71vwsquare Samba Member
Joined: December 27, 2005 Posts: 66 Location: medford,or
Posted: Tue Apr 25, 2006 7:35 pm Post subject: |
COFBack wrote: |
I bought the CB TIII kit (Linkage, Manifolds, Cleaners, Tops)
High quality, good fit.
Did take a while to get to me though.
I removed the whole thing cause I couldn't get it to work with the automatic transmission. Still want to give it another try though.
that looks like a really clean set up....there shouldnt be any problems with hooking it in a manual right....i wouldnt think that there would be...i am goin to have to check that site out...so with that set up you could probably use any style carbs for it huh...thanks |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Tue Apr 25, 2006 8:57 pm Post subject: |
those are EMPI HPMX 40
weber 40 IDF clones
Weber 44's will fit also.
Dunno about anything else.
I'd buy a used set of Webers before i bought a new set of the EMPIs
Manual should be NO problem _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
Hornman Samba Soul Surfer
Joined: April 16, 2002 Posts: 1062 Location: Ventura, CA
Posted: Tue Apr 25, 2006 10:28 pm Post subject: |
COFBack, why don't you go with a manual? I know, more bucks... _________________ Michael
1969 Fastback |
Posted: Wed Apr 26, 2006 6:14 am Post subject: |
I seriously considered it but the Pans are different. So I'd either have to find a manual pan (which I might do) fix it up then swap the body.
Or
Modify the existing pan for a manual. Which would be $$ and down time for the vehicle.
rms _________________
iowegian wrote: |
Posted: Wed Apr 26, 2006 7:23 am Post subject: |
Different pans? Really? Wow, what was \X/ thinking? Not too logical, huh? _________________ Michael
1969 Fastback |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Apr 26, 2006 11:01 am Post subject: |
Hornman wrote: |
Different pans? Really? Wow, what was \X/ thinking? Not too logical, huh? |
No provisions for a clutch cable inside the frame. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Apr 26, 2006 11:06 am Post subject: |
Use a hydraulic clutch conversion. Not stock, but easier than swapping pans. Lots of dunebuggy guys use them. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Apr 26, 2006 11:37 am Post subject: |
Tram, more info??
Is it like running another hyd line next to the brake line then tying it into a master cylinder next off the trans.
Guess I could search the Offroad Forum. But I'm afraid of USMCcord's short shorts.
RMS _________________
iowegian wrote: |
Posted: Wed Apr 26, 2006 12:18 pm Post subject: |
COFBack wrote: |
RMS |
thats awesome what a great chuckle...thanks for the info dude |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Apr 27, 2006 12:24 am Post subject: |
COFBack wrote: |
Is it like running another hyd line next to the brake line then tying it into a master cylinder next off the trans. |
Exactly, but it's a slave cylinder next to the trans. The master is by the pedal, just like a brake master. So, you'd need a new pedal assembly. You won't be able to use the stock pedal, unless you do a little engineering. Would be easiest to change over the whole pedal assembly to a hydraulic unit, where both the brake and clutch are hydraulic.
Something like this:
I think that one is running a hydraulic fuel pedal as well.
I know Martin @ The DDB has done this for customers. There may be pics on http://www.theddb.com or on The Samba under his name. |
Posted: Thu Apr 27, 2006 6:13 am Post subject: |
notched, that setup looks like forward controls for a harley. Pretty cool.
Nice to know there is an option to go hydraulic, rather than pan swap. _________________
iowegian wrote: |
Posted: Thu Apr 27, 2006 11:07 am Post subject: |
Looks like ISP carries a simpler kit. You might have to drill a hole in the clutch pedal assy. like the one on the brake pedal for the M/C rod, and do some other cutting/ mods, but I've heard that these work really well.
http://www.vwispwest.com/specials-ga321000.htm _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Apr 27, 2006 12:08 pm Post subject: |
That ISP hydraulic clutch set-up is slick. Looks plug 'n play. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Tue May 30, 2006 10:29 pm Post subject: |
Hey Wa11ace, where ya hiding? Got that Fasty on the road yet? _________________ Michael
1969 Fastback |
