ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Fri Apr 07, 2006 1:21 pm Post subject: 2.1 exhaust onto 1.9 |
So my exhaust is giving up the ghost. it cracked today about 3/4" away from the flange on the #1 cyl. So. woudl it be advantageous to install a 2.1 exhaust on my 1.9 (actually a 2.2)?
Another option isthe S&S headers, but ive heard horror stories about those. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A
Posted: Fri Apr 07, 2006 1:32 pm Post subject: 1.9L vs 2.1L exhaust |
I went through the same debate. The best I can tell, the exhaust itself is completely the same. The difference is in the O2 sensor used, the 1.9L uses a sensor before the cat. The 2.1L uses a heated O2 sensor.
I have a complete 1.9L exhaust (good shape), with a new cat and new muffler if you are interested. I put a S&S header on my 85 westy. The only bad thing is, that the flange between the muffler and cat is gone. It is welded together. I can take pics if interested. |
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Fri Apr 07, 2006 2:24 pm Post subject: Re: 2.1 exhaust onto 1.9 |
ProvoCyclist wrote: |
Another option isthe S&S headers, but ive heard horror stories about those. |
They should be interchangeable... but check to see if you can get the stock one repaired. I have the S&S, and would indeed advise you to stay away from them. Stock is still the best, aside from the $tainle$$ stuff you might be able to find (although i think it is pretty much discontinued).
-Damon |
Posted: Fri Apr 07, 2006 2:46 pm Post subject: s&s header |
I'm happy with my s&s header. Fitting it was pure joy. Pulling my motor soon, and will be having it powder coated. |
Posted: Fri Apr 07, 2006 3:06 pm Post subject: |
Thanks for the input guys. i just ordered a new stock setup, 2-day delivery. I gotta have it running asap, as Klaus is my DD. _________________ Clark
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
r39o Samba Polizei
Posted: Fri Apr 07, 2006 3:56 pm Post subject: |
Klaus is my DD. |
Translation please! _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
wbx Samba Member
Posted: Fri Apr 07, 2006 3:58 pm Post subject: |
r39o wrote: |
Translation please! |
DD = "daily driver" on this mailing list.
if this were the "just mommies" forum my wife reads so much of, it would mean "dear daughter".
Acronyms are way too confusing... kwim?
-Damon |
