Post subject: |
VanMan2009 wrote: |
This VW 5 speed that Weddle is selling is as strong as the VW 4 speed. Same beef up parts fit in the 5 speed as the 4 speed. Same Differentials available.(Locker, TBD, LSD).
Advantages over the flipped Subaru.
Bolts in to same van as the late side shift case 4 speeds. 83.5+
VW Shifter bolts up. (Is there a shifter avail for the Subaru)
All the forward Gears and Ring and Pinion are NOS VW new parts. (except 5th which is a New Weddle gear) Zero Mile parts. Not 180k+ like most vans.
Posted: Thu Jun 18, 2015 4:50 pm Post subject: |
How is a Subie 5 speed going to work? Somebody will have to change the ring gear to the other side or you will have 5 speeds in reverse.
And the 091/1 is delicate? Perhaps not up to a extremely boosted diesel, but hardly delicate. Early ones up to mid 1988 had a known weakness, but most are past that by now.
And the good thing is.... they fit.
Al _________________ Al Brase
Vanagons:
Zeitgeist 13 Samba Member
Posted: Thu Jun 18, 2015 4:55 pm Post subject: |
There are quite a few other threads about those off brand transaxles _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Thu Jun 18, 2015 5:16 pm Post subject: |
If you read the link that I posted above you will see that the front shift rod, shifter, shift box and some other parts are needed to make the 5 speed complete. Those parts aren't very easy to get ahold of.
The subaru 5 speed drives differently than a VW 5 speed in the videos that I have seen. With a engine conversion it drives much more car like. |
vanagonhopefull Samba Member
Joined: September 02, 2014 Posts: 35 Location: The Great White North
Posted: Thu Jun 18, 2015 5:38 pm Post subject: |
I have an '89 Westy, 5 speed TDI. (imported from Germany) It's great. 5th speed is pretty good for cruising highways at approx 100 km/h, even with stock 14 inch tires. |
MR GAS Samba Member
Posted: Thu Jun 18, 2015 7:31 pm Post subject: |
syncrodoka wrote: |
The Three 5 speed kits I have done recently were installed into late vanagons that were 4 speed vans. two were a bolt in deal NO mods. The third needed the shifter adjusted, after he called and I went thru how to adjust the shifter he has been happy since. All installs were done by the customer. Using the stock shifter does require pushing down as if to go to reverse to get into first. Like a Early Porsche 901 trans. So as I see it the 5 speed euro shifter is an option not a necessity.
The Subaru trans does drive more like a car as it has a taller first gear and ring and pinion. That might work good in my lighter van and on the road. The VW trans has a lower first gear ratio and ring and pinion giving it the lower offroad capable first so I can get to my out of the way camping spot. _________________ Transaxles Rebuilt, Repaired and Re Geared 25 years. www.MRGASRebuilds.com |
Posted: Thu Jun 18, 2015 7:57 pm Post subject: |
If you don't need to push the shifter down to shift into first then you have the possibility of misshifting into 1st while looking for 3rd. It can be done but it isn't a ideal solution as members have mentioned before.
I should have mentioned that in 2003 the PO of my van spent thousands of dollars importing a 5 speed from the motherland then having WEDDLE rebuild it with new parts with all new 5 speed shift components so I know exactly what is good or bad about a legit VW 5 speed. |
