oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Sat Apr 15, 2006 10:35 am Post subject: how high can be the oil temperature at a 36hp engine?!°!? |
hi, i have now tested my oval, but as a type 4 engine only driver, i was a little bit speachless as i looked at my oiltemgauge by drivening about 60-65miles/ hour and my oiltemperature goes up to 230°F - 250°F (110°-120°C)
i thing that it is a little bit to high, so what do the oval 36hp enginedrivers normaly have
my engine is new rebuilt ( crank cam , bearing oilpump) but it have a judson on it, and also i have an extern oilcoolter mountet instead of the original ( mounted on rear torsionbar)
any suggestions?!?!
_________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 15, 2006 11:08 am Post subject: |
Hi oval56,
230F you really do not want to get to. Personally we prefer to keep the temp below 220F. Backing off on the gas as the temp gets above 212F.
Check your oil temp with a gauge type you can get the sender down the dipstick. Candy thermometers have to be very accurate, and are inexpensive. Test the test gauge with boiling water at somewhat near sea level or boil temp adjusted for higher altitudes.
The oil cooler with no fan is not going to work well. Better to get it back inside the shroud in a doghouse to give it better cooling. |
Bruce Samba Member
Posted: Sat Apr 15, 2006 11:40 am Post subject: |
Congratulations, you have just proven that replacing the stock oil cooler inside the fan shroud with an external one makes the oil temp go up. Rip out all that crap and stick a stock cooler in the shroud.
If you think you want more cooling, use a Porsche 356 oil cooler. They are the same size as a VW one, but are aluminum so they dissapate the heat better. |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Sat Apr 15, 2006 12:48 pm Post subject: |
Hi I have just put 500km on my freshly rebuild 36hp engine with Judson, in the last week, and I have mounted a 356 oil cooler on it, and when I am cruising with 100-110km/h the oil is 70-80 degrees celcius.
It is not aluminuim (in fact I have never seen one in aluminuim) but it have wings/baffles like a radioter on a modern car or newer oil cooler, I had it tested and the guy said that it would be about 50% more effective than the original one.
Here is a picture from the rebuild, but it is a little difficult to see it properly.
_________________ http://vw-bluehats.blogspot.com/ |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Apr 15, 2006 7:20 pm Post subject: Post subject: how high can be teh oiltemperature at a 36hp |
Peter , glad the cooler worked out for you . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Sat Apr 15, 2006 8:10 pm Post subject: |
I am also rebuilding the motor for my 54 bug and am wondering about using the 356 oil cooler mentioned above. Is their a specific year 356 oil cooler you use and are any other mods necessary to use it .Thanks |
oval56 Samba Member
Posted: Sun Apr 16, 2006 6:55 am Post subject: |
okay, thanks for all that ideas, but my idea was it to replace the stock cooler, to get the headtemperature at a low level , so now i will try a 356 cooler instead of my extern one or later plus my extern one _________________ www.oval56.com
www.dbkvw.com |
Posted: Mon Apr 17, 2006 12:25 am Post subject: |
Hi Troy
Yes it just worked out fine
Thanks again.
rlmatinez The only mods I needed to do was to hammer the inside of the fan shroud a little, as the 356 cooler is a little higher.
As for which year it is ask Teeroy he is the man I bought it from.
56oval Anothother idea could be making a fanshroud with a dog house oil cooler, this way you still get good coolin on your heads, I was thinking on doing so on my own. _________________ http://vw-bluehats.blogspot.com/ |
oval56 Samba Member
Posted: Mon Apr 17, 2006 1:42 am Post subject: |
hi peter, i just bougth a 356 oilcooler via ebay yesterday, hope that i get it installed to 1.mai hannover and hope also that it will work _________________ www.oval56.com
www.dbkvw.com |
Posted: Mon Apr 17, 2006 7:02 am Post subject: |
oval56 wrote: |
hi peter, i just bougth a 356 oilcooler via ebay yesterday, hope that i get it installed to 1.mai hannover and hope also that it will work |
Sounds good Andi then we can talk about oil temperature when we are drinking beer and looking at Gradulux
I am taking the 54 down there. _________________ http://vw-bluehats.blogspot.com/ |
oval56 Samba Member
Posted: Mon Apr 17, 2006 7:24 am Post subject: |
i will also came with my 57, but i think on trailer if the coler do not arrive in end of this week ....
Peter_Plade wrote: |
oval56 wrote: |
I am taking the 54 down there. |
www.dbkvw.com |
Posted: Mon Apr 17, 2006 12:29 pm Post subject: |
Okay but no trailer queens here
I am taking the 600km each way, in the oval with a buddy of mine _________________ http://vw-bluehats.blogspot.com/ |
My57Oval Samba Member
Posted: Mon Apr 17, 2006 7:30 pm Post subject: |
I am surprised that the motor didn't seize up! There is a reason that those crazy German Engineers put the cooler INSIDE the doghouse. The internal one combined with the external one would probably lower temperatures, but I bet you wont get past 1000KM without it developing a leak somewhere. Just my opinion. |
oval56 Samba Member
Posted: Mon Apr 17, 2006 10:21 pm Post subject: |
rakeyworth wrote: |
my idea was the same as i have done it at my 2.4 type 4 engine, this 2.4 liter has only a extern oilcooler and a 36hp fanshroud, oiltemperature has in maximum 100°C, and work fine the last 20000miles
at my 36 judson engine i hat a extern cooler and the okrasa cooler, but oiltemperatures are to high... so i now will try the original 356 coller, but now the zylinderheadtemperature will rise _________________ www.oval56.com
www.dbkvw.com |
oval56 Samba Member
Posted: Tue Apr 18, 2006 1:09 am Post subject: |
I am taking the 600km each way, in the oval with a buddy of mine |
i'm not a trailer fan, but i now have 500km testing on my oval, and everything work fine, beside the oiltemperature... so my girlfrind decided that i have to trailer it ...
this is my second meeting within the last 10 years wich i have to use the trailer _________________ www.oval56.com
www.dbkvw.com |
Posted: Tue Apr 18, 2006 1:39 am Post subject: |
I am only kidding I understand you perfectly no need to destroy the new engine
I was thinking is your type 4 not getting hot when you are holding still?
I have several frinds that driving with big type 1 egines 2276 etc
but they all have a doghouse oilcoolers and a seperat front mounted oil cooler.
Another thing is are 100% sure that your gauge shows the correct temperture? My nos motometer unit had to adjusted when I put in the car. _________________ http://vw-bluehats.blogspot.com/
oval56 Samba Member
Posted: Tue Apr 18, 2006 2:25 am Post subject: |
hi peter,
my gaues are nerly perfekt, i use the same in my 56, and they both have a difference about 5 degrees at 120°C, so they work perfect..
my type 4 engine has only the frontoilcooler ( setrab) , and when i drive to the meetings, my speed is 140-160km/h at 3500-4500 upm constant, the oiltemp goes to 100°C ( if it is hot outside the maximum is 105°C), cylinderhead goes at this speed from 140-160°C, also nearly perfect...
berfore i will reach oiltemp higher than 110° i had to slow down, becaus the cylinderheadtemp will go higher than 180° ...and 180°C is my stop point _________________ www.oval56.com
www.dbkvw.com |
oval56 Samba Member
Posted: Tue Apr 18, 2006 11:27 am Post subject: |
i will hope it also... otherwise i have to remove this high power engine for a type 4 ( just a joke) _________________ www.oval56.com
www.dbkvw.com |
oval56 Samba Member
Posted: Tue May 02, 2006 10:10 pm Post subject: |
oilpreasure and oiltemperature problem is now solved
i had installed a 356 oilcooleryesterday , and have reinstalled my extern cooling system
now it works fine as it has to work ))))) _________________ www.oval56.com
www.dbkvw.com |
