What interior door panels and seats do I have.
burner
burner is offline
PostPosted: Fri Apr 14, 2006 3:06 pm    Post subject: What interior door panels and seats do I have. Reply with quote
I read the treatise on middle seats by Lind (very helpful) and checked the tech. section and came up with this so far.
Middle seat:
The four post middle seat with the angled leg is 64-67. It has an ashtray so it is from a microbus or deluxe. If this is all correct the upholstery doen't match the range of options listed in the technical section.
Front seats:
I don't know what these seats are, or the door panels.
Any help appreciated.
PostPosted: Fri Apr 14, 2006 3:13 pm    Post subject: Reply with quote
The middle seat is the correct Silver Beige/Basalt Grey for a '64 Deluxe.
The heat-seamed pattern and color makes it '64 only.
The front seat and door panels are aftermarket and "incorrect".
burner
burner is offline
PostPosted: Fri Apr 14, 2006 3:24 pm    Post subject: Reply with quote
Thanks Everett,
My middle seat just doesn't look much like the example in the paint/upholstery section of the "Technical" page. Wish I had the original panels and front seats too. I appreciate your time.
PostPosted: Fri Apr 14, 2006 3:29 pm    Post subject: Reply with quote
It looks the same to me:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=213682
The pattern is slightly different as your seat is heat-seamed and that seat has the earlier sewn pleating.
The door panels are available new so you could restore your interior.
Unfortunately the heat-seamed seat material is not available.
burner
burner is offline
PostPosted: Fri Apr 14, 2006 3:58 pm    Post subject: Reply with quote
My middle seat seems much more two-toned and far more beige than the example but I am happy it is correct.
PostPosted: Sat Apr 15, 2006 8:31 am    Post subject: Reply with quote
I think the lighter color fades or yellows or gets sun damaged.
burner
burner is offline
PostPosted: Wed Jun 07, 2006 2:36 pm    Post subject: Reply with quote
More questions,
I have a rear seat that matches the materials in middle seat (siver biege/basalt grey) but no luggage bar across the top. I can feel the three mounting brackets on the back of the rear seat but there are no holes in the material. Shouldn't a rear seat in this color scheme have (or have had) a luggage bar as this scheme was only used on deluxes? I have all the other jailbars.
Is there anyway to determine if my walk through came with a 2/3 or full middle seat. I know the full seat I have is not common in a walk through. Unfortunately, my cargo floor has been hacked up a bit.
All of these clues are making me think the rear and middle seats are not original to my bus but I would like to confirm this somehow.
Thanks for any help.
PostPosted: Thu Jun 08, 2006 9:18 am    Post subject: Reply with quote
It could be a Standard seat with no luggage bar. The standard seats do not have the 3 brackets so you should not be able to feel them. They did have a metal plate across the top edge of the seat.
Short or long middle seat - Check your M-code plate for the model #. 241 = full seat. 251 = short middle seat.
burner
burner is offline
PostPosted: Thu Jun 08, 2006 3:05 pm    Post subject: Hooray Reply with quote
Thanks Everett,
The M code says 241 so it could still be the original seats.
I am certain I can feel three bracket on the back seat each with two round holes one over the other. This seems like the proper arrangement based on pictures of the luggage bar supports I have seen. If there was a luggage bar at some time there would have to be holes in the upholstery, right?
PostPosted: Fri Jun 09, 2006 5:25 am    Post subject: Reply with quote
Yes, the holes should be there.
burner
burner is offline
PostPosted: Tue Jul 11, 2006 3:27 pm    Post subject: Reply with quote
Everett, you are probably tired of this but, I am still curious. You have been very helpful.
I am certain my rear seat frame has three brackets at the top each with two holes for a luggage bar. The material is the heat seamed silver beige/basalt grey used only in a '64 sealing wax red/beige grey deluxe but, it has no holes in the upholstery where the post mount screw should go through.
Did any deluxes come without the rear seat luggage bar?
Did some standards actually get deluxe seat frames and upholstery without luggage bars?
I am thinking of getting a luggage bar for the rear seat but I am hesitant to put holes in the original material.
Thanks
PostPosted: Tue Jul 11, 2006 8:18 pm    Post subject: Reply with quote
I don't think so.
Thanks
This is possible - maybe someone made a mistake and used a Deluxe seat frame. Standards have a metal plate screwed along the top rear corner of the seat frame. This could screw into any seat frame.
iamdonquixote
iamdonquixote is offline
PostPosted: Tue Jul 11, 2006 8:33 pm    Post subject: Reply with quote
that color combo would also have come on mouse grey / pearl white buses ( deluxe & standard ) 64 buses also had color matched headliners.
PostPosted: Tue Jul 11, 2006 8:37 pm    Post subject: Reply with quote
No, Mouse Grey Buses have single-tone seats.
iamdonquixote
PostPosted: Tue Jul 11, 2006 9:20 pm    Post subject: Reply with quote
ok, I see that seat is two tone, but wouldn't the deluxe mouse/white buses have had two tone seats or was in -only- on the red buses?
burner
burner is offline
PostPosted: Wed Jul 12, 2006 3:49 pm    Post subject: Reply with quote
Hey Hey! I have become a "Samba Contributor". I love it. I used to be a trainee or something like that.
According to the technical section, only the sealing was red buses have the two tone seats in 64.
The frame of my seat feels like the frame in the following picture.
https://www.thesamba.com/vw/gallery/pix/187525.jpg
Does anyone have a picture of an uncovered rear seat frame from a standard for comparison. I didn't find one in the gallery.
I will post a picture of the rear seat soon. It has the same material as the middle seat, a material that is not available in reproduction.
Somehow, I have a deluxe rear seat frame covered with original deluxe upholstery with no evidence of any luggage bar.
Volkswagens can be such mysteries.
Thanks for the replies.
Jerry J
Jerry J is offline
PostPosted: Wed Jul 12, 2006 10:16 pm    Post subject: Reply with quote
Hi Mike,
My standard has a deluxe back seat that I recently re-upolstered. It had the same tabs along the top bar. Of course the little tab on the side is for mounting the seat to the side of the bus. Unfortunately I didn't snap a photo before putting the new cover on.
There could be a possibility that your seat was recovered back in the days when the material was available and the luggage bars weren't re-installed.
If you were to ask for my opinion I'd put the luggage bars on. It certainly wouldn't be wrong on such a cool bus.
Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab
burner
burner is offline
PostPosted: Fri Jul 14, 2006 11:48 am    Post subject: Reply with quote
Jerry J wrote:
Hi Mike,
Thanks Jerry. The material looks quite old but it could just be old replacement material I suppose. Seems to be the most logical hypothesis as it seems unlikely to come from the factory without a luggage bar or holes in the material.
Hope to see you at the Bug In or the Drive In.
Absolutely Volkswagen
absolutelyvolkswagen.org
