volksaddict Samba Member
Posted: Fri Mar 24, 2006 5:49 am Post subject: pre 58 backing plates on upside down? |
Prior to '58 or so, did they put the rear brake backing plates on upside down? That is, the wheel cylinder is on the bottom and the entrance for the e brake cable is on the top with the cable comming in from the REAR of the car? Longer steel lines to bend around the axle and reach the wheel cyl. Sure looks odd that way.
Seems the 56 and 57 cars I have here are like this and the 58 and 59's are "normal", at least what I'm used to seeing. Or were the po's of 2 different cars from 700 miles apart just on drugs? |
Buggeroff Argumentative Bastard
Joined: October 16, 2004 Posts: 1124 Location: Lake of the Ozarks, Missouri
Posted: Fri Mar 24, 2006 2:26 pm Post subject: |
No drugs involved, my 57 has the exact same setup.
Chris. _________________ "Chris of the Ozarks"
Headlinerless 57 Ghia
Thread deleter extrordinaire. |
Posted: Fri Mar 24, 2006 2:41 pm Post subject: |
Guess I should've checked here before I started messin' with it. Easy enough to put back though.
But what a goofy setup - wheel cylinder and bleeder valve on the bottom, brake cable going in backwards on the top, steel lines all wiggled around, just hangin' there.
Sure looks funny... |
Posted: Fri Mar 24, 2006 3:40 pm Post subject: |
You would think that air would be easier to expell from the system if the wheel cylinders were at the higher point.
I guess like everything else, they had their reasons.
Posted: Fri Mar 24, 2006 8:26 pm Post subject: |
Yeah, reasons why they changed things.
If I wasn't so obsessed with stock... |
retrowagen Samba Member
Posted: Fri Mar 24, 2006 8:39 pm Post subject: |
The change in brakes co-incided with a change in wheel cylinder design and size of brakes... the same equipment change as between Oval Window Beetles and the newer "Square Window" 1958's. On the Karmann-Ghias, the changeover date was September 23, 1957. My KG was built on that exact date and had the earlier style of brakes... mine must have been put together early in the day! _________________ David Ruby
President, Karmann-Ghia World Club |
Posted: Sun Mar 26, 2006 6:39 am Post subject: |
Just for future reference, for others reading this down the line and for myself when I forget this detail; the early style e brake cables are longer that the later ones, to acomodate the trip around the top of the axles. Since the PO of this car replaced the cables with the later style and I don't have any spares to put the right ones back on, the car is getting the backing plates installed "right side up". I'm calling it a period upgrade. |
