newbi ? - headgaskets
aguabonita
aguabonita is offline
PostPosted: Mon Mar 27, 2006 11:54 pm    Post subject: newbi ? - headgaskets Reply with quote
Hi, I recently bought an '87 westy and I would like to know how well my headgaskets are holding up. What is a "easy" way of determining this? Should I just watch the coolant level?
thanks Question
weinerwagen
weinerwagen is offline
PostPosted: Tue Mar 28, 2006 7:24 am    Post subject: Reply with quote
Good rule of thumb:
1. Engine overheats after all the fluid drains out from under the van
2. Puddles of green (blue for the pureist) (rust for the lazy) fluids under the van.
4. Dripping fluid from the head gasket next to the casing.
5. Whiff of anti freeze smell when you walk past the engine vents.
6. Red warning lite on the temp guage starts flashing while on a long uphill
pull far far away from the nearest German Auto Repair.
7. (Diesel) Milky coloured motor oil.
8. (Diesel) Bubbles in water bottle when started cold.
9. Gyser of hot fluid shooting out the water bottle when cap is removed.
Just a few symptoms....Been there done that.... Shocked
mrchris42
mrchris42 is offline
PostPosted: Tue Mar 28, 2006 11:03 am    Post subject: Reply with quote
You could just replace the gaskets, then you would know that their new!!
I like the suggestions above (WW)!
I don't think you'll ever know -- until they're leaking. You can also make sure both heads are grounded to the block and/or firewall to help prevent electrolysis. Also make sure to change the coolant every two years or so to slow the degradation/corrosion process.
weinerwagen
PostPosted: Tue Mar 28, 2006 11:15 am    Post subject: Reply with quote
Good grounds on the engine help slow down the messy old forest growth that occurs between the heads and the case
levi
levi is offline
PostPosted: Tue Mar 28, 2006 4:43 pm    Post subject: Reply with quote
clean the underside of the engine, then you'll be able to see after running around a bit if there are any leaks.......and where.
Here's a suggestion if you're a new owner:
Before you worry too much about anything else, replace that fuel line.... all of it. Even if it looks brand spankin new Very Happy
aguabonita
PostPosted: Tue Mar 28, 2006 4:49 pm    Post subject: why the fuel line? Reply with quote
May I ask why, i'm very new to this (as you can probably tell). Smile
levi
levi is offline
PostPosted: Wed Mar 29, 2006 12:40 pm    Post subject: Reply with quote
Well....if I still had all the photos of burnt-to-a-crisp vanagons, I would just post about 10 of those.
These vanagons are 20 years old now, and a lot of them have the original fuel lines, leaking. Very common are leaks up by the front gas tank, and these are too dangerous. But if you get a leak at the back, by the engine, especially that 20 year old plastic connector that just falls to pieces when you touch it......
