Stroking a 36hp
krusher
krusher is offline
PostPosted: Wed Mar 22, 2006 10:58 am    Post subject: Stroking a 36hp Reply with quote
Hi, In my barndoor at present I have a oval 36hp engine, then OG bus engine is sitting siezed in my garage I would like to rebuild this engine for the bus with some modification for a little extra power, so am lookinf at stroking it a little. I know okrasa made a 69.5mm crank for there TSV and empi mad a 6mm over stock stroked crank, but I have little to no chance of getting one of them.
I remember reading somwhere a 356 crank is a possible, does anybody know details.
Very Happy
RIS
RIS is offline
PostPosted: Wed Mar 22, 2006 5:13 pm    Post subject: Reply with quote
If you know of a GOOD crank grinder they should be able to weld and offset grind your current crank for more stroke, if you can find rods with a smaller big end diameter you can gain more stroke when offset grinding.
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
GDOG57
GDOG57 is offline
PostPosted: Wed Mar 22, 2006 7:01 pm    Post subject: Reply with quote
A porsche 356B crankshaft has 74mm stroke and should work.You will have to use porsche 912 rods also.Pistons from a '84 or so Harly-Davidson sportster,Kolbenschmidt 77mm.This will net you 1378cc. You might also want to port and pollish heads and use 1600 valves.Hope this helps you out. Laughing
sammyphsyco
sammyphsyco is offline
PostPosted: Wed Mar 22, 2006 7:56 pm    Post subject: Reply with quote
Which year, that was a transitional era for HD from trouble head to evo.
http://www.aircooledresearch.com/ This guy sells B piston's in 88.5 mm for 90$, piston's only no cylinders. Says he builds sroker 36 hp's.
sammyphsyco wrote:
Your just jealous the voices are talking to me
GDOG57
GDOG57 is offline
PostPosted: Wed Mar 22, 2006 9:52 pm    Post subject: Reply with quote
1984
krusher
krusher is offline
PostPosted: Thu Mar 23, 2006 12:50 am    Post subject: Reply with quote
Interesting combo, thats 74 is a hefty stroke, is there alot of clearencing required and is that harley piston the equiverlant of a B stroker?
how much wider would this engine be?
Thanks Very Happy
GDOG57
GDOG57 is offline
PostPosted: Thu Mar 23, 2006 6:19 pm    Post subject: Reply with quote
Yes the case must be clearanced.The engine does not get much wider,no cutting involved.The pistons are like having "B" strokers.For more info on a motor like this contact:Steve Daniel at Daniel's machine shop in Augusta Maine.Sorry i dont have his phone number Very Happy
