Godsbug Samba Member
Joined: April 29, 2006 Posts: 996 Location: Renton, WA
Posted: Tue May 09, 2006 12:20 pm Post subject: The best method for timing? |
I have a question about timing for Anne. She is a stock 1500 6V with dual stock carbs, single port with vacuum advance distributor. What is the best method for setting the timing? My uncle helped me with it and unplugged the vacuum line from the distributor when timing it while running. Should that be left on when it's running with the timing light? Should I use the cheapy method of turning the dist (engine not running) until the points close and setting it that way? Or is he right in unplugging the line when setting the timing?
Thanks in advance for your help. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Tue May 09, 2006 12:23 pm Post subject: |
with stock equipment and an all stock motor, I would time it the old fashoned way, engine off, with a test light. You should be able to look up your engine # in any good vw book tune up section to find the correct timing mark to use _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue May 09, 2006 5:46 pm Post subject: |
How do you do that? What tools do I need? _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
KTPhil Samba Member
Posted: Tue May 09, 2006 6:39 pm Post subject: |
Three VWs and you don't know how to set timing with a test lamp (spare bulb)?
Do you have Muir's Idiot book? (not trying to be insulting, that's its nickname). Best source for the novice and the rest of us alike. Has a good section on timing and why. And he does it with cheap tools, so you won't go broke.
Posted: Tue May 09, 2006 6:47 pm Post subject: |
Crazy as it sounds, I've never used a timing light. I've actually never set the timing myself, and I've had VW's for 15 years.
Yep, I've got the idiot book. We used the timing chart in the book, but it didn't seem to help anything once I got her back on the road. I'm curious because we changed the timing quite a bit. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue May 09, 2006 6:51 pm Post subject: |
The "best" way is with a digital timing light that has a built in tach and you can set the advance so you don't need a degreed pulley. _________________ Glenn
Member #1009
#BlueSquare |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Tue May 09, 2006 7:15 pm Post subject: |
A timing light will be no use on a 6v car. you will need to static time it as Eric states! _________________ To his their own PBJ
Pl@y@ #1 |
KTPhil Samba Member
Posted: Tue May 09, 2006 7:19 pm Post subject: |
Cost: $100
Muir's way: 50c
Yeah, fancy will be better, but you can at least eliminate bad timing as a cause with a static setting. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue May 09, 2006 7:20 pm Post subject: |
DMNCLNR wrote: |
A timing light will be no use on a 6v car. you will need to static time it as Eric states! |
My timing light works on both 6V and 12V, but yes, best bet on a stock 6V engine is to static time it. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Tue May 09, 2006 7:28 pm Post subject: |
Russ Wolfe wrote: |
DMNCLNR wrote: |
My timing light works on both 6V and 12V, but yes, best bet on a stock 6V engine is to static time it. |
Is there a switch to go from 6 to 12v? or is it universal? I have never got one to work on a 6v car! _________________ To his their own PBJ
Pl@y@ #1 |
Posted: Tue May 09, 2006 7:57 pm Post subject: |
My uncle hooked the timing light up to a 12V battery and attached the clamp to a ground and did it that way. It seemed to work. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Posted: Tue May 09, 2006 8:00 pm Post subject: |
DMNCLNR wrote: |
Russ Wolfe wrote: |
DMNCLNR wrote: |
Is there a switch to go from 6 to 12v? or is it universal? I have never got one to work on a 6v car! |
It is just universal. All the timing lights I have will work on 6V. Mostly, the internals of the electronics of the light just want some power, 5V and up to about 24V. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Wed May 10, 2006 10:26 am Post subject: |
So is it bad to unhook the vacuum line when timing the car using the timing light? Will it change the actual timing? _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
KTPhil Samba Member
Posted: Wed May 10, 2006 11:36 am Post subject: |
Depends. If you set it to about 30 total at high rpm, you can leave it on. On the other hand, if you set it at idle to TDC or thereabouts, remove it from the distributor and plug it for the setting. See the books for the exact setting (or stay tuned, I'm sure I'll get corrected!) |
Erik G Samba Member
Posted: Wed May 10, 2006 12:02 pm Post subject: |
go back to the idiot book, forget everything you have done, and start from the begining.
With all the stock equipment that you have, you do not need a static timing light (timing gun) it is much easier to do it the way the book has it _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
KTPhil Samba Member
Posted: Wed May 10, 2006 3:29 pm Post subject: |
"Static timing light" is just a bare bulb in a socket with a couple of alligator clips. That is what the Idiot Book recommends. Dynamic (i.e., while moving) timing is what you would need a strobe for. |
Posted: Sat Jun 03, 2006 6:45 pm Post subject: |
OK, the idiot book doesn't work for me in this instance. I used a light bulb the idiot book way and the light stays on for a full quater turn of the engine. What am I doing wrong? As I speak the car is half a block down the street and won't start. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
Posted: Sat Jun 03, 2006 7:56 pm Post subject: |
Hook up the static test light to the distributor side of the coil. (green wire). Turn the engine over to the timing marks slowly by hand. The light should just come on as you come to the timing mark. (points just opened). It WILL stay one for about 1/4 turn of the engine, or until the points close.
If it doesnt come on as you bring the engine onto the timing mark, move the distributor slightly and try again.
After you learn to do it this way a few times, you can actually do it by ear as you will hear the point snap as they open. A good thing to know if you are in the middle of nowhere and dont have any fancy tools. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun Jun 04, 2006 6:27 pm Post subject: |
I got it to work! Thanks guys, it made a WORLD of difference.
Now my only frustration is with the starter, but as long as I plan out my trips with a half an hour in between drives I'll be OK.
Thanks! _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
