emptyspaces Samba Member
Joined: April 01, 2006 Posts: 20 Location: Syracuse NY
Posted: Sat Apr 01, 2006 10:00 am Post subject: Engine noise '84 vanagon what to look for when buying |
Hello, I am going to look at an 84 Vanagon GL, the owner claims he put it up for the winter last year, and this year it isn't running on all 4 cylinders. He says he thinks its a stuck valve (I have delt with the the old 1600cc. aircooleds, but never with a wasserboxer) Is this possible? I haven't heard it for myself yet. What is a fair price? Where is the rust? Said he replaced the distributor last year because the hall effect switch kicked the bucket. Any info is informitive
Regards,
Tim |
weinerwagen Samba Member
Joined: May 10, 2004 Posts: 1548 Location: Monterey, CA -Laguna Seca--Coats, Kansas
Posted: Sat Apr 01, 2006 10:26 am Post subject: |
Stuck valve? probably not, most likely a bad lifter or no compression
I'm a risk taker, for the right price one could talk me into anything.
Maybe the load on the lifter is too much, some experimentation might be in order but be prepared to do a head or lifter work if you do decide to buy it
900 bucks if the vehicle has good title,
you get those who think they have an oil well in the back seat, give us a good idea what you are working with and we can be better in a ball park figure _________________ Retired attorney--Tort King. |
btlbugtyp1 Samba Member
Joined: March 15, 2006 Posts: 202 Location: Ridgeley, WV
Posted: Sat Apr 01, 2006 11:43 am Post subject: |
i recently bought my 82 aircooled brick with a bad lifter and leaky flywheel seal ...but it was $200 and very nice being from AZ ....ie no rust and all straight ....my only complaint is that the speedo isnt working now .....but it will soon thanks weinerwagen |
Posted: Sat Apr 01, 2006 12:28 pm Post subject: |
it's in the mail....
the rear main is easy too. pop the trans, do a clutch while you are there, once that flywheel is off you can do the seal
don't forget the 0 ring on the flywheel
biggest pain I found other than my lower back, was the axle bolts and nuts
PITA. _________________ Retired attorney--Tort King. |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Sat Apr 01, 2006 10:10 pm Post subject: |
They rust anywhere two panels are joined. The seam rust is a bigger problem than it looks. In my book, a bus with a three cylinder engine is one that could be bargained cheap, shops charge $60HR plus to say hello. |
Posted: Sun Apr 02, 2006 6:48 am Post subject: looked at it |
took a look that the vanagon yesterday, very very clean, one small dime sized spot of surface rust on the outside of the passanger rear fender flair. Runs perfect, no knocking, no ticking, just sounds like a 4cylinder vw running on 2cylinders. Apparently the mechanic tested compression, and two cylinders (on one side) are pressureising the intake (ie, valves are not shutting). Underside of engine is spotless, no oil leak, no coolant leaks. Only forseeable problem besides the engine is that its due for tires, and the top or the windshield is cracked. asking $1500, said no less that $1000...I offered $750, he counteroffered $800......good deal? |
Posted: Sun Apr 02, 2006 3:32 pm Post subject: |
just for $hits ahd giggles you ought to try looseening the suspect valves so they have a little lash and see you get compression back ...it may just be an adjustment .....you may get lucky you never know |
Posted: Sun Apr 02, 2006 3:47 pm Post subject: |
btlbugtyp1 wrote: |
I was thinking the same thing, back off the load on those exhaust valves
see if compression returns
Repair manuals have 2 long turns down, but sometimes.....
I've seen 1/2 and that's where it will run at
seems odd but I bet the load is too tight _________________ Retired attorney--Tort King. |
Posted: Tue Apr 04, 2006 7:58 pm Post subject: |
what do you mean by less load? backing off the valve adjustment? or less load as in less backpressure from the exhaust system. How likely is this the problem? And if it is a valve or lifter or something...how much $$ (also I am way out of touch with VW parts- I'm still in Rocky Mtn. Motor Works times) Where can I get what I need?
Thanks so much!
Regards,
Tim |
Posted: Tue Apr 04, 2006 8:10 pm Post subject: |
back off the load on the lifter,
turn if back a bit _________________ Retired attorney--Tort King. |
r39o Samba Polizei
Posted: Wed Apr 05, 2006 1:52 pm Post subject: |
weinerwagen wrote: |
PITA. |
Axles are trival. What pain is there to removing some bolts, especially if you use an air ratchet?????? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
