greent3 Samba Member
Posted: Sat Apr 08, 2006 8:12 pm Post subject: Just failed air care |
In B.C. we have a wonderfull thing called air care. The Gov't tests the emitions that come from your car. My 70 FI fastback failed, my hydrocarbons at idle are to high. I have never had this problem on my other air care tests. Can anybody offer any opinions on why the hydrocarbons may be to high and ways to fix the problem?
Thanks |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Sat Apr 08, 2006 8:29 pm Post subject: |
It's most likely running rich, or it might be caused by a miss or something.
What were the levels of the other chemicals in the exhaust?
Hydrocarbons are basically unburned fuel. |
Posted: Sat Apr 08, 2006 8:40 pm Post subject: |
Driving - hydrocarbons 255.00 ppm
- carbon monoxide 1.24%
- oxides of nitrogen 1493.00 ppm
Idle - hydrocarbons the test only regesters 2000 ppm and thats what I got, so it's probably even higher
- cabon monoxide 2.4%
The others were not even close to a fail only the hydrocarbons at idle. |
KTPhil Samba Member
Posted: Sat Apr 08, 2006 8:54 pm Post subject: |
Wow, that's really high at idle! I would check for air leaks, especially leading to the pressure sensor. A leak would fool the EFI into thinking you are under load and it would enrichen the mixture.
If I remember, 70s do not have a mixture adjust screw on the ECU, so that isn't it.
My shop used to have a "test pressure sensor" that they epoxied a hex key to the bellows adjustment screw so they could "tune" it during test. Won't work with the latest test equipment. In California, cars this old are exempt so I don't worry anymore.
Check hoses, fuel pressure, and also check for a leaking cold start enrichment injector (if your year has one).
(edit) Another cause can be old leaky injectors or a stuck injector. This and the air leaks will show up at idle, but get hidden at higher RPMs as your readings suggest.
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Bobnotch Samba Member
Posted: Sat Apr 08, 2006 9:49 pm Post subject: |
Also check the voltage, as a lower volt reading (12.5 or less) will cause the car to run rich. The D-jet is a very voltage sensitve system, and they have a tendency to run rich as the voltage regulator starts to fail. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Sun Apr 09, 2006 6:34 am Post subject: |
Getting the engine good and hot will also help _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
rloaircool Samba Member
Joined: January 21, 2004 Posts: 304 Location: Idaho Falls, Idaho
Posted: Sun Apr 09, 2006 7:03 am Post subject: |
COFBack wrote: |
Getting the engine good and hot will also help |
That might not be a bad idea either. When I was in highschool, I worked at a shop that did a lot of emissions testing. If a vehicle looked like it would have a hard time passing, my boss would have me take the car out for about 20 minutes, driving pretty hard. Then we would leave it ideling for 10 mins or so before testing it. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Apr 09, 2006 7:27 am Post subject: |
Check the resistance of the plug wires. You should be running the OE style with the replaceable ends. They should read under 1500 ohms. The resistance of the rotor should be under 5000 ohms. If you are running carbon core wires, get rid of them and go to the genuine Bosch wires.
And what Bob said. Check the charging system. Also, disconnect the fuel hose to the cold start valve, and plug it. You don't really need it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Apr 09, 2006 11:08 am Post subject: |
Thanks for the tips. I was able to get 3 months insurance when I failed, so I have some time to try and figure it out. I'll post the solution when I figure it out.
Thanks for your help
Eric |
