mr69 Samba Member
Joined: March 03, 2006 Posts: 179 Location: Long Beach CA
Posted: Fri Mar 24, 2006 12:00 pm Post subject: Praise the lowered |
whats better airbags or hydraulics for lowering. i need to be able to clear a dip in my driveway but i want it lowered for crusing. |
steven wood Samba Member
Joined: March 14, 2004 Posts: 1647 Location: Virginia, NOT West Virginia!
Posted: Fri Mar 24, 2006 12:12 pm Post subject: |
it depends, If you going to run hydraulics, then you need to use accumalators so the ride isn't as bad. If you are in a cold climate then the seals in the cylinders go bad and the guides break. If you use airbags, then you can buy all of the parts and brackets already prefabbed through KCW. Even though hydraulics are Olde School, I would run hydraulics any day of the week! |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
Notchback65 Samba Member
Joined: March 23, 2006 Posts: 251 Location: Houston, Texas
Posted: Fri Mar 24, 2006 2:46 pm Post subject: |
Get the airbags,because with hydraulics you need a ton of batteries.Do you really need all that clutter in a small space. |
sled Samba Member
Posted: Fri Mar 24, 2006 7:11 pm Post subject: |
you dont need any more than 2 batteries (24 volts) for hydraulics
you dont need accumulators for a good ride
if all you want to do is go up and down slowly to clear driveways and speed bumps then either will work just fine, take your pick
PM me if you want explanations and details of either. |
67stang302 SBS Hit Squad
Posted: Fri Mar 24, 2006 11:01 pm Post subject: |
anybody running bags with really high horse power? I have a project comming up and the curent plan is using a 300hp subie motor and I still want a lowered stance but like the idea of adjustability of bags.
Sorry for the thread jack _________________
EverettB wrote: |
Hondaz rulez my lifez |
SBSeven 1 YR and still going
59 Kombi laying beam
64 type 34 |
