westy decal
aguabonita
aguabonita is offline
PostPosted: Sun Mar 26, 2006 6:09 pm    Post subject: westy decal Reply with quote
is there any way to apply these decals on your fiberglass top without getting those microbubbles? i can see the 'translucent' decal part around the letters really easily.
kevin
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Sun Mar 26, 2006 8:29 pm    Post subject: Reply with quote
Having just installed these myself two days ago, I have one question. By translucent part, are you referring to the cover layer that should be removed after sticking the letters on the van?
aguabonita
PostPosted: Sun Mar 26, 2006 8:47 pm    Post subject: emmm Reply with quote
ahhh, i guess so. woops. does that stuff just peel off?
aguabonita
PostPosted: Sun Mar 26, 2006 8:48 pm    Post subject: Reply with quote
also, does the front sticker go over the one of the bolt? does it mess up the sticker?
Yellow Rabbit
Take your time as the decals want to stick to it. I used a soft rag to apply pressure to the decal after removing the protective layer.
Michael J
Michael J is offline
PostPosted: Sun Mar 26, 2006 8:58 pm    Post subject: Reply with quote
Here is a picture of my 90 Syncro Westfalia to show you where, in relation to the bolt, the front emblem gets placed.
Michael J
fifty-five
Samba Crash Test Dummy
fifty-five is offline
PostPosted: Sun Mar 26, 2006 9:02 pm    Post subject: Reply with quote
If you have concern of messing the decal up take it to your local sign shop and have them install it. They shouldn't charge more than 5-10 bucks unless you bring in your bus really dirty. Don't worry about the bubbles, they will fall out in the sun. If you were here in NC I would do it for free.
aguabonita
PostPosted: Sun Mar 26, 2006 9:44 pm    Post subject: synchro Reply with quote
I might go out and buy a Synchro sticker just the looks of it. Those are bad ass.
mrchris42
mrchris42 is offline
PostPosted: Mon Mar 27, 2006 9:07 am    Post subject: Reply with quote
I had decals applied to my work vehicle recently and watched.
They did it something like this - http://www.autobodyart.com/howtoapply.htm
Also they used a heat gun and a plastic scraper/fingers to remove the old decals very quickly
