dragonfire709 Samba Member
Joined: July 13, 2005 Posts: 154 Location: Hampshire, UK
Posted: Tue Mar 28, 2006 9:59 am Post subject: Pop top adjustment |
I've had a good old search and cant seem to find an answer to this one!
I'm trying to find out if its possible to adjust the height at which the Westfalia roof sits when popped.
The reason being is that i have just fitted a new canvas which is slightly too slack all round. I am thinking that if we can adjust the height of the roof by about 1cm then that would pull the canvas taught. _________________ My name is Roy |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Raynor Shine Samba Member
Posted: Tue Mar 28, 2006 11:10 am Post subject: |
I replaced my canvass a couple months back with similar concerns It seems to be fitting better although not that "stretched" tight look. I was told over time it will. Keep your eye on it. |
Posted: Tue Mar 28, 2006 3:12 pm Post subject: |
I thought it may get a bit tighter over time, how loose was yours roughly when you first fitted it,Raynor?
Mine is hanging down by about 1cm on each side.
Oooo er missus. _________________ My name is Roy |
aguabonita Samba Member
Joined: November 27, 2005 Posts: 267 Location: Monterey, CA
Posted: Tue Mar 28, 2006 4:51 pm Post subject: |
Is there any way to buy another cushion for the top to extend the bed? I am 6'3" and its a bit short. |
ncwesty Samba Member
Joined: February 08, 2006 Posts: 58 Location: Durham NC
Posted: Tue Mar 28, 2006 6:30 pm Post subject: |
Kevin675, My friend made a platform out of pylwood and some eggcrate mattress stuff. Once your up in the bed you can lay this platform down it woul rest on the side grooves, you end up sealing yourself in the top bunk. He liked the extra few inches it gave him. Maybe something like that would work |
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Wed Mar 29, 2006 5:54 am Post subject: Re: Pop top adjustment |
dragonfire709 wrote: |
The reason being is that i have just fitted a new canvas which is slightly too slack all round. I am thinking that if we can adjust the height of the roof by about 1cm then that would pull the canvas taught. |
Maybe i am missing something here, but when i replaced my canvas, i just pulled the excess through the top trim bits. Sure there is a bit hangning down, but you can't see it (well, except for the front when the top is popped), and if it really bothered me, i'd just cut it off.
My canvas installed tight and wrinkle free from day one.
-Damon |
Posted: Wed Mar 29, 2006 10:01 am Post subject: |
I was hoping to avoid having to pull the slack through as i was concerned abou endeing up with an untidy edge at the top. Luckily i have been able to shrink the fabric slightly by soaking it with a hose and drying several times. This seems to have taken a lot of the slack up.
