Raynor Shine Samba Member
Posted: Thu Apr 13, 2006 5:05 pm Post subject: 87 Westy Refrigerator Modifications |
Ok- so I removed the reefer to clean inspect & make modificaions as I could never get it lit on propane. Removal was straight forward & easy. Added the larger GOWesty cooling fan & pump valve/ new piezo ignitor. Cleaned out the burner box/ vac'd the exhaust & added an internal fan on the inside to keep cool air circulating.
Cleaned everything.. I mean CLEANED. Re-installation was not so bad but everyone knows where I am going with this...
I still can't get it to light on propane. I get spark & if too much gas is in the box, I hear a "pop" See a flash, but not lighting the pilot. So did I waste my time & money/ Does anyone have any advice?? |
CF Samba Member
Posted: Thu Apr 13, 2006 5:08 pm Post subject: |
vanagon.com has the best info for the fridge. |
Posted: Thu Apr 13, 2006 5:11 pm Post subject: |
& I have read all of the vanaon.com articels & Frank Condicelli info as well. |
r39o Samba Polizei
Posted: Thu Apr 13, 2006 7:03 pm Post subject: |
You got gas? How's your pressure regulator? You blow the whole mess out with compressed air? You try running it outside of the van to test? Can you smell som gas? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Joined: April 12, 2003 Posts: 1839 Location: Englewood, FL
detter Samba Member
Joined: September 22, 2005 Posts: 33 Location: Mahone Bay, Nova Scotia, Canada
Posted: Thu Apr 13, 2006 8:56 pm Post subject: |
I have done servicing jobs on several Dometic Westy fridges and have come up with a few tricks. When cold, the chimney is full of a cold, heavy plug of air. We need a draft going up the chimney just like in the house with a wood stove. Try starting the fridge on 110V then when the system gets warm (cool) shut off and try all the usual tricks. Some people clear the ignition box by blowing fresh air up the drain tube. Light the stove and check the flame height to make sure gas pressure is up to snuff.
All this is conditional upon you having cleaned the box, cleaned the jet in Acetone, checked the chimney for wasp nests, and filled the propane tank and holding your mouth just right.
I have also found that pumping in lots of air in between ignition attempts helps. Some people even resort to driving around for 5 minutes to clear the chimney-- Go Figure...
Once it is lit leave it on GAS and switch on your inverter and snap on the 110V switch for 10 minutes or so to hurry up the cooling process.
I know they discourage attempting to manually clean the jet but I have used my welding needle tips to do the job and under a magnifying glass the oriface was partially plugged and no amount of washing seemed to work. Good Luck! |
jaunck Samba Member
Posted: Fri Apr 14, 2006 8:41 am Post subject: |
If I haven't used the fridge on gas for any length of time, I usually hold the pilot light button for about 2 minutes to get all the air out of the system. Next is a 1/4 mile drive to a parking lot to get the accumulated gas out of the flue pipe/van and light the pilot. I've done this several times now and haven't had a problem. I could NEVER get it lit any other way after it had been sitting.
Don't try the sparker after holding the pilot light button down for a long time. Kinda sounds like lighting a tin can tennis ball launcher... |
Dogpilot Samba Member
Posted: Fri Apr 14, 2006 9:37 am Post subject: |
One quirky thing I did to improve mine was open up the water drain at the bottom front. Suck on the drain hole with a vacuum cleaner. Mine had a lot of fine rust particles in it. I actually left it open for a couple of days and drove about. The vibration filterd a bit more rust from the drain, and I vacuumed the drain again. You can put an ear bulb (one of those small round bulb squiter thingies), and pump some air into the chamber with that. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Fri Apr 14, 2006 3:07 pm Post subject: SWEEET |
Everyone- thanks for the good karma!!
The refrigerator is lit right now!!! took some patience, but I kept pumping & held the button down until the pilot stayed lit. It hadn't been started that way in a very long time so the pilot went out a couple times until it felt like staying on!!
We are in business. New fan working too/ sadly not the LED light. Maybe tomorrow~ |
DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Sun Apr 16, 2006 6:23 am Post subject: |
1 – the PO had used the fridge, but never maintained it. Even cleaning it was beyond them. Years of exploded coke cans and eggy- goo had built up inside of it it and its little cooling fins. Yikes – they are sharp.. clean with care. I used "Awesome" (Dollar store) cleaner – worked REALLY well.
2 – Took off the outer cover off the flue-vent and blew some compressed air into the exhaust and intake of the unit – oh my – the crap that flew out… I must have blown at least 2 lbs of rust, "gray matter", dust, bugs, and other debris out of the unit.
3 – Took off the water drain – nothing came out. Good, I look down – close and see that the entire drain is jammed with rust and carbon debris! I took a pick and started to see that the crap was jammed into the tube 6"! I would pick, blow air, pick, blow air – and finally gave up (what the hell, its all ready broke..) and shoved a rubber tipped blow gun with 120 PSI into the drain. At first – nothing then a nice "FOOSH" sound and air flow!
4 – I primed the system by running the stove for 45 seconds – 5 pumps of air – lit right up. I then turned my eye to the little non- visible "visible" flame down in the corner of the unit and yup – she was a burnin! However the LED on the front stove panel was not on. _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) |
jarnevic Samba Member
Posted: Tue Sep 27, 2011 12:48 pm Post subject: 1984 Vanagon Refrigerator Removal |
I want to install the Gowesty Fridge Elimination Kit and the first thing in the instructions is to remove the old one; Gowesty wants you to buy the entire Bentley VW manual at great expense, when all I want is page 76.24, which explains the removal. Any ideas on how to remove this thing? |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1888 Location: Sidney B.C. Canada
Posted: Tue Sep 27, 2011 1:16 pm Post subject: Re: 1984 Vanagon Refrigerator Removal |
jarnevic wrote: |
yeah, crazy eh? Needing the Bentley manual for the fridge removal. Not that you would find it helpful for other things on the van that might me more difficult to do,
It is not a "great expense" if it saves you just one trip to a mechanic.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
gbrandt Samba Member
Posted: Tue Sep 27, 2011 1:49 pm Post subject: |
And after all that work, you will find that the fridge is the same piece of sh*t, just cleaner.
I did the same things and the fridge sucked all summer. _________________ 'Lucky' our 1987 Red Westy, ASV 1.9 TDI ~130HP, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
