lovedavdubs Samba Member
Joined: April 30, 2004 Posts: 1597 Location: New York, NY.
Posted: Sun Mar 26, 2006 6:17 pm Post subject: POR-15 update. MOTHER @#$%ER!!!!! |
Well, it's been two weeks since I installed my new exhaust wrapped in about 4 coats of POR-15. I crawled under the van yesterday to replace my leaky valve covers and gaskets and this is what I found
I followed the instructions to a 'T'. I'm gona contact the manufacturer about this and see what they say. I'm not happy.
On a lighter note I finally got my much needed stock valve covers installed on the van, thanks to Dan from Syracuse No more oil in the heater boxes
After doing some digging I found out that after market valve covers such as the ones I have often require special gaskets that are specifically designed to fit them correctly. That's why the oil has been passing right through my stock gaskets and dripping down on to my heater boxes. As you can see from the photo, the stock gaskets just wont stay put. This is what I discovered when I removed the drivers side cover. This had also happened in the passed. A piece of the gasket actually broke off inside and it caused me a collapsed lifter way out in PA.
_________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
Phil G Samba Member
Posted: Sun Mar 26, 2006 7:32 pm Post subject: |
It's hard to beat ceramic coating inside and outside the pipes, but cost . .
I had really surprising results once about 10 years ago painting a pair of iron Corvette manifolds using a few cans of Pep Boys High-temp exhaust spray-paint. It ended up a silvery white color once cooked well. Still looked good 5 years later when I sold the car. And it was cheap! In fairness though, those manifolds were better protected not being under the car, and I had also had free access to an ultra-high pressure water-blaster at the time. The advantage of blasting with UHPW over sand is that all rust and debris are removed leaving only raw metal behind. Sand on the other hand imbeds mineral into the metal's surface. That's why even a hint of moisture on sandblasted steel will cause rust immediately. I've decide to build my next exhaust system using thick-wall stainless. To hell with all coatings . . .
Here's a few pictures of the last VW exhaust system I created. I'm really proud of how it came out - more importantly how it makes power, but I feel like a total dumb-ass for not building it using stainless tube. It would have only added about $125.00 to the material cost which is certainly cheaper than a Jet Hot ceramic coating, and no more labor. I actually prefer welding stainless. I had to build this one because I couldn’t get anyone to do the job the way I needed it done. Transverse collector orientation, well tucked, long 1 5/8” primaries, high flow muffler, medium wall, thick flanges welded inside and out, etc. Everyone whined that there wasn't enough room, etc. Sometimes the world just isn't up to our expectations! . .
Sorry to hear about the POR (P-O-S?) though. It's a bummer when you put time and care into a project and it dumps on you due to no fault of your own. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Sun Mar 26, 2006 10:01 pm Post subject: |
We did a beetle exhaust last year with the high heat POR20 last year. Followed the directions, spent a bunch of money on their chemicals and the stuff peeled off in big flakes in a week.
Went to the other guys and bought a $7 can of high heat exhaust paint and its still on there.
Complained to the company and got a gee thats too bad. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
benmac Samba Member
Posted: Sun Mar 26, 2006 10:15 pm Post subject: |
man seeing this is making me jelouse. this summer im getting a new exaust system. good luck lovedavdubs with fixing that |
Posted: Sun Mar 26, 2006 10:34 pm Post subject: |
W1K1 wrote: |
Complained to the company and got a gee thats too bad. |
Who were the "other guys"? _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
davidorchard Samba Member
Joined: February 02, 2006 Posts: 12 Location: austin, tx
Posted: Mon Mar 27, 2006 8:12 am Post subject: |
Phil G, that exhaust is increadible, if you haven't heard that enough yet. very nice! |
Randy in Maine Samba Member
Posted: Mon Mar 27, 2006 8:50 am Post subject: |
Quote: |
Everyone whined that there wasn't enough room, etc. |
They were right. There is no room in there.
Nice job! Looks good. |
danfromsyr Samba Member
Posted: Mon Mar 27, 2006 9:02 am Post subject: |
LD that bend gets Hella hot.. it's a heavier cast steel/iron so it'll take it as long as the weight of your muffler is always supported,
mine failed there because the strap failed and the bend had to carry the weight of the muffler.. it didn't like it.
the other POR 15 parts should hold up better.
also make sure you get your van running as close to right as possible.
lean will run a extra hott exhaust, rich will run a cooler exhaust, but increase the risk of backfires (if given leaks) and kill your Catylic converter.
glad the OEM VCs worked. now just check and change the gaskets often, your fresh air depends on it.
dan |
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Mon Mar 27, 2006 9:14 am Post subject: |
If it's any consolation, I had my brand new crossover pipe ceramic coated (yes, inside and out). Drove it straight from the store where I bought it to the coating shop. Damn thing is rusting out like there was no coating at all, right at the U-bend. I think it's just poor-quality metal, plus the heat generated from turning the exhaust around 180 degrees.
I'm hoping it will last long enough until Jake Raby finishes development on his header system. _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Mon Mar 27, 2006 10:04 am Post subject: |
The funnny thing is that just this weekend I was making "the list" of things to do to the van in a couple of weeks when it emerges from its hibernation. One thing is what to do to the used exhaust I have to put on. Up to this point I feel that there has not been sufficient data supporting the use of POR-15. It seems that most of the work people have doen with this product has been unsuccessful. It looks to me that the best thing for this ehaust is to leave it bare and not let it touch salt. I think I might just throw it on as is and hope for the best.
Sorry about the failure ldvdubs! _________________ 82 Westy: Air is cool! |
r39o Samba Polizei
Posted: Mon Mar 27, 2006 11:24 am Post subject: |
Try the high temp paint you get at a FLAPS. The kind that you need to bake in by running the car to full temp within some amount of time after applicaiton. The higher the temp rating the better. I think you get 1200 or, maybe, 1800 degree paint. You may have to reapply from time to time. Better than all that rust, though.
Then again Googling would help too, I guess.
Best of luck,
Walt... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Mar 27, 2006 12:10 pm Post subject: |
use an old timers solution..
Stove polish.. made for wood stoves, keeps them black.. but still doesn't combat RED glowing metal , i doubt anything would stay on a surface that hott.
other solution is rub on some 'olive oil' time to time, let it smoke and it'll 'temper' to a nice nonrusting black..
also a wood stove trick that your not liekly to find in the big city.
both of these need to be 'refreshed' time to time which isn't that big of a deal while camping.. once a month reach back rub on some oil or polish.
dan |
brooklynvan Samba Member
Joined: February 08, 2006 Posts: 342 Location: Brooklyn NY
Posted: Mon Mar 27, 2006 2:42 pm Post subject: |
I like that idea, like a cast iron skillet.
Canola Oil might be better, it's got a higher smoke point than Olive, and doesn't smell as acrid when burned.
seems a little tough though to have to oil your whole exhaust every month or so.
if you used oil from a deep fryer you could pretend you were a veggie oil diesel |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Tue Mar 28, 2006 8:06 am Post subject: |
Didn't work for me, nore did the dupicolor header paint from Autozone.
The people that used to swear by the POR products now say this is the stuff: http://72.10.43.141/high_temp.htm
I'm not wasteing any more money on my cheap exhaust. _________________ My Art:
http://www.instagram.com/flynn8552/ |
Posted: Tue Mar 28, 2006 9:32 am Post subject: |
stove polish keeps my baja mfflers nice and black..
they were already rusty so paint wasn't going to stick..
i just rub a lil on every now and again.
wear latex gloves.. it will stain.. |
Posted: Tue Mar 28, 2006 10:39 am Post subject: |
I'll give the oil a shot. But I'm through with the expensive "High temp" paints and stuff. What a waist of time and money.
P.O.R. = Peels off rapidly _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
Posted: Tue Mar 28, 2006 11:39 am Post subject: |
brooklynvan wrote: |
seems a little tough though to have to oil your whole exhaust every month or so. |
Peanut oil has an even higher smoke point. Recommended for stir-frys. In fact, you could pick your exhaust oil based on your culinary mood of the moment.
Here's a thought: maybe the valve covers are supposed to leak in order to provide a nice protectiive film of oil on the exhaust system, and all of our efforts to plug up leaky valve covers have been in vain. Damn, but those VW engineers were clever. _________________ Present:
Back in the day:
'72 Super Beetle
Posted: Tue Mar 28, 2006 11:51 am Post subject: |
SlowLane wrote: |
Peanut oil has an even higher smoke point. |
P.O.R. = Peanut oil prefered?
SlowLane wrote: |
Here's a thought: maybe the valve covers are supposed to leak in order to provide a nice protectiive film of oil on the exhaust system |
And my lungs _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Tue Apr 04, 2006 12:07 pm Post subject: |
It looks like there is paint under your POR-15. I thought POR-15 was to go over BARE metal ? _________________ Midwest Autosavers, Inc. Woodstock, IL |
Posted: Tue Apr 04, 2006 3:34 pm Post subject: |
DrDarby wrote: |
It looks like there is paint under your POR-15. I thought POR-15 was to go over BARE metal ? |
Nope, if your looking at my picture, that’s bare metal under there. I had the entire system sand blasted prior. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
