Best set-up for Aux Battery |
Factory installed Relay (GoWesty type kit if N/A) |
45% |
[ 5 ] |
Isolator |
18% |
[ 2 ] |
Seperator |
0% |
[ 0 ] |
Voltage Sensing Regulater (VSR) |
36% |
[ 4 ] |
Automatic Charging Relay (ACR) |
0% |
[ 0 ] |
Total Votes : 11 |
gmasterv Samba Member
Joined: June 18, 2005 Posts: 56 Location: Nashvegas, TN
Posted: Thu Apr 06, 2006 12:36 am Post subject: Best set-up for Aux Battery |
After reading through years of posts/debates on the best way to configure (i.e. connect, isolate and charge) your aux batteries, I'm actually more confused now than ever? relay? Voltage sensing relay? Autmatic Charging Relay? separator? Isolator? manual switch? heck, I'm not even sure what all these mean and I know some overlap...
I just want to know how to keep the on all night and drive away in the morning!
Anybody have any experience with this relay made by Blue Sea Systems? A boating enthusiast friend of mine swears that this is exactly what I need?
http://www.bluesea.com/product.asp?Product_id=53476 |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
Posted: Thu Apr 06, 2006 11:20 am Post subject: |
For light duty use (anything in your camper is most likely light duty compared to a boat with a large bank of batts and heavy current draws) the relay system is just fine. I have mine that way and have never had any trouble. Also much cheaper and simpler to set up. _________________ '89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * * |
northwesty Samba Member
Joined: February 25, 2006 Posts: 45 Location: Vancouver
Posted: Fri Apr 07, 2006 12:06 am Post subject: |
I agree with surfer. Keep it simple. No need to complicate and waste time/money. I would DEFINITELY put in a manual switch though.
If you're driving in the boonies and it's late, raining, cold, yada yada. You should at that point shut off the aux batt charging relay manually, to help avoid alternator failure. It's quite a load to run the healights, stereo, windshield wipers, heater fans, and charge two batteries at the same time. |
