wiartonallan Samba Member
Joined: March 25, 2006 Posts: 165 Location: Wiarton Ontario Canada
Posted: Mon Apr 03, 2006 6:28 pm Post subject: 8" wide alloys |
Turns out the MB S320 wheels I purchased on eBay are 16* 8" CT35 and not 16*7.5 as I though.
Has anyone had experience fitting such wide rims on a Westfaia. What hardware is required or are these wheels simly too wide?
Ian |
Posted: Mon Apr 03, 2006 7:50 pm Post subject: |
I'm running 18x8s on my Bus. They have a 32mm ET and fit with no spacers. I did have to nick the ends of the upper control arms a bit though. Depending on which tire you choose, I would venture to say that they should work on your Westy with somewhere between a 5 and 10mm spacer.
A 225/55/16 has an average section width of 9" (outer sidewall to outer sidewall). This is almost exactly the same width of your wheels (outer lip to outer lip). Pull a front wheel and install one of the Mercedes wheels. Then place a straight edge straight up from the outside edge of the inner wheel lip. This will tell you how much of a spacer you will need for the tire to clear the upper control arm. Of course, if you want wider tires, you'll have to take this into account. It's also a good idea to look up the actual section width of the tire that you plan on running to make sure that you are comparing apple to apples.
Another plan is to install the tires that you want onto the Mercedes wheels and then install the wheels onto the Bus using common fender washers (as spacers) and long lugs. Add washers until you have the correct clearance to the control arm. Then remove the wheel and washers and measure the thickness of the stack of washers. This is how thick of a spacer you will need. Don't drive the bus with the washers installed, it's not safe. Just use them for measurement purposes.
I have less than 1/16" between the upper control arm and the wheel rim. These wheels have been on the Bus for over 3 years now with no clearance problems at all. In order to keep the tires under the fender lips, try to keep the clearance from the tire to the upper control arm down to no more than 1/8".
8" wheels on a Vanagon is a tight fit but with the right measurments, it can be done. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
r39o Samba Polizei
Posted: Mon Apr 03, 2006 8:19 pm Post subject: |
18x8 has a better chance of fitting than 16x8 as the front end parts get further in the higher up you go.
I am getting close to trial fitting a set of S500 16x7.5 wheels. They have 225/60-16 tires on at the moment which look awfully meaty to me. I think I need a narrower tire. But can not quite decide what, exactly, yet.
I am only using the 7.5s as they were a gift. Otherwise I would be shootting for 7 or maybe 6.5.
*BUT* I am told they should fit with a small front spacer. Later that spacer will be the rotor for my big brakes I am working on.
We'll see... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
atarasi Samba Member
Joined: October 19, 2004 Posts: 320 Location: Seattle, WA
Posted: Tue Apr 04, 2006 7:51 pm Post subject: |
I installed 16 x 7.5 Borbet wheels (at 19lbs each) with 205/60s. Gowesty recommends 215s, but I thought that might look too balloon-like. No clearance issues with a 12mm spacer. They revolve 785 per mile, while the stock tires are 809. The 215s revolve 771. |
r39o Samba Polizei
Posted: Wed Apr 05, 2006 1:48 pm Post subject: |
What brand and model 205/60s? I need for a Westy so the load index is important to me.
TIA,
Walt... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Wed Apr 05, 2006 7:55 pm Post subject: |
They are Bridgestone Potenza G009. Rated at 1389 lbs at 44lbs of pressure. Nice looking tires. Wear is at 460 I believe. |
r39o Samba Polizei
Posted: Thu Apr 06, 2006 9:04 am Post subject: |
Load Index not high enough for a Westy.....92H
I am strongly considering the VancoContact 2 in a 215/60-16 99H. I just have to find pricing.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
