Speedo noise
aguabonita
aguabonita is offline
PostPosted: Wed Mar 29, 2006 10:35 pm    Post subject: Speedo noise Reply with quote
Anyone ever get a weird wawawawa sound sometimes that sounds like it is coming from the speedometer? I get it about 1/2 the time I drive around. I pulled the speedo cable and dripped some lube down there and it seemed to help but it has recently come back.
Kev
thumpergti84
thumpergti84 is offline
PostPosted: Thu Mar 30, 2006 6:01 am    Post subject: Reply with quote
What kind of lube did you use??Could just get a new cable.
psych-illogical
psych-illogical is offline
PostPosted: Thu Mar 30, 2006 10:11 am    Post subject: Reply with quote
This winter mine started squeeling pretty loudly when it's cold outside. I thought is was my cable but if I pull over and disconnect the cable from the speedo it stops. The cable is still spinning in it's housing when I do this so it leads me to believe that it's something in the speedometer itself. I've got another speedo that I'm going to try to swap out and see if that helps. Past experience tells me that 9 times out of 10 it's the cable but if it turns out to be the speedo itself, I'm going to have to send mine off to get it cleaned and lubricated (I want to keep as close to original mileage as possible showing on the odometer). I'll try a place called Palo Alto Speedometer for service. I've sent my BMW speedos to them before and I think they service all kinds.
83 1/2 Westy waterboxer
'57 Beetle-sold Sad
Coupla '81 BMW motorcycles (R80G/S; R100RS)
'96 BMW R1100GS
weinerwagen
weinerwagen is offline
PostPosted: Thu Mar 30, 2006 10:36 am    Post subject: Reply with quote
YUP! My 88 Carat sent out the waaaawaaa waaaa. Remove the top, take the
cable off from the back of the cluster...
Get some GOOD lubricant with a plastic hose that will direct it down towards and inside the cable housing...fill liberally.
Retired attorney--Tort King.
aguabonita
PostPosted: Fri Mar 31, 2006 4:47 pm    Post subject: Reply with quote
Did you use graphite or a lube like 3 in 1?
weinerwagen
PostPosted: Fri Mar 31, 2006 4:52 pm    Post subject: Reply with quote
NOPE...Liquid Wrench --the good stuff, Laughing
