Baywindow "Rarest of the Rare" FAQ
Page: Previous  1, 2, 3 ... 97, 98, 99, 100, 101  Next
chimneyfish
chimneyfish is offline
PostPosted: Thu Apr 13, 2017 5:54 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
chimneyfish wrote:
OrangeZA wrote:
From reading Simon Glen’s “Sahara Handbook” that I referred to earlier. He only really had issues with dampers/shock absorbers, he recommended using the heavy duty Boge ones, Gabriel, Koni or Bilstein. He didn’t like the coil-over type as he found the springs tended to become dislodged and wear a hole in the body of the damper. The Konis are rebuildable, more information on Koni dampers can be found here http://www.ratwell.com/technical/Koni.html
I have the adjustable Koni red Special D's all round, I'm very happy with them, oil filled shocks all the way for me!
I wonder whether it was the red Koni coil overs Simon Glen had issues with? I would have thought they would have been ideal.
Here are some pictures Topaz put up of Koni coil over shocks she had for sale (I bought my rear regular red Special Ds from her NOS, back when they were hard to get hold of).
http://www.thesamba.com/vw/forum/viewtopic.php?p=1777085
topaz. wrote:
Both pairs took me a truly long time to track them down.
If a T2 owner or a member is interested the part numbers direct from Koni are as follows:
There is a slight difference in length:
T2a [8000e-1082] on a T2b:
Thank you for your time.
1965 Type 1 Deluxe Sedan (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury)
rsbadura
rsbadura is offline
PostPosted: Fri Apr 14, 2017 2:39 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
vworwhat wrote:
Does anybody know the m-code for these chocks?
I have had the same Heavy Duty KONI shocks at my German 1979 9 seater L(uxury) bus at the front axle.
No M code indicate this (M103 is not in the list) - only unknown M code is 708.
I ask KONI for refill (because of advertising with live time guarantee) - but the declined Laughing
Not available anymore - only normal red KONI, that I have installed then (8 years and a lot of miles ago...)
vworwhat wrote:
with warehouse patina
sorry to say that: for me they look like used... but certainly less than mine Wink
regards and happy Easter
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupé (Type 14)
1979 VW luxury bus to camper conversion (Type 22, T2b)
1982 Eriba Pan camping caravan
2017 VW Cross Polo (Type 6C)
vworwhat
vworwhat is offline
PostPosted: Fri Apr 14, 2017 4:04 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Thanks a lot for all the valuable information!
Well true, with regard to the Ratwell charts, these adjustables would not be M103. They probably would have had an m-code though, but maybe not
I have had a set of those red rear Koni coil overs on my earlybay for a period, to temporarily cure a saggy ass syndrom. Using the longer latebay version on an earlybay gave quite a lift. I drove a few 1000 miles like that always being concerned about damaging the mounts, but nothing happened. Obviously that has put considerable strain on the mounts. Not really advisable
Rolf, I sincerely believe they are NOS, but who knows. They are absolutely clean underneath the cap and work perfectly. I bought them as NOS together with a bunch of other NOS parts of a German guy, who I trust. But things are only NOS once, so its quite academical as these go on my westy today, so no matter what, they are not NOS any longer
Westfalia Helsinki 6/77
Winter bus 5/74
Earlybay 7 seater deluxe 11/69
Type3 9/63 1500N M264 panel
vworwhat
vworwhat is offline
PostPosted: Fri Apr 14, 2017 5:08 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Absolutely no damage to these unreinforced mounts. Guess I was just lucky... how do reinforced mounts of a 1200kg payload baywindow actually look like? Has anyone ever seen them? Are there any pics available?
Winter bus 5/74
mcdonaldneal
mcdonaldneal is offline
PostPosted: Fri Apr 14, 2017 6:12 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
vworwhat wrote:
That would be M103 then - heavy duty shocks, thanks. No further specification. Any idea whether these shocks required reinforced shock mounts? Or were they optinal fitted on std busses destined for use on bad roads?
Our Australian Kombi had M103 as an M code. I'm not sure if all Aussie buses had this, probably not. I'm fairly sure my rear shocks are still the originals, but I don't know what to take a picture of to help the topic Embarassed !
I'll try to crawl under and see what I can see...
1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
mcdonaldneal
PostPosted: Fri Apr 14, 2017 7:58 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Well, I don't know if this helps anyone but, the rear shocks on our Kombi are Cofap, I can't make out all of the part number, some of it seems to be 147 0794.
It has the M code for heavy duty shocks but of course these might be replacements. We got the bus at about 100,000miles.
Mounting points rusted but don't seem deformed.
vworwhat
vworwhat is offline
PostPosted: Fri Apr 14, 2017 8:05 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Cofab are not your original shocks, they should be aftermarket.
M103 should be coilovers i guess, at least that is what Ratwell suggests.
I can't spot any reinforcments Question. Or is the topmount bulkier?? That is difficult to make out ... would you mind to take a picture of the back side of the top mount. You will have to crawl underneath the bus with a flashlight though Embarassed
Winter bus 5/74
mcdonaldneal
PostPosted: Fri Apr 14, 2017 8:11 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
I can't spot any reinforcments Question. Or is the topmount bulkier?? That is difficult to make out ... would you mind to take a picture of the back side of the top mount. You will have crawl underneath the bus with a flashlight though Embarassed
Thanks vworwhat. I'm away for a few days, but I'll try for a pic when I get back.
vworwhat
vworwhat is offline
PostPosted: Fri Apr 14, 2017 8:44 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Thanks a lot, mate. Much appreciated Very Happy
Winter bus 5/74
otiswesty
otiswesty is offline
PostPosted: Mon May 01, 2017 7:44 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Not really Bay Window specific, but I have been looking for one of these for quite a while. Just found these in Europe and they're coming over pretty soon courtesy of a German buddy.
Plus the cord for the inductive pick up.
1978 Sage Green P22 Westfalia
Just a regular guy
notchboy
notchboy is offline
PostPosted: Mon May 01, 2017 8:18 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
What is that? A CB or microwave Question Laughing
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
mcdonaldneal
PostPosted: Tue May 02, 2017 12:29 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Could it be the fabled VW diagnostic machine?
alman72
alman72 is offline
PostPosted: Tue May 02, 2017 4:29 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
sweet VAG. (1367)
RONIN10
RONIN10 is offline
PostPosted: Tue May 02, 2017 8:12 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
A YouTube video explaining its use here:
https://www.youtube.com/watch?v=JMFSs72UqMI
Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle
airkooledchris
airkooledchris is offline
PostPosted: Tue May 02, 2017 10:00 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
I love stumbling across posts where my own content is displayed.
That was a cool little toy to play with. I only wish I had the pickup for the flywheel still on my case to check the timing with it (when I still had it.)
I eventually let it go to someone local to me. As with anything VW related, I wish I still had it Razz
1979 CA Transporter
Join the IAC Facebook group here!
notchboy
notchboy is offline
PostPosted: Tue May 02, 2017 11:42 am    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Oh wow. How cool is that. Nice vid airkooledchris Cool
1964 1500 S
VWDog
VWDog is offline
PostPosted: Tue May 02, 2017 1:30 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Uh-oh, now Jason's gotta have one... I mean two, no, three!! Wink Laughing
I do agree, great explanatory video airkooledchris. I never knew such a thing existed, but that's only showing my ignorance Embarassed Oh well, now I do Smile
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
notchboy
notchboy is offline
PostPosted: Tue May 02, 2017 4:07 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Does it work with FI?
I defiantly think its neat. I remember a big diagnostic center being for sale a couple years back in Texas? It was the size of a rolling tool box? But this little guy would do. I may have to get one Laughing
1964 1500 S
Xevin Premium Member
Xevin is offline
PostPosted: Tue May 02, 2017 4:24 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
notchboy wrote:
I may have to get three Laughing
Fixed that for you Jason Wink
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
[email protected] wrote:
notchboy
notchboy is offline
PostPosted: Tue May 02, 2017 5:33 pm    Post subject: Re: Baywindow "Rarest of the Rare" FAQ Reply with quote
Id fixate on making sure I had the attachments, the box it came in, the supplemental for dealers on how to use it, a book of matches from a dealer that used them, a cigarette smoked by the tech using it......
In my search for that Ill net two more incomplete units Wink Laughing
1964 1500 S
Page 98 of 101
