DustyTires Samba Member
Joined: November 17, 2005 Posts: 42 Location: Eugene, OR
Posted: Thu Mar 23, 2006 11:55 pm Post subject: Installing Big nut tranny in a 59 Kombi |
I am restoring a 59 Kombi to use as a daily driver, It is still 6 volt with a split case tranny and a 40 bastard. I have a big nut transmission that is 12v with reduction boxes (so I can stay stock heighth). I plan on running a 1600. single or dual
My question is do I need a adapter plate to mount the transmission to the frame and engine? If so where do I get one? Also is this going to be worth the effort?
Thanks for any info or help -Dusty |
NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Thu Mar 23, 2006 11:57 pm Post subject: |
You'll need the nosecone adapter. I believe you can get it from Busboys. I'm sure there are other makers of the adapter out there too.
The rest will interchange just fine. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Posted: Thu Mar 23, 2006 11:59 pm Post subject: |
I cant just swap out the nose cone from a split case tranny? |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Fri Mar 24, 2006 12:50 am Post subject: |
DustyTires wrote: |
NO |
NAES Samba Member
Posted: Fri Mar 24, 2006 8:45 am Post subject: |
The way the front of you transmission mount is made fits a crashbox trans which is totally different from the full synchro you want to put in. Ergo, you need the adapter mount. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Sat Mar 25, 2006 8:02 am Post subject: |
NAES wrote: |
The way the front of you transmission mount is made fits a crashbox trans which is totally different from the full synchro you want to put in. Ergo, you need the adapter mount. |
You will need to shorten the park brake cables too. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Mar 25, 2006 9:21 am Post subject: |
ToolBox wrote: |
Hi Volks,
Definitely! Check the yellow pages for "Wire Rope" supplier. They should have or can get proper sized swedged ends for the front of the cables. Then you cut the cables just short enough and have the new ends swedged on at the shop. |
Posted: Tue Mar 28, 2006 8:39 pm Post subject: |
ok, so I need a nose cone adapter and shorten my parking brake cables but what about the shift coupler? Also where do I find this nose cone adapter? I have looked and have had No luck finding any. And should I rebuild the reductions boxes myself or a shop? Thanks Again |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Wed Mar 29, 2006 7:39 am Post subject: |
DustyTires wrote: |
Hi DustyTires,
Do the RGBs yourself and with that experience you can repair them later with ease. Even out on the road as we have had to do! |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Tue Jul 10, 2018 10:16 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
I know there are many threads on this topic, but finding the best ones depends on the search terms used and I've sometimes forgotten what terms I previouly used to get at some of the better threads.
In any event, I may be putting a big nut into a '59 (VIN#473896)
Is this all I need?
https://www.wolfgangint.com/store/product/trans-adapter-2301265/
What about the nose cone and hockey stick? Does the big nut nose cone and hockey stick just mount to this adapter? |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Jul 10, 2018 10:22 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
SixVolt wrote: |
Is this all I need?
See this one too: https://www.thesamba.com/vw/forum/viewtopic.php?t=222339
E-brake cables are also another dynamic.
And another nosecone adapter option: https://www.thesamba.com/vw/classifieds/detail.php?id=1318980
EDIT: Given the chassis #, I can't remember if the nosecone adapter is needed. I know my April '59 would need one, if the mounting point wasn't already modified with a latter mount. Food for thought. But the cabling will more than likely needed modification in a '59 for a big nut mamajama. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Tue Jul 10, 2018 10:32 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Would also depend on if your bus was built for split case or tunnel. MAY59 was the switch over between those. _________________ In Stereo, Where Available! |
Posted: Tue Jul 10, 2018 11:09 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Eric&Barb wrote: |
Would also depend on if your bus was built for split case or tunnel. MAY59 was the switch over between those. |
Exactly. Progressive Refinements calls out 19 May 1959, starting at Chassis #469 447, so you might not need the nosecone adapter for going from split-case to tunnel trans, but I believe there will be some modifications required to the length of the e-brake cables. Good luck! _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
Posted: Tue Jul 10, 2018 11:23 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Appreciate those responses. And yes, I did pick up on those brake cable threads that indicate 123.5 inches which I understand to be the later cables shortend. I'm asking about the mount because I bought the bus in this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=180
On page 10 of the thread you can see where some prior owner of the tranny ground the bell housing a bit too much and got into the starter bushing cavity.
The seller went to this (small nut) trans because the big nut trans he had seemed to be a Frankenstinien hodge podge of adaptions that wasn't working.(He explains some of the details in the thread).
I've been saving a '66 big nut drum to drum core for just this opportunity. I had a small nut 59 in the past with stock 36er and its not conducive to a freeway on-ramp.
Since my VIN # is after that cut off, I'm hopeful I only have to deal with the cables. I'm going up to trailer it home tomorrow, so I'll know more then. |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Tue Jul 10, 2018 12:24 pm Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Something to keep in mind if you end up having to use the adapter is the wolfgang part scoots the trany back ever so much and has been known to create a toe in issue. The lolly pop from Wagens West does not cause this. I used the wolfgang one back in the day and it did the job on lowered buses but I have made a point to use the lolly pop on stock buses. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue Jul 10, 2018 12:38 pm Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Appreciate that insight. I'll post a pic of what's there when I get it back down to Ohio. |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Tue Jul 10, 2018 5:05 pm Post subject: Re: Installing Big nut tranny in a 59 Kombi |
Okie Adam wrote: |
Something to keep in mind if you end up having to use the adapter is the wolfgang part scoots the trany back ever so much and has been known to create a toe in issue. The lolly pop from Wagens West does not cause this. I used the wolfgang one back in the day and it did the job on lowered buses but I have made a point to use the lolly pop on stock buses. |
I have used the wagenswest lollipop, the concept1 adapter and the Wolfgang as well as hard mount. The best option is the wagenswest lollipop. It is the only one in my experience that does not create a toe-in situation and fit is good. |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Thu Jul 12, 2018 2:10 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
I thought the Bastard 40 and the Fully Synchronized Tranny came out at the same time? Odd to have a Bastard on a split tranny? _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
cww Samba Member
Posted: Thu Jul 12, 2018 4:55 am Post subject: Re: Installing Big nut tranny in a 59 Kombi |
WW lollipop worked on my 58. |
